Old Sat, Apr-07-2007, 10:45:39 PM   #1
Bmw M3 Guy
LSB E46 M3
Bmw M3 Guy's Avatar
Reputation: 0 Bmw M3 Guy is on a distinguished road
Default Fuel tank sending unit, Fuel filter, Fuel pressure regulator. Update and question
Attached below are the parts and labor I need to fix my car. Going back to this thread:http://www.m3forum.net/m3forum/showthread.php?t=155177
I guess the Fuel regulator, pump and sending unit need to be replaced, but I feel it exceeds what the price should be.
Does this sound right? Is there any kind of warrenty, recall, or bulletin on this?
Is this job hard to do with 2-3 people?
I can just buy the parts I need and do it myself if its not hard.
Let me know what you guys think. This will exceed $1,500 at the dealership.
Please let me know what you think.
Justin
Current: E92 M3 Fully Loaded Aw/Extended Black/CF
6MT
Rpi-Gtm Header Back Exhaust
H&R Spacers
ESS Tune
Sold: E46 M3
Factory - Everything except Nav.
Aftermarket- Gruppe M Ti exhaust, 19’’ Ssr Gt-10, 285x30x19R - 255x35x19F, Jl 10''W7/Jl 500/1, Blacked Grill, Blacked Gills, L.e.d. tail lights, Angel eyes, Depot crystal smoked corners, Painted reflectors, Uuc pedals, H&R sport springs, K&N drop in filter, Drilled rotors, Axis pads.
Sold: 500 Hp S4
Myspace: http://www.myspace.com/m3guy
Jump to top Bmw M3 Guy is offline   Reply With Quote
Old Sat, Apr-07-2007, 11:39:17 PM   #2
kiloil
kiloil's Avatar
Reputation: 0 kiloil is on a distinguished road
Yikes!
The fuel filter and the regular are really easy to remove and replace.
The fuel pump, it seems you will have to drop the tank to get to.
You can probably do this with a friend (dropping tank) and you might spend $425.00.
Jump to top kiloil is offline   Reply With Quote
Old Sat, Apr-07-2007, 11:39:36 PM   #3
ArtM3
Reputation: 0 ArtM3 is on a distinguished road
according to realoem
clamps are 56 cents
the level sensor is $47
the pump $231
filter $39
regulator $70
I've ALWAYS paid less than their prices including my BMWCCA a good bit less...
total $390, I'd pay about $330 or so...
the labor:
filter/regulator ~1/2 hr (I've done it)
the fuel pump/level sensor maybe 1 hr (I've done it on an e36, very similar)
w/ cleanup and all 2.5 hrs max...they want ~7 hrs!
both jobs are very simple if you have any mechanical apptitude...
disconnect battery
the sensor & pump are accessed by removing the rear seat (5 minutes)
they are secured in the tank by 2 large locking rings...unplug, unscrew & replace...maybe 15 minutes each...
fuel filter/regulator
with car on lift (actually this can be done on jack stands)
remove cladding & shield 5 minutes
remove filter clamp 1 minute
remove hoses, quick release fittings, very easy maybe <10 minutes
remove regulator block from filter, remove regulator from block <5 minutes
install new regulator onto block, screw filter into block (don't forget the crush washer) <5 minutes
reassemble 10 minutes
http://www.realoem.com/bmw/showparts...08&hg=13&fg=10
http://www.realoem.com/bmw/showparts...73&hg=16&fg=15
Jump to top ArtM3 is offline   Reply With Quote
Old Sat, Apr-07-2007, 11:51:52 PM   #4
Bmw M3 Guy
LSB E46 M3
Bmw M3 Guy's Avatar
Sweet. Now I just need to make a friend on the forums that lives near me to help!
Sd People?
Haha
Thanks
Justin
6MT
H&R Spacers
ESS Tune
Sold: E46 M3
Sold: 500 Hp S4
Old Sat, Apr-07-2007, 11:57:43 PM   #5
ArtM3
dood, you could fly me and my wife out, I'd do the job in 2 hours, you buy the parts...it would still be cheaper
parts ~330
2 tickets ~ $250 each
total $830 as opposed to $1500
Old Sun, Apr-08-2007, 12:02:28 AM   #6
ArtM3
do it outside or in a well ventilated area
make sure your gas tank is <1/2 full
wrap rags around the fuel filter connections as you disconnect them (sops up the fuel)
make sure all vapors have disapated before reconnecting the battery
Old Sun, Apr-08-2007, 12:07:21 AM   #7
CARVER
Modded
CARVER's Avatar
Reputation: 579 CARVER has a reputation beyond reputeCARVER has a reputation beyond reputeCARVER has a reputation beyond reputeCARVER has a reputation beyond reputeCARVER has a reputation beyond reputeCARVER has a reputation beyond repute
parts ~330
Dood, Justin, hurry up and take him up on it before the wine/beer wears off!!!!
Jump to top CARVER is offline   Reply With Quote
Old Sun, Apr-08-2007, 12:12:19 AM   #8
Bmw M3 Guy
LSB E46 M3
Bmw M3 Guy's Avatar
fine ill do it haha.
parts ~330
done , ill fly you out hahaha
maybe I can call you when I get to doing it.
walk me through it perhaps?
6MT
H&R Spacers
ESS Tune
Sold: E46 M3
Sold: 500 Hp S4
Old Sun, Apr-08-2007, 12:44:40 AM   #9
ArtM3
hook up a webcam
my billable rate as a PE is $135/hr
seriously, when you get around to it, feel free to PM me with any questions...
Old Sun, Apr-08-2007, 01:13:48 AM   #10
ArtM3
I just looked up the labor rates on my BMW KSD
1 fru = 5 minutes
filter & regulator togther 11
without draining tank (just make sure it's <1/2 full)
sensor 4
pump 7
110 minutes total < 2 hrs, and mechanics always beat these numbers on routine procedures...
How hard is it to change the fuel sending unit? UA///M3 E46 M3 (2001-2006) 40 Thu, Jun-28-2007 03:56:54 PM
My m3 not cranking ...could it be the fuel regulator? Fuel pump? imperialHWY E46 M3 (2001-2006) 10 Wed, Nov-08-2006 03:01:25 PM
My m3 not cranking ...could it be the fuel regulator? Fuel pump? imperialHWY General BMW Discussion 4 Wed, Nov-08-2006 01:30:51 AM
My m3 not cranking ...could it be the fuel regulator? Fuel pump? imperialHWY Pacific 0 Tue, Nov-07-2006 03:55:51 AM
please help about fuel pressure regulator!!!! B.M.W E46 M3 (2001-2006) 0 Sat, Jun-11-2005 06:56:25 AM
Discussing Fuel tank sending unit, Fuel filter, Fuel pressure regulator. Update and question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
