Old Fri, Apr-20-2007, 12:01:30 AM   #1
marmarm3
marmarm3's Avatar
Reputation: 0 marmarm3 has disabled reputation
Default cold start spueel = dealer fixed
The problem that i was having when the car started cold was because of the pulleys. Was under CPO and only paid 50 deductible. The bad part though was they ****in scratched my car and but 10 miles on it. Is 10 miles normal or a a little over?
Thanks
Jump to top marmarm3 is offline   Reply With Quote
Old Fri, Apr-20-2007, 12:38:29 AM   #2
r6vr6
Reputation: 0 r6vr6 is on a distinguished road
What did they change a tensioner pulley ?
Jump to top r6vr6 is offline   Reply With Quote
Old Fri, Apr-20-2007, 01:10:51 AM   #3
marmarm3
marmarm3's Avatar
yea they replaced the alternator drive belt tensioner
Old Fri, Apr-20-2007, 01:13:01 AM   #4
eurone46
TitanM3
eurone46's Avatar
Reputation: 0 eurone46 is on a distinguished road
they drove the car for ten miles thats alot dude.. i know a friend a the dealer and they said they can only drive it for a mile or something like that.
gt45r top mount
Mods: k&n 63 CAI, jvt headers, debaffled M exhaust, D/a race soft, rogue ssk, D/A street pulleys, cdv delete, cat delete, jp LWF, sach clutch, H&R coilovers, TMS sways. SS clutch lines, SS brake lines and a few cosmetics
Future works, alpha n tune with ITB's
Jump to top eurone46 is offline   Reply With Quote
Old Fri, Apr-20-2007, 01:21:49 AM   #5
marmarm3
marmarm3's Avatar
yea that's what i thought. But i can'tdo anything now. he SMG was also real jerky, i had to reset itlike 7 times to get it to be smooth again.
Old Sat, Apr-21-2007, 01:37:52 AM   #6
marmarm3
marmarm3's Avatar
never mind the problem happened again today. MF's didnt fix shiit. They better not charge me another deductible for going again for the same problem they didnt fix.
Old Sat, Apr-21-2007, 02:15:24 AM   #7
deilenberger
deilenberger's Avatar
I actually don' think this is a "problem" - mine did it for a period of time - then just stopped. If the squeel continued for more than a minute or so after starting I might be concerned - but what's happening is the alternator is working hard to replenish the power in the battery that was used to start the engine.. and there is probably a tiny bit of slipping of the alternator pully/belt causing the noise.
To me - it's a "they all do that" and it's harmless sort of thing.
  • 2001 M-Coupe - TiSilver/Black - Das Boot..
  • 2006 Cayenne/S - Iceland Silver Metallic/Stone-steel Gray - Truckster.
  • 2007 R1200R - Roadster, black mit/white pinstripes - the REAL BMW..
Old Sat, Apr-21-2007, 03:21:19 AM   #8
marmarm3
marmarm3's Avatar
yea that's what i though and let it go for like a year. But after reading on the forum people having the same problem fixed, it convinced me to fix it too. Should i just let it go? The things that concerns me is if this will cause a major problem in the future as time goes by. Theres another issue that wasnt there but started after the dealer replaced the alternator drive belt tensioner= when i turn the car on for ignition, the car goes to life then for a split split 1/000th of a second, it feels like it died and then finally turn on. It's real hard to explain, its like the car turns on the belt is going and suddenly the belt gets stuck and in an instant it gets loose. You can feel it when you turn the key. What might be the cause of this?
Thanks
Engine Squealing @ Cold Start Only Mornings What Bmw Dealer Should I Go? xxweisxxm5 Pacific 8 Thu, May-25-2006 11:48:56 PM
Really fixed the cold start issue rustamabd E36 M3 (1992-1999) 5 Fri, Oct-31-2003 10:20:45 PM
Cold Start problem fixed! astan100 E36 M3 (1992-1999) 11 Tue, Sep-23-2003 07:13:16 AM
Cold start fixed, but EML light just appeared topaz E46 M3 (2001-2006) 0 Tue, Jul-01-2003 02:59:17 PM
Cold Start Fixed muf E46 M3 (2001-2006) 8 Thu, Aug-22-2002 01:34:36 AM
Discussing cold start spueel = dealer fixed in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
