Closed Thread
Old Fri, Oct-29-2010, 03:07:44 AM   #11
deilenberger
deilenberger's Avatar
After checking the connection - you may as well go get a rebuilt one from BMW... what you're seeing is brush bouncing - the slip rings are probably out of round and/or the brushes are worn out and the springs aren't pushing them against the slip rings hard enough.
The "rebuilt" ones from Autozone would be better called "repainted" ones.. and since worn brushes are probably the biggest cause of failure, it's not a surprise that the ones you're getting are having problems. If you're real ambitious - take one to a local auto-electrical shop that does alternator rebuilds. They'll have a new regulator/brush assembly that just screws right in, and chances are good that will fix the problem.
  • 2001 M-Coupe - TiSilver/Black - Das Boot..
  • 2006 Cayenne/S - Iceland Silver Metallic/Stone-steel Gray - Truckster.
  • 2007 R1200R - Roadster, black mit/white pinstripes - the REAL BMW..
Jump to top deilenberger is offline
Old Fri, Oct-29-2010, 01:29:15 PM   #12
MY02M3DINAN
MY02M3DINAN's Avatar
Reputation: 0 MY02M3DINAN is on a distinguished road
Originally Posted by ZiMMie View Post
OP check you power cable from the alternator to the starter. Also check the main connection at the boost point left side of the engine bay.
GREAT ideas... checked them both and they are OK.
The battery is only a couple years old and holds a charge very well.
I measure at least 12VDC after sitting overnight.
I'm going to check my battery connections again.... I've had problems in the past with a poor clamp. Maybe this is the cause?
Anyone know if the alternator is circuit breaker/fuse protected?
I recall old style headlights had an automatic resetting circuit breaker system that caused the headlights to blink when there was a short.
But If I still have problems, I'm taking the alternator to a local shop to be checked out.
2002 TiAg M3 Cabriolet
Dinan S-M3 Kit
{Throttle Bodies/CAI/MAF/Stage 4 software}
Dinan Strut tower brace & Front sway bar
Auto Solutions SSK
UUC Motorwerks "Rasp-X" mid-pipe
Urethane RTAB's/FCAB's/RSM's
Hawk HPS Brake Pads
CDV delete
V1 Hardwired
THIS CAR IS NOW FOR SALE!
Jump to top MY02M3DINAN is offline
Old Fri, Oct-29-2010, 01:33:34 PM   #13
Voltaire
Voltaire's Avatar
Reputation: 0 Voltaire has disabled reputation
After reading about all the problems with Autozone alternators, I'd be inclined to go with one from BMW.
2006, AW 6spd. SOLD
Originally Posted by Miami M3 View Post
i voted walk because like most americans you are probably fat and could use the exercise
Jump to top Voltaire is offline
Old Fri, Oct-29-2010, 03:07:03 PM   #14
MY02M3DINAN
Well, considering my factory alternator, and now TWO different ones from autozone all have the exact same issue.... I'm wondering if its an alternator problem at all?
Dinan S-M3 Kit
Auto Solutions SSK
Hawk HPS Brake Pads
CDV delete
V1 Hardwired
Old Fri, Oct-29-2010, 03:20:55 PM   #15
Alchemist753
2003.07 E46 M3
Reputation: 0 Alchemist753 is on a distinguished road
Was pricing alternators just a few days ago for my 2003 M3, the best options I found were:
NEW Valeo from pelican at $341
REMAN Bosch from eeuroparts at $169 + $100 core or bavauto at $170+$73 core
If you are looking locally, NAPA comes in at $245 + $89 core for the REMAN
Bosch part # is AL9407X for my 2003 M3, may differ for late models.
Prices may of course have varied by now. Not sure about shipping costs.
Jump to top Alchemist753 is offline
Old Fri, Oct-29-2010, 06:04:43 PM   #16
Toxic0n
Go to an alternator shop and get the alternator load tested. They should be able to tell you if there is something wrong with it.
Jump to top Toxic0n is offline
Old Fri, Oct-29-2010, 06:29:21 PM   #17
k2e15
k2e15's Avatar
Reputation: 0 k2e15 is on a distinguished road
Cross my fingers, I'm replacing the alternator this afternoon, I hope that this solves the issue and the battery is pretty much brand new!
06' M Lovin every second of it!
2006 Silver Grey M3 Coupe
Jump to top k2e15 is offline
Old Fri, Oct-29-2010, 06:33:37 PM   #18
Itsablurr
Reputation: 0 Itsablurr is on a distinguished road
Exactly.
Where is the Voltage Regulator located on your car? That would be the next place to look.
2003.5 M3: BBS LM - TC Kline - Vorshlag - Borla
2001 S54 M Roadster: BBS Motorsport 3pc Magnesium - TC Kline - 3.73LSD - HMS Rollbar - Stromung
1967 Chevelle 2dr Coupe: Cragar S/S - Dynomax
Jump to top Itsablurr is online now
Old Fri, Oct-29-2010, 09:31:02 PM   #19
MY02M3DINAN
Originally Posted by Itsablurr View Post
Exactly.
The Voltage regulator is suppose to be located inside the alternator.
Anyone know if there is a relay or something else involved?
I checked the system again today, when the light is on, the alternator is not charging. I was lucky? enough that it came on and stayed on at start up.
Dinan S-M3 Kit
Auto Solutions SSK
Hawk HPS Brake Pads
CDV delete
V1 Hardwired
Old Fri, Oct-29-2010, 10:52:11 PM   #20
bmw loe
Reputation: 0 bmw loe will become famous soon enough
buy from www.alternatorpros.com
rebuilt units from Duralast (autozone) have issue's with the voltage regulators not being able to reliably spin to that high of an RPM. I had the same issue with Duralast brand, it's the alternator you put in there, nothing else.
-e92 335i 6MT Space Gray/Black M-sport, JB4 G5 ISO/DCI/CM Meth (CM10 nozzle)
12.612@114.74mph, 18psi on stock run-flat tires and plausible fuel pump codes sold
-e46 M3 6MT, sold
-e46 M3 SMG, sold
-E90 LCI M3 Interlagos Blue / Novillo Silver
Jump to top bmw loe is offline
Closed Thread
battery, high, light, revs, urgent
Battery light indicator on... Alt. or battery? Boostin FD E46 M3 (2001-2006) 25 Sun, Aug-31-2008 03:58:39 PM
Battery light on? zakattak20 E46 M3 (2001-2006) 11 Sat, Jan-27-2007 05:32:02 PM
battery light aznniche E46 M3 (2001-2006) 2 Mon, Nov-20-2006 09:11:44 PM
arghhh....battery light on again.....3 days after new battery carbonblackcab E46 M3 (2001-2006) 11 Mon, Sep-25-2006 12:48:53 PM
Battery Light on spars E46 M3 (2001-2006) 6 Mon, May-24-2004 01:00:55 AM
Discussing BATTERY LIGHT IS ON - what to do? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
