![]() Location: MASS
GUYS! after reading about this issue and NOT having it, i figured i was lucky enough to not have to deal with it... but it started, about 2 weeks ago, car doesnt always turn over on the first try when the engine is cold...
I might have found a fix, and its actually a quite simple one... Turn the key to position one, (you hear the fuel pump prime) let it prime to build pressure and simply turn the key, boom, no delay. It seems to occur only to me when i hop in, put the key in the ignition and immediately crank it over... so i mentioned it to my dad and he laughed at me, telling me to let the fuel pressure build first, then turn it over, and what do you know... started right up.. I dunno if this works for everyone, and i only discovered this today so im not even sure if its a "permanent fix" but it makes sense to me... try it out and lemme know if it works for you all as well cheers jason
![]() -- Jason My Garage: 2004 LSB M3 2006 IB M5 2006 IR 4.8is X5 2004 Z4 WEAREM///COLORED |
BAMF
![]() Location: North Dallas, TX
Yeah, this generally seems to be the only resolution (to the symptom, not the problem mind you). On occasion, i still get a little lugging after waiting for prime, thought it still only takes one start. It just sounds a little ugly. I still feel like i'm priming my $55k car like I prime my lawnmower.
MMM Lover
![]() Location: Fairfax, VA
Doesn't work. When I originally posted this over 1 year ago:
http://www.m3forum.net/m3forum/showt...light=starting I was given the same answer. I tried it for a bit and it seemed to work (purely coincedental). This has not worked this entire spring. I'm still experiencing the same type of problems...
-Bob ![]() - 2004 3.0 X5 Sterling Grey/Black - 2012 Audi A6 |
| Start of SUMMER LOLLICUP MEET!!! | playskool1 | Pacific | 13 | Tue, Jun-17-2008 11:37:35 PM |
| *Official Start Of Summer Meet*-6/23/07 | MysticDroptop | Northeast | 42 | Tue, Jul-10-2007 02:46:18 PM |
| Cold start problem and gas line antifreeze | marknoir | E46 M3 (2001-2006) | 7 | Thu, Jun-01-2006 06:42:03 PM |
| Cold Start problem vs. Race Gas? | masayahin | E46 M3 (2001-2006) | 3 | Thu, May-25-2006 09:29:02 AM |
| Help...hard to start my engine when cold | qqjohnny | E46 M3 (2001-2006) | 4 | Tue, Sep-23-2003 03:02:26 AM |
