Old Sun, Jun-26-2011, 08:40:16 PM   #31
magnetic1
Reputation: 0 magnetic1 is on a distinguished road
Default Re: Battery Light at High RPM
Originally Posted by Chaser720 View Post
For people looking to go used/rebuilt on these... IMHO dont. I tried to save a buck and it took me three rebuilt ones to get one that actually worked right. Not worth the hassle.
Even the ones you get from the dealer are reman units
Wonger
VIR Sloppy GTS3 Record 2:04.3
2012 NASA Nationals GTS3 First Loser
#121 GTS3 E46 M3 Build/Blog
2003 Avus Blue Individual M3 Street Mule
Jump to top magnetic1 is offline   Reply With Quote
Old Sun, Jun-26-2011, 11:33:59 PM   #32
MisterEm
MisterEm's Avatar
Reputation: 0 MisterEm is on a distinguished road
If you don't have an electrical rebuild shop nearby... get the OEM one from rmeuro:
http://www.rmeuropean.com/bmw-parts.aspx#Category
Same Bosch Alt. the stealer (and Tischer) charge $450 for.
Added bonus: California, Arizona and Nevada get free overnight delivery with GSO as well. Just type GSO shipping in the notes page.
Mike
p.s. My original alternator rebuilt at the local ma and pa shop electric rebuild shop (for less than $100 with tax) is nearing 50k miles.... The only thing unique about these M3 alternator units are the mounting holes. Same crap that goes on an old F150.
Jump to top MisterEm is offline   Reply With Quote
Old Mon, Jun-27-2011, 06:18:40 AM   #33
AW_IRed
Reputation: 0 AW_IRed is on a distinguished road
Ok. I just ordered Bosch alternator. Drove the car today, rev'ed it a few times all the way to 6k+ rpm, didnt see the battery light flash. Weird. It was almost always flashing when i hit 5k+ rpm a few days ago. any ideas? thoughts? TIA.
Jump to top AW_IRed is offline   Reply With Quote
Old Mon, Jun-27-2011, 07:11:13 PM   #34
Jeka///M3
Jeka///M3's Avatar
Reputation: 0 Jeka///M3 is on a distinguished road
Just had the same issue a couple of weeks ago. The light would come on at hi RPMs, and eventually just stayed on.
I got a used unit from my body for $180 and installed it the same day.
Our alternators are not the problem, it's the voltage regulators (which are a part of the assembly). there is a transistor that powers up the rotor (basically an electromagnet) of the alternator, and by varying the current to the rotor the stator output voltage gets regulated.
So the Alternator itself almost never goes bad, and any alternator you buy either from the dealler or any other place has a refurbished voltage regulator.
Jump to top Jeka///M3 is offline   Reply With Quote
Old Mon, Jun-27-2011, 07:31:56 PM   #35
magnetic1
Not entirely true. While that may be the case in some instances, it wasnt for me. I replaced the voltage regulator first and it didnt fix the problem. Replaced the alternator and all is well now. Keeping the new OEM voltage regulator in trailer though as backup.
Wonger
Old Thu, Jun-30-2011, 03:41:21 AM   #36
m3vert7590
Reputation: 0 m3vert7590 is on a distinguished road
this just happend to me and i replaced alternator and regulator... and a day later its happening again.. and its a brand new alternator and regulator.. my batter light flashes on past 4k rpms .. its only been 3 days since replace alternator
2003 m3 a/w on cinnamon vert fully loaded,
powerflex rtabs, rogue fcabs, zcp wheels, koni yellows,hnr springs, brembo gt kit front 355mm
2002 bmw e39 m5 (the BEAST) bilstein coilovers, fcabs.silver on two tone silver and black interior
2006 range rover sport fully loaded (white on beige)
2003 nissan 350z vortech supercharged, nismo lmgt4wheels ,brembo gt kit front 355mm
(400whp)
2007 honda civic lx
Jump to top m3vert7590 is offline   Reply With Quote
Old Thu, Jun-30-2011, 03:42:49 AM   #37
m3vert7590
now im completely pissed off
(400whp)
2007 honda civic lx
Old Thu, Jun-30-2011, 02:28:33 PM   #38
MisterEm
MisterEm's Avatar
Take your battery out and give it an overnight trickle charge from a proper battery charger. The alternator will not charge up the battery to full capacity by driving alone, if its charge state was diminished from a bunked alternator.
Old Thu, Jun-30-2011, 02:36:08 PM   #39
magnetic1
That too. There is a big warning tag on the Bosch reman alternators that state you must fully charge the battery before hooking up the alternator or else it could fail.
Wonger
Old Thu, Jun-30-2011, 04:12:56 PM   #40
AW_IRed
I used to only get battery light flashing when doing 5k+ revs. But now, battery light is on right on starting the car. Alternator and more stuff now??
battery, high, light, rpm
high rpm misfire Techno ///M3 E36 M3 (1992-1999) 9 Wed, Nov-28-2007 01:17:25 AM
flat spot at high RPM johnhk79 E46 M3 (2001-2006) 3 Tue, Nov-06-2007 05:58:00 AM
Battery Light Going On After 5k RPM craziex8 E46 M3 (2001-2006) 10 Sat, Jul-14-2007 10:55:13 PM
need a high res high rpm photo of a m3 tac LunaticDriver Off Topic 26 Thu, Apr-14-2005 02:26:21 PM
At high rpm car won't go into 3rd. SOURCE1064 E46 M3 (2001-2006) 38 Mon, Mar-07-2005 02:27:24 PM
Discussing Battery Light at High RPM in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
