Closed Thread
Old Tue, Aug-07-2007, 09:01:22 PM   #1
koss_22
Reputation: 0 koss_22 is on a distinguished road
Default ignition coil recall number ?
as the title states does any body know the recall number or anything i can tie this service bulletin to thanks
Jump to top koss_22 is offline
Old Tue, Aug-07-2007, 09:10:36 PM   #2
ZeroG
ZeroG's Avatar
Reputation: 0 ZeroG is on a distinguished road
It was never and official recall. It was just an SB. If a dealer were to encounter a car with the issue they would replace the Bremi Coils Out of good will.
If you do some searching, I think someone posted up the actually SB.
INDIVIDUAL BMW: '04 LEMANS BLUE VERT, LT ECRU INTERIOR, FULLY LOADED, EURO FOLDING MIRRORS, 6000K XENON FOGS, BBS CHs, RPI SCOOPS, and K&N PANEL.
BMW Special Tools: RTAB, FCAB, Shim Kit & Tool, Cam Holder, and Flywheel Lock
Jump to top ZeroG is offline
Old Tue, Aug-07-2007, 09:15:18 PM   #3
koss_22
yeah the problem is that they are refusing to acknoledge the SB and not to fix my car but my buddy was in there a week earlier with the same year car and it was covered
Old Tue, Aug-07-2007, 09:18:16 PM   #4
ZeroG
ZeroG's Avatar
That sucks... You might be able to try another dealer. I do know that the SB only covered certain years, so maybe that has something to do with it. I know when my were replaced the year was not in the SB, but they dealer did it anyway.
Old Tue, Aug-07-2007, 09:39:40 PM   #5
koss_22
yeah finally bmw canada agreed to cover it and do the sparkplugs. thanks for the replies mods please close
Old Tue, Aug-07-2007, 09:41:39 PM   #6
lmtfi
lmtfi's Avatar
Here is the SB text:
"SI B 12 24 05
Engine Electrical SystemsFebruary 2006
Technical Service
This Service Information Bulletin replaces S.I. B12 02 04 dated March 2005.
SUBJECT
S54B32- Special Limited Ignition Coils Warranty of 8 Years/Unlimited Miles
MODEL
MY '01, '02, '03 E46 - M3 coupe/convertible with S54 engine
MY '01, '02 E36/7 - M roadster/coupe with S54 engine
SITUATION
BMW has become aware of a potential problem that could affect the durability of Bremi ignition coils of certain MY' 2001, 2002, and 2003 BMW automobiles equipped with the Motorsport S54B32 engines. We estimate that only a small percentage of vehicles will actually develop a problem. Affected vehicles may have a Service Engine Soon light illuminated with misfire faults stored in the Engine Control Module (DME) and a rough running complaint.
CORRECTION
In the event that the Bremi ignition coils of a 2001, 2002, 2003 E46 (M3 coupe/convertible), or 2001, 2002 E36/7 (M roadster, M coupe) with S54B32 engine exhibit the symptoms of failure indicated above, they should be replaced with the improved ERA part (PN 12 13 7 551 260). For ignition coils replacing instruction refer to RA 12 13 511 found in BMW TIS.
PARTS INFORMATION
Part Number
Description
Quantity
12 13 7 551 260
ERA coil
Max 6
WARRANTY INFORMATION
As a commitment to our customers, and to demonstrate our confidence in our product, BMW will extend the warranty of the Bremi ignition coils from 4 years or 50,000 miles to 8 years and unlimited miles.
The warranty extension for this component applies to the above listed models only and is transferable to any subsequent purchaser of these models.
This extended warranty is applicable to vehicles registered in all 50 states.
Warranty coverage for all other parts is not affected.
BMW will inform all affected owners of the above listed models of their extended Bremi ignition coils warranty. A sample letter is attached.
The following Warranty Information should be used if Bremi ignition coils replacement becomes necessary as outlined above:
Defect Code
12 13 93 14 00
Replace Bremi ignition coils. Includes deleting any
misfire fault codes stored in the Engine Control
Module (ECM/DME)
Main Work
Labor Operation:
Labor Allowance:
00 54 124
11 FRU - E46 M3 with S54
8 FRU E36/7 M roadster/coupe with S54
+Associated Work
Labor Operation:
Labor Allowance:
00 54 692
9 FRU E46 M3 with S54
6 FRU E36/7 M roadster/coupe with S54
Note: The following explanations spell out the correct use of the work times.
Main Work:
Use this labor operation number when the only repair performed is the listed warranty repair.
OR
+Associated Work:
Use this labor operation number when other repairs or services are performed along with the listed warranty repair.
Under no circumstances should both labor operation numbers be claimed. Attempts to claim both times will result in an unnecessary delay in claim processing and payment."
Jump to top lmtfi is offline
Old Tue, Aug-07-2007, 09:42:41 PM   #7
lmtfi
lmtfi's Avatar
I will note that I am aware of a 2006 M3 that had all coils replaced under this SB when one of them failed.
Old Tue, Dec-25-2007, 04:54:24 AM   #8
TiAG///M3
Reputation: 0 TiAG///M3 is on a distinguished road
Damn do I love this forum, exactly what I was looking for. Got a 2002 that threw a SES light and read misfire in cylinder 1. Looks like i'll be sched an appointment with my local bmw dealership!
2002 TiAG M3**GC coilovers**Gruppe M CF Intake**AC Schnitzer rear strut brace, pedals, shift knob and e-brake**BBS LMs**RE Rasp Pipe**Smoke LED Tails, corners, sides**Hamman replica brake duct covers**Matte black kidneys and side gills**
Jump to top TiAG///M3 is offline
Old Tue, Dec-25-2007, 07:48:33 PM   #9
deilenberger
deilenberger's Avatar
And I think I'll stickie this.
  • 2011 Lexus RX-350. SWMBO's toy.
Jump to top deilenberger is offline
Old Mon, Mar-01-2010, 08:17:20 PM   #10
deilenberger
Here are some "original" documents, you can print and hand to the dealer when they claim ignorance..
Closed Thread
coil, ignition, number, recall
Ignition Coil Recall mah_hai E46 M3 (2001-2006) 22 Wed, Dec-09-2009 04:34:43 AM
Help! Ignition coil recall REJECTED! nv_khris E46 M3 (2001-2006) 65 Fri, Oct-16-2009 08:38:04 AM
ignition coil went out at 3k MaNaWaR E46 M3 (2001-2006) 40 Wed, Oct-07-2009 07:33:13 AM
ignition coil service... should i get anything else done? wolfbeast E46 M3 (2001-2006) 0 Mon, Mar-24-2008 05:56:53 PM
Bad ignition coil bigneil E36 M3 (1992-1999) 5 Thu, Oct-06-2005 01:19:47 PM
Discussing ignition coil recall number ? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
