Old Fri, Oct-19-2007, 12:53:40 PM   #1
MI6
Reputation: 0 MI6 is on a distinguished road
Default TCU's and ULF's
do our cars have both, or is it one or the other? I have an iPhone and have read that for optimal handsfree use, that an upgrade to a 13th generation ULF is needed.
Jump to top MI6 is offline   Reply With Quote
Old Fri, Oct-19-2007, 02:41:52 PM   #2
Need4Spd
Need4Spd's Avatar
Reputation: 0 Need4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond repute
Others can correct me if I'm wrong but I believe it's one or the other. If you have BMW Assist, you have the TCU (b/c it has built-in cell phone circuitry so that it can dial out to Assist). If only Bluetooth, then the ULF. If none, then by all means get the ULF. Martin at Bimmernav.com will probably be able to answer all your questions and probably has the info you need on his site.
Past car: '05 M3 'vert, 6MT, custom 18" RAC RG63 Hyperblack monolites, Continental Extreme DW 245/40 and 275/35, Nav, HK, BT, Euro rotors, Custom Performance Rasp Terminator (2nd Gen.), Silverline DICE iPod adapter, EAS Aurora 60 LED Angel Eyes, "-CDV," "free & easy" camber mod (-1.7 degrees), Koni S/A shocks, Rogue Engineering RSMs and transmission mounts, Bimmerworld silicone intake boot, spacesaver spare from LeatherZ, updated OEM RTABS
'11 Jaguar XFR
Jump to top Need4Spd is offline   Reply With Quote
Old Fri, Oct-19-2007, 09:43:52 PM   #3
M3prof
M3prof's Avatar
Reputation: 0 M3prof is on a distinguished road
TCU: Installed by the factory. For 2004 and earlier cars the TCU only had Assist and no bluetooth. To add Bluetooth to a 2004 and earlier car you pull the TCU (and loose Assist) and swap in a ULF, add a bluetooth antenna and pairing button. The ULF was only an dealer installed accessory, never installed by the factory. For 2005 and 2006 E46 cars if you ordered Assist, the factory installed a TCU that included bluetooth.
Notes:
TCUs are made by Motorola and ULFs are made by Visteon.
ULFs require a pairing button, TCUs do not.
There were some 2004 cars that came with documentation from the factory that they had bluetooth but the TCU actually did not have it.
The ULF can be retrofitted to cars that did not have Assist (see EAS or BimmerNav).
For some later model non-bluetooth cars (2004?) you can install at TCU rather than a ULF, but TCUs are relatively expensive (if buying from a dealer).
There are 13 versions of the ULF, apparently only the 13th version works with the iPhone. The 1st generation (sold by most US BMW dealers) was notoriously buggy and worked with very few phones. Later models worked with many phones (except of course, the iPhone). I don't know about compatibility of TCUs with the iPhone.
There are both GSM and CDMA TCUs. I believe on the CDMA TCUs work in the US. The GSM ones are for Europe, though there are people selling them in the US on ebay, be careful, I don't think you can even get the bluetooth part of the GSM TCUs to work in the US.
TCUs (except early 2005 ones) include voice controlled dialing. ULFs have voice controlled dialing and voice controlled navigation commands.
TCUs
Description Qty From Up To Part Number Comments
TELEMATICS CONTROL UNIT CDMA Oct-03 84116938764 has Assist only; no BT?
TELEMATICS CONTROL UNIT CDMA Dec-03 84116945062 has Assist only; no BT?
TELEMATICS CONTROL UNIT CDMA Mar-04 84116947308 confirmed has Assist only; no BT
RMFD TELEMATICS CONTROL UNIT CDMA Mar-04 84116949110
RMFD TELEMATICS CONTROL UNIT CDMA Mar-04 84106978527
RMFD TELEMATICS CONTROL UNIT CDMA Mar-04 84109123190
TELEMATICS CONTROL UNIT CDMA Mar-04 Apr-04 84116945940
TELEMATICS CONTROL UNIT CDMA Mar-04 Sep-04 84116952218
RMFD TELEMATICS CONTROL UNIT CDMA Mar-04 Sep-04 84106978528
RMFD TELEMATICS CONTROL UNIT CDMA Mar-04 Sep-04 84109123191
RMFD TELEMATICS CONTROL UNIT CDMA Sep-04 Mar-05 84106978529
RMFD TELEMATICS CONTROL UNIT CDMA Sep-04 Mar-05 84109120844 SW:32 HW:35
TELEMATICS CONTROL UNIT CDMA 84116946993 1st Generation (does not have SES Voice Recognition built-in. Requires separate module)
TELEMATICS CONTROL UNIT CDMA Mar-05 May-05 84106964114 2nd Generation (Voice input for phone included)
TELEMATICS CONTROL UNIT CDMA Mar-05 Sep-05 84106965056 3rd Generation (Voice input for phone included)
TELEMATICS CONTROL UNIT CDMA Sep-05 Apr-06 84106963798 Motorola TCU production date 14.07.2006
TELEMATICS CONTROL UNIT CDMA Sep-05 May-06 84109120843
RMFD TELEMATICS CONTROL UNIT CDMA Sep-05 Jul-06 84109122529
RMFD TELEMATICS CONTROL UNIT CDMA Sep-05 Sep-06 84109132711
TELEMATICS CONTROL UNIT CDMA Sep-06 84109115729
Visteon ULF Modules with Bluetooth only; no Assist
Visteon ULF Module end of life Jun-07 84216934552 1st generation
Visteon ULF Module end of life Oct-07 84216938610 2nd generation
Visteon ULF Module end of life Mar-07 84216934961 3rd generation
Visteon ULF Module end of life Jun-07 84216950089 4th generation
Visteon ULF Module end of life Jan-07 84216945387 5th generation
Visteon ULF Module end of life Oct-07 84106955522 6th generation
Visteon ULF Module end of life Apr-07 84106969268 7th generation
Visteon ULF Module end of life May-07 84216958358 8th generation
Visteon ULF Module end of life Sep-07 84106987546 9th generation
Visteon ULF Module end of life Nov-07 84106980130 10th generation
Visteon ULF Module end of life Jan-07 84109133329 11th generation
Visteon ULF Module end of life May-07 84109145007 12th generation
Visteon ULF Module Current production 84109154358 13th generation
European TCUs
TELEMATICS CONTROL UNIT GSM Jan-05 84116946991
TELEMATICS CONTROL UNIT GSM Mar-05 84106965055
TELEMATICS CONTROL UNIT GSM Sep-05 84106964113
TELEMATICS CONTROL UNIT GSM Jul-06 84106963758
TELEMATICS CONTROL UNIT GSM Nov-06 84109129850
TELEMATICS CONTROL UNIT GSM Mar-07 84109127894
TELEMATICS CONTROL UNIT GSM 84116946011
TELEMATICS CONTROL UNIT RFMD GSM 84106978533
Jump to top M3prof is offline   Reply With Quote
Old Sat, Oct-20-2007, 04:29:57 AM   #4
itsme
itsme's Avatar
Reputation: 0 itsme is on a distinguished road
China
Notes:
You're good
-Wing
2002.5 Stl Grey M3 SMG II
Jump to top itsme is offline   Reply With Quote
Old Wed, Nov-14-2007, 03:45:39 AM   #5
marcelji
Reputation: 0 marcelji is on a distinguished road
Default bluetooth in a 2004 M3 with Assist
I have a 2004 M3 with Assist, navigation, and pre-wiring for cell phone. If I want bluetooth capabilities, do you think my best option is to get the Bimmernav kit for $695? It sounds kind of expensive for what it is. Has anyone tried this kit? Will the system really be able to accept voice commands for dialing and so on? I would probably stay away from the eject kit just because it is fitted for individual phones. Phones change too often to deal with this.
Jump to top marcelji is offline   Reply With Quote
Old Wed, Nov-14-2007, 05:19:03 AM   #6
maddog2020
Reputation: 0 maddog2020 is on a distinguished road
That's what I did, but I went with Tom@EAS. I am very happy with the switch, all the voice commands work well, it works just fine with the iPhone - but be aware that the iPhone sends names with the number type, e.g. (mobile), or (home) so the caller ID display is a bit useless.
The install is very easy, it took me about half an hour to get it all done.
Ian
Jump to top maddog2020 is offline   Reply With Quote
Old Wed, Nov-14-2007, 06:36:52 AM   #7
YseanY
YseanY's Avatar
Reputation: 0 YseanY is on a distinguished road
Taiwan
has anyone tried the new generation 13 ulf with nokia n series? particularly the n95
GONE
2004 ///M3 6 SPEED - CARBON BLACK | BLACK NAPPA LEATHER | NAVIGATION | PREMIUM PACKAGE
ENGINE | Rogue Engineering Street Pulleys
DRIVETRAIN | OEM BMW Motosport 4.10 Differential | Rogue Engineering Custom SSK | Rogue Engineering Weighted Selector Rod | Rogue Engineering Transmission Mounts | GSP Clutch Pedal | CDV Removal
EXHAUST | OEM CSL Headers | Larini GT Sports Cats | Larini Section 2 | Rogue Engineering El Diablo Ti Tips
SUSPENSION | TC Kline Racing 500F/500R S/A Coilover | Eibach Front/Rear Sway Bars | Powerflex RTAB
BRAKES | Giallo Midas Brembo GT 355MM 6-Piston Monoblock Front BBK | Brembo GT 345MM 4-Piston Monoblock Rear BBK
WHEELS/TIRES | RACMonolites RG4 | Vredestein 275/30/19 and 265/30/19
EXTERIOR | OEM CSL Roof | OEM CSL Bootlid | OEM CSL Bumper | OEM CSL Diffusor | 28% Tint | 6000K Predator Chromiums | LED Turn Signals
INTERIOR | Hardwired Valentine 1 | Illuminated ///M3 Door Sills
Jump to top YseanY is offline   Reply With Quote
Old Thu, Nov-15-2007, 09:26:48 PM   #8
marcelji
Default EAS bluetooth
Thanks Ian! Do you know the part number of what you bought from EAS? Do you know if there is any difference from Bimmernav?
Old Thu, Nov-15-2007, 09:30:15 PM   #9
tom @ eas
tom @ eas's Avatar
Reputation: 0 tom @ eas is on a distinguished road
The 13th Gen ULF has specific iPhone compatibility, but if someone is in the SoCal area with a n95 - we'll be happy to pair up the phone and find out for others on the forum.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG FACEBOOK YOUTUBE FLICKR INSTAGRAM
Jump to top tom @ eas is offline   Reply With Quote
Old Thu, Nov-15-2007, 10:03:42 PM   #10
maddog2020
There is just the module: http://www.europeanautosource.com/pr...5c2bbf71b383b1
Or a full upgrade kit with all the other bits and pieces (I bought the full kit): http://www.europeanautosource.com/pr...5c2bbf71b383b1
Ian
Euro Bluetooth TCU's? tripower E46 M3 (2001-2006) 2 Wed, Nov-08-2006 11:18:32 AM
A heads up on bad Bluetooth TCU's efc1878 E46 M3 (2001-2006) 7 Thu, Oct-26-2006 12:49:27 AM
Discussing TCU's and ULF's in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
