Old Tue, Nov-13-2007, 03:26:27 AM   #11
Feffman
Feffman's Avatar
Reputation: 0 Feffman is on a distinguished road
Elf HTX (www.Elfoils.US) brake fluid. Works great.
Feff
MVP Track Time
Jump to top Feffman is offline   Reply With Quote
Old Tue, Nov-13-2007, 11:46:56 AM   #12
THEHOUNDER
Old Guy with M3
THEHOUNDER's Avatar
Reputation: 0 THEHOUNDER is on a distinguished road
Originally Posted by Nick325xiT 5spd View Post
SuperBlue can be a warranty problem. (It happened to me.)
I've always been amazed by that...not only does my dealer offer to use super-blue, the braking system is made by ATE, the maker of super blue/gold.
2004 Silbergrau SMG/ FLMS "half cage"/ V-CSL Roof/Works Bell SMG/ Fabspeed Headers/ Epic tune/ BW 3.5"/Cobra Sebring (d) - Suzuka (p)/Brembo 355/345 / GSP Gen 1 Pedal /Moton CS / Ground Control Race Bars / AIM Solo DL /Other junk and stuff
2012 Mercedes GL450 - Tow pig
2010 Featherlite 17'6" open
2008 335xi -stock
Jump to top THEHOUNDER is offline   Reply With Quote
Old Tue, Nov-13-2007, 03:25:51 PM   #13
elbert
I brake for tailgaters
Reputation: 0 elbert has disabled reputation
Wales
ProSpeed GS610
It costs about the same as Motul RBF600, but IMO it gives a slightly firmer brake pedal (it could be my imagination though)
I flush every couple months, more as a precaution than actual need
Jump to top elbert is offline   Reply With Quote
Old Tue, Nov-13-2007, 04:10:08 PM   #14
OLOAM3
OLOAM3's Avatar
Reputation: 0 OLOAM3 is on a distinguished road
Originally Posted by M3-peat View Post
I'm getting sick of bleeding before every event and always worrying about my fluid.
I use Pentosin Racing Brake Fluid now, cheap($15/liter) and decent boiling points(572 d/393 w) but I have to bleed before every event and sometimes during the event.
I'm considering Castrol SRF and be done for a year, from what I hear anyway.
The track I goto most frequently is pretty hard on brakes which generally calls for a bleed everytime.
Interesting, I run ATE in my E46 M3 and only bleed when I change pads, and have never had a fade issue. I will admit I am lighter, app 3000#'s and do have Brake ducts for cooling on the front. It sounds like cooling might be the big issue, not the fluid.
Peter
1995 M3 NASA TTC CDTC Cheap Disposable Track Car
2004 6GT3 Stock for now.
Jump to top OLOAM3 is offline   Reply With Quote
Old Tue, Nov-13-2007, 05:24:02 PM   #15
Ogi
Reputation: 0 Ogi will become famous soon enough
Bulgaria
I never bleed my brakes, I only flush them, and I usually do it every 3-4 events (weekends).
I switch between ATE Super Blue and the gold stuff (if you already have the blue stuff in and flush in new blue fluid how can you tell when the old fluid stops coming out of the line and the new fluid begins?).
I haven't had the need for the really high end stuff. I'm running stock size rotors with PFC-01 pads at the track on a R-compound tire. Over the course of the weekend, my brake pedal will hold the same firmness (I also have stainless steel brake lines).
The warranty issue w/ ATE should not be an issue at all. The owners guide says to use DOT 3/4 brake fluid. If someone gives you lip about it at the dealership, show them what the owners manual says, and then show them the bottle of the stuff. It should be a moot point.
Ogi
Originally Posted by CAG View Post
Ogi I have to give you credit, you have swayed my opinion...
Jump to top Ogi is offline   Reply With Quote
Old Tue, Nov-13-2007, 06:02:25 PM   #16
nrubenstein
Some dealers are more full of **** than others. This dealer diagnosed a friend's bad head gasket as bent valves from a money shift and kindly offered to replace his engine for $12K. (E36 M3)
What really pissed me off was that they went ahead and branded my service record. It's one thing to say no, it's another to go out of your way like that.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison
2002 BMW M3 Alpinweiß/Black - JBL MS-62C, IDQ-12v3, JBL MS-8
1989 325is Alpinweiß/Black - S50B30, GC/Koni, Sways, BBS RX, Hybrid C61-2, Sundown SA-12, JBL MS-8
1989 M3 Alpinweiß/Black - S50B32. 321hp.
Hers: 1996 Porsche 911 Turbo Black/Black
Hers: 1988 325iX Coupe Diamondschwartz/Black 5spd - Korman lengthened front driveshaft, Cam, Bilstein, H&R Sport, snow chains.
Jump to top nrubenstein is online now   Reply With Quote
Old Tue, Nov-13-2007, 06:41:09 PM   #17
Greg S
How fast do you want to go?
Reputation: 0 Greg S is on a distinguished road
IIRC superblue isn't DOT approved, only because it's blue though. I think it says it's DOT 4 equivalent or something like that.
-Greg S
Jump to top Greg S is offline   Reply With Quote
Old Tue, Nov-13-2007, 06:52:31 PM   #18
nrubenstein
The question is whether or not you give a **** enough to actually escalate it. It wasn't worth my time to do so.
Old Tue, Nov-13-2007, 07:03:26 PM   #19
Ogi
Bulgaria
I always find it worth my time to make sure I get the proper service from the service department. If they are going after blue brake fluid, they will go after anything. It is my right to modify my vehicle the way I choose, and as long as I meet the standards set my the manufacturer, you better believe I'm going to expect I receive the proper service. I'm not afraid to bump heads with a service department.
On the other hand, I live in the bay area, and I have plenty of service departments to choose from.
Ogi
Old Tue, Nov-13-2007, 08:29:02 PM   #20
M3-peat
Slow in fast out
M3-peat's Avatar
Reputation: 0 M3-peat is on a distinguished road
Peter
both your weight and cooling are helping you a lot. I've considering cooling but don't know enough about which one to get. It's really only Sebring that really kills my brakes, haven't had the same problems elsewhere(RA and VIR).
Clint
2012 Alpine Wht E92 M3 DCT ZCP
2003 Topazblau 6MT (Past)
Mods: stuff
Jump to top M3-peat is offline   Reply With Quote
bleed, brake, fluid, junkies, track
Track junkies - opinions about using spacers on track Got_S54? M3 Track: Racing and DE 17 Sat, Mar-24-2007 08:42:40 PM
Track: Brake Fluid, Pads & Oil jdb E46 M3 (2001-2006) 5 Tue, Apr-20-2004 07:31:09 PM
Question for track junkies BarryB E46 M3 (2001-2006) 32 Sat, Apr-17-2004 08:55:44 PM
brake bleed? cathu2 E36 M3 (1992-1999) 3 Thu, Apr-17-2003 01:40:22 AM
Brake pads & fluid for track days kster E46 M3 (2001-2006) 0 Thu, Nov-14-2002 05:07:29 AM
Discussing Track Junkies: Which brake fluid do you use and how often do you bleed? in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
