This is a FAQ - to answer the frequently asked questions by people who just bought an E46/M3 - or people who are considering buying one. In some cases - it will refer to other Stickies or FAQs.
QUESTION - I'm thinking of buying an M3 - what is the best year? And what should I look out for. ANSWER - (DonE) That isn't easy to answer. They're ALL good! There weren't any real fatal flaws in the M3 from when it was introduced. A few years had some potential bearing problems that were addressed by a RECALL from BMW. See the "Bearing Recall" question for more info. In general - condition and maintenance are more important than the year of the M3. A low miles '01 that has been maintained by a fanatic, and not driven hard will be a better car than a newer one that has high mies, was driven hard and put away wet.QUESTION - I'm thinking of buying an M3 - but I can't afford one still in warranty - what should I do? ANSWER - (DonE) Lots of people will suggest you only buy an M3 that is still within warranty. That viewpoint seems rather odd since that would make their car unsaleable once it was out of warranty. There are aftermarket warranties available - usually only at time of purchase. Some of the best might be available from your lending institution if you're borrowing from a Credit Union. Others are usually available from a dealer - even used car dealers, but consider that there is usually a 100% markup on these (if it costs you $2,000, the dealer is pocketing $1,000) - so dickering on the price is very doable.QUESTION: I've heard about a "bearing recall" - what's that all about and should I avoid those cars? ANSWER - (DonE) The bearing recall was a response by BMW to some engine failures on early M3 engines. The range of cars is from late '01 cars to early '03 cars.QUESTION - The seller claims the car has a 100k BMW warranty - what's the story? ANSWER - (DonE) - There are several different things the seller could be referring to. One might be the 100k/6-year ENGINE warranty that covers oil lubricated parts. This is only applicable on 2001-2003 cars. They might also be referring to the BMW "CPO" warranty - see: http://www.m3forum.net/m3forum/showthread.php?t=153882 for information on the BMW CPO warranty, extended BMW warranty, extended BMW maintenance and aftermarket warranties.QUESTION: - What's the story with oil for the M3? ANSWER - (DonE) - There is only ONE oil approved by BMW for the M3 - It is "CASTROL TWS 10W-60" (Think Ten W Sixty to remember TWS.) The oil is made specifically for BMW engines, and is specified for the S54 engine, and some year M5 series engines. Considering the "special" oil, it's suprisingly reasonable when bought with a BMW-Car Club of America discount - in the $7-8/liter range. The engine uses 5.5 liters - buy 6 bottles for an oil change. It's available from BMW, and some independent vendors who sell BMW parts.QUESTION - What's that "Sport" button do? Do I get more power? ANSWER - (DonE) - Not much actually. It gives you NO MORE POWER. It won't make the car go faster. What it does is changes the response of the electronic throttle on the engine making it respond more to less pedal movement, but 100% is still 100% - and that's all the throttle available "sport" or no "sport". You may find the car more difficult to drive smoothly with the sport button pressed - but some people seem to like that - so it's up to you what you do with it.QUESTION - How do I know if the car has original paint or not? ANSWER - (bCaHnIaCnKa) - Very few shops are good enough to actually repaint a car correctly or match it very close to OEM so you can't tell if a part has been repainted. Spotting repaint can give a clue about the car possibly being in an accident or have been damaged that hasn't been reported to CARFAX.Questions suggested by RBC44 (Ben): QUESTION - Is this a good price? (year, equipment, mods) ANSWER - (DonE) - This question is asked all the time - and usually answered by people claiming either: it's WAY too much for the car; or that they bought a car for less. The real answer is - the car is only worth what someone will pay for it. To figure out if the car is within reason - go to sources like Kelly-Blue-Book (www.kbb.com), Edmunds (www.edmunds.com) and NADA (www.nada.com) - all of these offer price guides. Looking for completed auctions on Ebay can also give you an idea of what cars/years/miles/mods bring what prices.QUESTION - What to look out for (recalls, sibs, etc.) when buying an M3? ANSWER - (DonE) - Your first step here is to have a friend at a dealership - or have a PPI done (see above.) The dealer can pull up a car's warranty/recall repair information on their computer - even if they didn't sell the car. That is valuable information, and will give you some idea if the car was maintained - at least during the free maintenance period. You want to make sure the engine-bearing recall was done if the car falls under that group of VIN#'s.QUESTION - What are Inspection I and II? ANSWER - (DonE) - "Inspection" services are exactly what the name describes. These are major services where many components on the car are "inspected" by the technician doing the job, looking for any problems or worn parts. The two services include different things - with "II" being the bigger (and more expensive) of the two. Depending on where you're located - Inspection services will range from $500 for an Inspection-I, to $1500 for an Inspection-II. BOTH inspections include doing a "valve adjustment" - this is not optional, it's not done by them listening to the engine - it has to be done and will require from 3-6 hours of labor time.QUESTION - What are the differences in model years? ANSWER - (DonE) - http://m3.madrussian.net/modelinfo.shtml for everything you need to know..QUESTION - Are there any DIY sources? ANSWER - (DonE)QUESTION - What are all these abreviations people use (ssk, bbk, cai, etc.)? ANSWER - (FM3)QUESTION - HELP! My check-engine-light just came on, what's wrong? ANSWER - (DonE) - The honest answer - we don't know what's wrong. Forum members can take potshot guesses at what they might think is wrong based on their experiences.. but without reading the fault codes - it's just guesses. What you should do is get the codes read. Most large chain autoparts places (AutoZone, PepBoys, etc) will loan you a code reader in the hopes when you find the problem you'll buy the parts to fix it from them. These code readers will read the OBD-II codes (emissions related P0001-P0999) and perhaps some of the BMW proprietary engine management codes (P1000-P1999). It will tell you what the standard OBD-II codes mean - the BMW specific ones you'll have to lookup on the web. You also could visit a dealer (figure $100+ to read the codes) or a good independent who specializes in BMWs.QUESTION - I'm thinking of buying an M3 - but what's that noise in the exhaust system around 2,500-3,700 RPM? ANSWER - (DonE) - That noise is normal. Listen to a Ferrari at full tilt - same sort of noise. It's called "the rasp" - and is caused by the design of the headers and first exhaust section on US cars. US cars have the catalytic converters as part of the exhaust headers.. the first exhaust section has different designs for the two legs of the exhaust. All of this creates the "rasp". It's normal - but can be eliminated if you want to spend some money. There are various vendors who sell front exhaust sections that help eliminate it.QUESTION - Some cars I'm seeing for sale say "SMG" - What's SMG mean? (Thanks to xASAPx for the question!) ANSWER - (DonE) - SMG is BMW's version of a Formula-1 transmission, where shifting of a manual transmission is done under computer control and the clutch and engine speed matching is also controlled by the computer. SMG stands for "Sequential Manual Gearbox". For more info see: http://auto.howstuffworks.com/sequential-gearbox.htm,QUESTION - I'm looking at an M3 - where can I get the service records from the prior owner(s) ANSWER - (DonE) That depends. A dealer can call up BMW's computers - where any warranty (+CPO) or free-maintenance services records will be recorded. Normally they'll only do this for the current owner of the car, or as part of a PPI (see above!), but sometimes if approached right, they might do it for you as a favor. Out of warranty/free-maintenance records are normally only kept on the computer of the servicing dealer - if the car was dealer serviced. These are lots harder to get - usually requiring you to contact the former owner and ask that they contact the dealer and give permission in writing for you to see/obtain these records. If the former owner(s) used independent shops - chances are - you're not going to get the service records unless they came with the car.QUESTION - My keys don't lock or unlock the car ANSWER - (DonE) First make sure you're within range - which on the E36/M3 (especially the convertibles) is really a short distance. About 10 feet isn't an unusual max range. You can improve on the range by touching the metal key tip to your chin (really - it works, try it..) This sort of becomes 2nd nature after a while, even if you do look to the world like a complete idiot.QUESTION - What's this subframe thing I've heard about? ANSWER - (DonE) The "subframe issue" really isn't an issue with the rear subframe (which is a framework that holds the differential in the rear of the car, and some suspension components mount to) - It's an issue with the part of the car's body that the subframe mounts to.QUESTION - The "clown-nose" (round red thing under the rear-view mirror) blinks when the car is locked, does that mean I have an alarm?. ANSWER - (DonE) Probably not if you don't get a chirp when you lock and unlock the car.QUESTION - Hey - this morning my car beeped at me, and my display is showing a blinking temperature. What's up with that? ANSWER - (DonE)It's BMW's temperature nanny telling you the roads may be cold enough for black ice. At temps below 37F - the display will flash and one beep will sound. Once it does it - it doesn't do it again, unless you drive through temperature gradients that pass through 37F. It will do it again if you stop and then start the car.QUESTION - Is there any service info on the SMG available on-line? ANSWER - (DonE) Yes there is.. see http://jasoncampagna.com/SMG.pdf (thanks to FastDog911 for the link..) Back on line! Thanks FFWD!OFFLINE when checked 11/15/11. Please PM me if it goes back on-line. QUESTION - Recommended parts sources (realoem etc.)? ANSWER - (GoSlow2GoFast) - Sure are: Last edited by deilenberger; Wed, Nov-16-2011 at 12:17:58 AM. |
Folks - any contributions of "Noobe Questions" or Answers is welcome, and will be added with attribution (meaning your name gets in the FAQ..) Please PM me with them.
CONTINUED.. (we ran out of space in the original posting..)
QUESTION - What's the difference between OEM and OE parts - how come OE is more money? ANSWER - (DonE) OEM = Original Equipment Manufacturer, OE = Original Equipment. QUESTION - What's the deal with the rearview mirror? I see a line in it.. (thanks to HerrSMiG for the suggestion!) ANSWER - (DonE) This isn't a good thing. It means the caustic fluid used in the mirror is leaking out. If it hasn't already - chances are excellent it will damage your console area.
| bought, buying, e46 or m3 |
| Just bought an 04 e46 m3/ need help | jnm555 | E46 M3 (2001-2006) | 6 | Mon, May-07-2012 02:12:25 PM |
| Just bought an E46 M3 LEMON! | turbo///M3 | E36 M3 (1992-1999) | 26 | Tue, Jun-29-2010 11:09:15 AM |
| Just bought a E46 M3 | The Real M3 | E46 M3 (2001-2006) | 17 | Wed, Oct-08-2008 04:31:38 AM |
| What is the first present you are buying or have bought for your M3? | vivid | E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013) | 20 | Tue, Feb-26-2008 08:21:03 AM |
| Just bought an e46 m3 | chuck5 | M3Forum Welcome Center | 4 | Tue, Dec-04-2007 04:51:18 PM |
