Old Sun, Dec-16-2007, 10:23:33 PM   #1
///m1ka
///m1ka's Avatar
Reputation: 0 ///m1ka is on a distinguished road
Location: Los Angeles, West Palm Beach, Chicago, Milwaukee
Default Replacing rear differential seal?
Has anyone replaced the seal between the drive shaft and the rear differential on an e46 M3?
Mine appears to be leaking approx 1 drop per day. I have searched but found limited info.
Does anyone have a DIY link that may assist me?
How hard was it to fix?
I do have a lift which will make the job much easier.
thanks
Jump to top ///m1ka is offline   Reply With Quote
Old Mon, Dec-17-2007, 12:18:13 AM   #2
JeST
Old Skool
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
It's pretty straight forward. Before removing the old seal measure how deep the seal is and use that as a guide when installing the new seal.
1. remove wheel on the axle that needs work. (you can get a little extra room by removing the 4 screws holding the rear sway bar)
2. Inverted torx socket needed (I think its a E11)
3. Remove axle (i used 2 pry bars on both sides and just wiggled it out)
4. To remove the original seal theres a special tool bmw says to use but you can use a prybar just as long as your prying it out within the seal and not the housing for the seal (look at the new seal theres a lip you can pry on)
5. install the new seal to the same depth the old seal was sitting.
If you need more detailed help I'll try and take pics the next time I replace one.
1988 M3 - Henna/black on black alcantara
2012 Ducati 848 Evo Corse
Jump to top JeST is offline   Reply With Quote
Old Mon, Dec-17-2007, 12:48:51 AM   #3
mredwin25
mredwin25's Avatar
Reputation: 0 mredwin25 is on a distinguished road
I think he's talking about the input shaft seal
Jump to top mredwin25 is offline   Reply With Quote
Old Mon, Dec-17-2007, 01:21:30 AM   #4
///m1ka
///m1ka's Avatar
Thats correct, the seal between driveshaft and rear differential.
Not the axle seal. Thanks anyways, I'm sure it will help someone.
Old Mon, Dec-17-2007, 01:53:21 AM   #5
m3keeper
Reputation: 0 m3keeper is on a distinguished road
Be careful not to change the pinion pre-load. The crush sleeve has already been positioned. Changing this could place added wear on the pinion bearings.
Jump to top m3keeper is offline   Reply With Quote
Old Mon, Dec-17-2007, 01:59:14 AM   #6
bmwbob
BlueHairMafia
bmwbob's Avatar
Reputation: 0 bmwbob has disabled reputation
St Vincent and the Grenadines
how would you accidentally change the preload by changing the seal... i am a novice on gears and axles.. etc...
Jan Obrien says tHe womeN in That group gossip about her (“One piece of gossip that went around was that we’d been evicted from our last apartment,” she says); spread lies about her; discourage other residents from befriending her and give her dirty looks whenever she tries to use community facilities, like the rec room.
Jump to top bmwbob is offline   Reply With Quote
Old Mon, Dec-17-2007, 02:28:49 AM   #7
mredwin25
mredwin25's Avatar
Well, I've never done it on the E46 but did it on my old E36 M3, here is how the crush sleeve work (E36), that sleeve is on the input shaft. That crush sleeve is what keeps the proper clearence between the input shaft and the bearing. Make sure that you retorque the center nut to proper torque specs, if accidentally you overtorque that nut you'll crush that sleeve therefore changing the clearance on the bearing and the shaft and you'll have no choice but to replace it with a new one, there is no going back. Mark the nut and the shaft to use it as reference when reinstalling everything. Clearance on that shaft is very crucial and if overtorqued it will destroy that bearing and also the gears, that's how important that crush sleeve is. Hope this helps and it's not too confusing.
Old Wed, Apr-21-2010, 04:07:15 AM   #8
jaciuro
When will they learn that the left lane is for passing only?
jaciuro's Avatar
Reputation: 0 jaciuro has a spectacular aura about
Puerto Rico
Has anyone come up with a DIY for this INPUT (driveshaft) seal replacement? I have searched for a while now with little luck.
E46 M3 and it isn't just one drop a day, it's more than that. I have the seal and crush sleeve, just wondering what to expect. I am pretty mechanically inclined, not a master by any means though....any insight from those with experience is appreciated! Thanks people!
2004 E46 M3 6-SPD Titanium Silver/Gray Leather
StopTech ST60/380mm, PowerFlex RTABs, Streamline Intake Tube & Filter
2005 Suzuki GSX-R 1000 Black/Yoshimura TRC (Stolen!)
2002 Subaru WRX Stage2+Sold
Jump to top jaciuro is offline   Reply With Quote
Old Wed, Apr-21-2010, 05:56:14 PM   #9
jcreme
Mechanical? Engineer?
jcreme's Avatar
Reputation: 0 jcreme has disabled reputation
I'm doing it this weekend. Based on my shop manual from Bentley Publishers, you need
  • An input shaft seal
  • An input flange lock plate (I'm betting this is optional - literallly )
  • 1.3L Castrol SAF XJ
No mention of the crush sleave, it says to mark the nut and input shaft to ensure it is in the exact same place on re-assmbly
Special tools required are
  • an inside seal puller
  • a spanner to hold the lock plate while you loosen/tighten the lock nut
  • An M10 Torx Socket for the lock plate bolts
The Castrol SAF XJ is $40-60 per liter at all sources I found. Does anyone have enough knowledge to say a replacement is ok? Even Royal Purple is only $15 per liter. Castrol shows this to be a 75W140 gear oil http://www.castrol.com/liveassets/bp...J_B1174_96.pdf
Jump to top jcreme is offline   Reply With Quote
Old Wed, Apr-21-2010, 06:06:32 PM   #10
.333 snubnose
.333 snubnose's Avatar
Reputation: 0 .333 snubnose is on a distinguished road
Following a service bulletin, most everyone will use the recommended (updated) gear oil with the friction modifier to prevent the LSD clutch grinding.
OEM fluid Castrol SAF-XJ + FM booster
BMW part# PN 83-22-2-282-583
...and yes, it's about $40 per liter
For Rent: RTAB tool (MIS), FCAB tool (MIS), Valve Shim Kit & Tool
For Sale: OE FCAB brackets (lollipops)
Jump to top .333 snubnose is offline   Reply With Quote
differential, rear, replacing, seal
Rear Window Seal MnkyBiz E36 M3 (1992-1999) 33 Fri, May-27-2011 03:44:45 PM
Rear Differential Seal alphakilo E46 M3 (2001-2006) 17 Mon, Jan-28-2008 07:59:50 PM
Good DIY link for replacing Differential Fluid? rockne E46 M3 (2001-2006) 0 Thu, Nov-29-2007 10:17:50 PM
replacing rear differential under warranty boostcrazy E46 M3 (2001-2006) 1 Thu, Oct-25-2007 07:47:33 PM
Replacing Rubber Window and Door Seal AMPowerJ E36 M3 (1992-1999) 6 Tue, May-24-2005 09:45:41 PM
Discussing Replacing rear differential seal? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
