Old Sun, Feb-24-2008, 06:32:50 AM   #1
derekw
Reputation: 0 derekw is on a distinguished road
Default OBDII to BMW 20-pin connector adapter?
I have a 99 M3, and I have a generic OBDII code reader (gets much more use on my Tahoe...). I hooked it up to the M3 today (to the connector near the pedals) to check an SRS light that came on, but I can only access codes and information related to the engine or transmission.
I did some checking, and the SRS code/reset tool that Peake sells connects to the 20-pin underhood connector (and apparently, for the cars with both the OBDII connector under the dash and the 20-pin underhood connector, you must use their tool with the 20-pin underhood connector to access the SRS codes or to reset the light).
Some vendors sell a OBDII connector-to-20-pin underhood connector adapter, which would allow me to hook the code reader I have to the underhood connector. Does anyone know if this will let me use my code reader tool to check the SRS codes?
Thanks
Jump to top derekw is offline   Reply With Quote
Old Sun, Feb-24-2008, 06:39:24 AM   #2
phantom3
Reputation: 0 phantom3 is on a distinguished road
http://www.peakeresearch.com/srstool.htm . Buy the SRS specific one (pick the adapter you want)
SOLD
Jump to top phantom3 is offline   Reply With Quote
Old Sun, Feb-24-2008, 08:26:34 PM   #3
derekw
Thanks, but I'm just hoping I can get away with a $15 adapter instead of a $130 tool
Old Tue, Feb-26-2008, 01:00:44 AM   #4
derekw
Any other thoughts?
Old Sun, Mar-09-2008, 05:02:18 AM   #5
intravino
Reputation: 0 intravino is on a distinguished road
Default Cable, BMW 20M to J1962F, 1ft
These people sell a Cable, BMW 20M to J1962F, 1ft for $ 25.00 bucks plus shipping. It is not on their website yet becaue it is a new product:
http://www.carplugs.com/
Ask them by email before and they will sell you this cable.
Check on their website the contact email address.
I forgot it,
Intravino
Jump to top intravino is offline   Reply With Quote
Old Sun, Mar-09-2008, 04:11:58 PM   #6
PhYrE
Mmmmm-3
PhYrE's Avatar
Reputation: 0 PhYrE is a glorious beacon of lightPhYrE is a glorious beacon of light
The 20-pin port will not give you any more pins than at the dash with a generic reader.
You need something that is designed for the 20-pin connectors to read them. BMW has some additional wires on other pins for the ODBII connector that provide more to under the dash, and of course have more pins on the 20-pin connector.
As a side note, make sure that the cap is on for the 20pin port, as removing it disabled the ODBII port in the car.
Basically you need the SRS tool or a knockoff or official BMW reader. As with most carmakers, they use proprietary systems and put as little as possible on the ODBII channels.
-M
2008 BMW M3 Coupe (White on Fox Red)
CF everything / Lowering springs / EDC / Tint
AA Short Shifter
SOLD - 1997 BMW M3 Coupe (Estoril Blue]
VFE Supercharger Stage 1
Bilstein Sport Shocks/Struts
Euro-M3 Springs
Two-Piece Euro Rotors
JVC KD-AR5500 Headunit
Euro Headlights w/ TSX Projector Retrofit and HIDs
VDO Gauges
Harmon Kardon Amplifier retrofit
18-button OBC conversion retrofit
BMW Euro (clear) corners, tails, sidemarkers
ROH RT wheels / (f) 245/40/17 (r) 265/40/17 Toyo T1R
Jump to top PhYrE is offline   Reply With Quote
DICE Cable 6-pin Connector djpfine Audio/In Car Entertainment (I.C.E.) 1 Mon, Dec-31-2007 08:00:33 PM
BMW Pin Tool MrLiou168 Faults, Fixes and DIY 10 Mon, Sep-10-2007 01:21:09 PM
1998 ECU Pin Layout bmw m3 shawn_robinson E36 M3 (1992-1999) 0 Sun, May-15-2005 08:55:37 PM
BMW iPod Pin Extractor for Sale bimmer3 Parts for Sale/Wanted 0 Sun, Oct-17-2004 09:04:56 AM
What would cause my constant power pin (pin 1) in my factory alarm plug to not work? astan100 E36 M3 (1992-1999) 11 Thu, Jul-10-2003 05:04:13 PM
Discussing OBDII to BMW 20-pin connector adapter? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
