| M3 Track: Racing and DE Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! |
I plan on tracking my new M3 coupe quite a bit..... I was thinking about getting a set of stock 18" rims from someone who upgraded & put some track rubber on them....I figure I could go to a 255 front tire and a 275 or 285 rear tire.....
What is the widest tire that will fit on the stock 18" rims without rubbing? Of course a full custom wheelset like from CCW is the ideal solution....maybe 9" fronts with 10" rears? Does anyone know what will fit without fender rolling or rubbing? For a car with the weight of the new M3 I would like to run a 275 front and possible 305-315 rear...but it doesn't look like they would fit?
Brian 2008 E92 M3, Melborne Red, beige leather, loaded, with DCT!! (deliver 7-08 hopefully) 2006 Acura TL (wife) 1988 Porsche 928 S4 Guards red over champagne leather |
![]() Location: Louisville, KY
You are likely heading into unchartered territory as E92 M3s are only recently starting to be delivered to customers. This summer should provide you with a wealth of information as customers get them out on the track for the first time. I would assume the M3 fenders can accommodate a larger tire than the 335, but this should at least give you a starting place. Ideally you would like to run a square setup to attempt to neutralize any understeer and oversteer. CCW wheels are heavy and expensive for track wheels!
![]() Location: In my mind
Give the TireRack a call, they may actually know already what plus sizes will fit. If you're looking for a dual street/track tire, I would highly recommend the Potenza RE-01Rs. Astounding tire that can be daily driven. +1 on the square setup.
#4 |
(\OO\ (||)(||) /OO/)
![]() Location: Seattle
![]() Really? Are you talking about their 3-piece wheels? They seem pretty popular amongst dedicated track junkies. As for their 1-piece forged wheels, they're very light and strong for their size, and are half the price of other custom wheels such as Fikse, HRE, or Neez.
2005 Alpine White ///M3 SMG II |
#5 |
I did look on tirerack.....it seems there are several choices in 18" rims under 20lbs each......some are quite cheap too at $2-300 each..... The CCW's are WAY more $$$, but also are near 20lbs each....
Interesting about a balanced tire setup.....on my 928 I run WAY wider rear tires....most of the 928 racer-track guys do too...& the weight distribution on 928's is also 50-50 like the M3....but 150lbs lighter..... A typical setup is 275 fronts with 315 rears.....
| Fs: E92 M3 Oem 18" Wheels/tires | dosserj | Parts for Sale/Wanted | 45 | Tue, Jul-22-2008 03:32:15 PM |
| Track Wheels and tires | buckeye | M3 Track: Racing and DE | 3 | Mon, Jul-24-2006 01:28:51 PM |
| Track wheels and tires | hayjay13 | E46 M3 (2001-2006) | 1 | Thu, Jan-19-2006 01:02:36 AM |
| Best way to take track wheels/tires? | ekyub | M3 Track: Racing and DE | 10 | Sat, Oct-29-2005 05:05:38 AM |
| track wheels and tires | redenmd | E36 M3 (1992-1999) | 13 | Sun, Apr-11-2004 09:41:01 PM |
