Old Fri, Apr-11-2008, 12:01:17 AM   #21
Reputation: 0 Obioban has a spectacular aura about
yah, it's hard to find ones that work. That's why I made this thread!
Current Cars: 2005 IR/IR M3, 2003 TiAg M5, 1995 S50 B32 GT3 RS Green M3 Race Car _____Former Cars: 2004 TiAg/IR M3, 1996 TV/black M3, 1995 AW M3 shell
Useful stuff: Objective suspension comparison, DIY suspension install VIDEOS (e36 version), Stick Driving Basics, e46 Climate Control, Better Fuel Economy 101, 10W-60 TWS
Everything on the car: Mod List __________ HighRes M Wallpapers (Misc collected pics) <--- save target to desktop
Selling: Suspensions, brakes, safety equipment, etc (ask away!)
Renting: Valve shim adjustment kit, RTAB tool, Ball joint tool
Old Fri, Apr-11-2008, 03:37:52 AM   #22
Antroiny
(\OO\ (||)(||) /OO/)
Antroiny's Avatar
Reputation: 0 Antroiny is on a distinguished road
Eh, it was worth a shot. Thanks Tom!
Back to the web search...
2005 Alpine White ///M3 SMG II
Jump to top Antroiny is offline   Reply With Quote
Old Fri, Apr-11-2008, 03:46:23 AM   #23
carboy88
tRACk fan
carboy88's Avatar
Reputation: 0 carboy88 is on a distinguished road
What about the TCKline ones? The Pro Alloy nuts can be had with matching lock nuts, but $$$.
http://www.tcklineracing.com/wheels1.htm#spacers
" Pro Alloy Lightweight Nut- The best engineered lug nuts available. Super light-weight thin-wall construction using strong light-weight OEM quality materials. Oversized and taper seat to ensure best contact. External drive by popular 17mm hex for easier installation. Full stud engagement and can accommodate long racing studs. Very Reliable and stronger than aluminum racing nuts. Lug body produced by Cold-Forged SCM-435 material. Attached rotating taper-seat made with A7075-T6 aluminum and ultra-hard alumite finish. We offer full sets with or without wheel locks. Each kit comes complete with socket tools."
Jump to top carboy88 is offline   Reply With Quote
Old Fri, Apr-11-2008, 01:16:51 PM   #24
From the same link, "due to the closed end they cannot be used in conjunction with TC Kline Pro Studs"
Old Fri, Apr-11-2008, 02:25:55 PM   #25
carboy88
tRACk fan
carboy88's Avatar
Their regular aluminum ones are closed end, but the Pro Alloy ones are open. Unless I got it all wrong. From their pic, they are open and lockable.
Still, for that price you almost need a lock on each nut
Old Fri, Apr-11-2008, 03:40:27 PM   #26
hmm... they may work, but I think you'd have to drill out the key for sure.
Old Fri, Apr-11-2008, 03:47:12 PM   #27
carboy88
tRACk fan
carboy88's Avatar
Yes looks like it.
Slightly OT - Obioban I noticed in your pics that you are running different stud types front and back? The ones on the rears look like Turner studs with the hex bullet head, but your front ones look different? Are they RRT ones? What lengths are you running?
Thanks!
Old Fri, Apr-11-2008, 04:17:54 PM   #28
Yes looks like it.
Thanks!
I started out with the TCK studs front and rear. Their rears are too long and hit the ebrake (tick tick tick) so they were replaced in short order Turner's (75mm).... which is what you're seeing in the pics. Since then I have also replaced the fronts with Turner's for a uniform looks
Old Fri, Apr-11-2008, 04:41:47 PM   #29
carboy88
tRACk fan
carboy88's Avatar
Good info, thanks. I was looking at the TCK ones but sounds like Turner is the way to go.
Old Mon, Aug-09-2010, 08:58:43 PM   #30
thp
Reputation: 0 thp is on a distinguished road
Another potential solution.
McGard 24012
http://www.mcgard.com/prod_imgs/LockConeMulti.jpg
Which is the correct lock system for the Gorilla solution??
Gorilla Automotive 78433N - Gorilla Wheel Lock Systems
Gorilla Automotive 78633N - Gorilla Wheel Lock Systems
Inside every good car is a bunch of wires and mechanical stuff... and a crazy driver
Jump to top thp is offline   Reply With Quote
kits, locks, stud, wheel, work
Wheel Stud Conversion Kits Eric1855 E36 M3 (1992-1999) 23 Sat, Dec-22-2012 01:53:05 PM
Just trying to round up what stud kits, lug nuts and any locks folks are using... gixxer E46 M3 (2001-2006) 11 Fri, Mar-27-2009 12:29:15 AM
Wheel locks that work with stud kits! Obioban E36 M3 (1992-1999) 5 Sun, Mar-30-2008 12:13:36 AM
Does anyone know where you can get wheel locks that work with a stud kit? Obioban E46 M3 (2001-2006) 11 Mon, Oct-15-2007 06:24:58 AM
Lock nuts for those with stud kits Arnee E46 M3 (2001-2006) 11 Mon, Aug-14-2006 07:39:32 PM
Discussing Wheel locks that work with stud kits! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
