Old Tue, Apr-01-2008, 04:55:21 PM   #1
supalicious
Reputation: 0 supalicious is on a distinguished road
Default How long/far do you have to drive to charge battery?
Guys,
I only drive my car once a week and lately it's been getting difficult for the car to start up on the initial crank.
How long or how far do i have to drive the car before the battery starts to get charged up?
I'm guessing that short trips around the block isn't going to sufficient to keep the battery charged.
Thanks for the input!
Jump to top supalicious is offline   Reply With Quote
Old Tue, Apr-01-2008, 05:39:44 PM   #2
da3bous
Restricted
da3bous's Avatar
Reputation: 578 da3bous has disabled reputation
Faroe Islands
30 minutes is a good rule of thumb.....gives the alternator enough time to recharge the battery....plus it recharges your key so you don't get screwed with your keyless entry next time either
I've got diarrhea of the mouth....want to listen?
Jump to top da3bous is offline   Reply With Quote
Old Tue, Apr-01-2008, 05:43:57 PM   #3
Ghozt
Phuckface!!!!!
Ghozt's Avatar
Reputation: 0 Ghozt is a glorious beacon of lightGhozt is a glorious beacon of light
Question related to OP's question..
I was told by a friendly mechanic that a simple start-up of a car will give a battery a nice instantaneous recharge.. In example, you've noticed that you left lights on inside your car for a good 6 hours or so... Would a start-up along with a 3-5min running of the engine revive most of the lost charge, or is that false? I thought that once the alt kicks in, it gives the battery back a good amount of lost charge...?? Without having to go drive the car for 30 mins or let it run for 30 mins or whatever...
Jump to top Ghozt is offline   Reply With Quote
Old Tue, Apr-01-2008, 05:45:06 PM   #4
Jasoncor
Grumpy Young Man
Reputation: 0 Jasoncor has a spectacular aura about
I drove for an hour, and that was good
Jump to top Jasoncor is offline   Reply With Quote
Old Tue, Apr-01-2008, 05:47:46 PM   #5
Challenger 800
Married to Siberiankim
Challenger 800's Avatar
Reputation: 0 Challenger 800 is on a distinguished road
weird, my battery blew the fuk up yesterday. I was heading off to the beach when I went to crank it and KABOOM , the kids were like DAD FIX IT !!!!!! WE WANT TO GO SNORKLING !!!!!
Uhh STFU kids ok, thanks
Love My Kimmy
Jump to top Challenger 800 is offline   Reply With Quote
Old Tue, Apr-01-2008, 06:04:11 PM   #6
Dan I Am
Steep and Deep
Dan I Am's Avatar
Reputation: 578 Dan I Am has disabled reputation
Antarctica
You should keep a low amp charger on it during the week.
Tie your shoes. Drive your car. Love your girl.
Jump to top Dan I Am is offline   Reply With Quote
Old Tue, Apr-01-2008, 06:06:42 PM   #7
da3bous
Restricted
da3bous's Avatar
Faroe Islands
Have you ever had a dead battery and then after charging or jumping got it to crank and then shut it off after 10 minutes it was fine later??? I think that should answer your question.
Old Tue, Apr-01-2008, 06:07:57 PM   #8
Dan I Am
Steep and Deep
Dan I Am's Avatar
Antarctica
http://www.amazon.com/Deltran-SuperS..._tdp_sv_edpp_i
Old Tue, Apr-01-2008, 06:11:17 PM   #9
Ghozt
Phuckface!!!!!
Ghozt's Avatar
I'm not sure
I shoulda been more clear but I didn't mean a dead battery. I meant you notice your lights have been on so you do a quick turn-over, let the car run for a few mins, and shut it back off... Will that provide the battery with a "quick re-charge" or is that question better suited for mythbusters???
Basically, my mechanic advised it as a battery draining prevention tip.. If you notice lights have been on in your car for x amount of time, and you simply turn them off, your battery could need a jump start should you attempt to start it the next morning. Instead, a quick start-up followed by allowing the engine to run for 3-5 mins will allow for a quick re-charge, and the car should be fine the next morning...???
Old Tue, Apr-01-2008, 06:15:42 PM   #10
da3bous
Restricted
da3bous's Avatar
Faroe Islands
I'm not sure
I guess thats subjective how drained the battery is and such, but then again i would never suggest letting a M3 just get started for 5 minutes and shut down....
How long did your battery last? kramerdog E46 M3 (2001-2006) 57 Wed, Apr-23-2008 01:58:31 PM
WTB: Trickle charge/ Battery maintainer marmarm3 Parts for Sale/Wanted 0 Thu, Jan-03-2008 05:27:04 AM
How long does a battery last? EMAXX Off Topic 11 Sun, Nov-05-2006 06:19:23 PM
My battery WONT charge BigmansM E36 M3 (1992-1999) 16 Tue, Aug-22-2006 06:50:03 PM
Li-Ion battery - charge before first use??? dskippy888 Off Topic 3 Fri, Jul-28-2006 04:23:03 PM
Discussing How long/far do you have to drive to charge battery? in the Off Topic Forum - Place to discuss this and that. Note: We also have "request to join" forums: Guns and Fitness.
