Old Tue, Apr-15-2008, 07:38:10 AM   #1
Got_S54?
Got Lip?
Got_S54?'s Avatar
Reputation: 0 Got_S54? is on a distinguished road
Default DIY: Stopping cricket noise II
Thanks to samytampafl on the E46 fanatics who found the source of the annoying cricket noise behind the dashboard. His post shows how to remove the fan that causes the cricket sounding noise and replace it with a new one.
I realized the only thing wrong with it is that the bearing in the motor has dried out. If you don't feel like spending $80+ on a new fan, this DIY shows you how, for about $5 worth of electronics parts cleaner and dry lube and about 10 minutes, you can clean and relube the bearing in the motor for quiet free operation again.
Rather than cross link the original thread, I'll post his steps here, and continue with mine.
1: remove the plastic cover just above the pedals..
2. remove the 3 screws from the blower...Warning! Once blower is free, do not pull it out. It is still connected by an electrical connector
3. open hood.. head out to the front of the car.. find the electric box and remove the 4 hex screws, then remove the plastic cover
cover removed:
4. disconnect the electical connector to the fan
5. after you unplug the connector, you can remove the fan from inside the vehicle. you can either replace it with a new one, or proceed to cleaning/relubing the bearing like i chose to do.
edit: updated on the part numbers
It looks like there are two versions - one with a 3-prong connector and one with a 2 prong connector.
To check which you need, go to www.realoem.com and look up the part making sure you choose the correct year/model. From the main group, go to #12 - Engine Electrical System, then go to the Subgroup and choose 12-35 Control Unit Box.
You're looking for part #5 called the "Cover with blower".
It looks like for cars up to 2003, the correct part number is 12907571019
For cars 2003 and up, the correct part number is 12907570074
Double check with RealOEM or your local dealer to be sure.
05 TT 225 Quattro - APR Stage 1|FK coilovers|Megan Adj.Cont.Arms|APR catback|15F/20R spacers|OEM ALMS 18's - daily
02 M3 AW/IR - sold but not forgotten
Last edited by Got_S54?; Sun, Jul-13-2014 at 01:12:51 AM. Reason: updated pic links
Jump to top Got_S54? is offline   Reply With Quote
Old Tue, Apr-15-2008, 07:39:01 AM   #2
Got_S54?
Got Lip?
Got_S54?'s Avatar
6. remove the blower from the cover by removing the single screw
7. separate the blower housing by prying the furthest tab at the end while separating both halves
8. move onto the next one and the next one until you can separate the housing
9. remove the motor cover as well by prying the tabs carefully
10. with the motor cover removed, remove the foam spacer and carefully remove the circuit board
11. spray electronics parts cleaner on the motor and focus on the bearing. you'll see dirty fluid drip out. spin the fan by hand as well to make sure it's nice and clean and dry, although electronics parts cleaner evaporates very fast.
12. make sure it's dry, then carefully spray some dry lubricant directly on the bearing. this stuff is great because it drips into the bearing to penetrate, then the fluid evaporates leaving only the lubricant. spin the fan by hand (in my case, i connected the fan to a 12v souce, and sprayed the lubricant while it was spinning.
13. motors generally have 2 bearings - front and rear. i tried to remove the fan to get to the front bearing, but couldn't and didn't want to risk breaking it, so i sprayed the electronic cleaner toward the center of the fan, then the lubricant (while it was spinning)
Old Tue, Apr-15-2008, 07:42:51 AM   #3
Got_S54?
Got Lip?
Got_S54?'s Avatar
test the fan if you can by connecting it to a 12v source before putting it back on the car. i used a car battery charger with little alligator clips
video 1
Reassemble the fan unit and test again. No more cricket noise!!!
video 2
Re-install the fan and enjoy cricket-free operation.
Old Tue, Apr-15-2008, 07:45:40 AM   #4
2euro
APEX KNG
2euro's Avatar
Reputation: 0 2euro is on a distinguished road
good stuff Joseph!
Jump to top 2euro is offline   Reply With Quote
Old Wed, Apr-16-2008, 01:55:29 AM   #5
Niels E46 M3
Reputation: 0 Niels E46 M3 is on a distinguished road
awesome post!!!
thanks!
2009 Space Gray M3 Coupe
  • DCT
  • Fox Red Extended
  • All Options except Sunroof
My Ultimate BMW ///M Blog
Jump to top Niels E46 M3 is offline   Reply With Quote
Old Wed, Jul-30-2008, 02:52:41 AM   #6
jaciuro
When will they learn that the left lane is for passing only?
jaciuro's Avatar
Reputation: 0 jaciuro has a spectacular aura about
Puerto Rico
Nicely detailed DIY post.
2004 E46 M3 6-SPD Titanium Silver/Gray Leather
StopTech ST60/380mm, PowerFlex RTABs, Streamline Intake Tube & Filter
2005 Suzuki GSX-R 1000 Black/Yoshimura TRC (Stolen!)
2002 Subaru WRX Stage2+Sold
Jump to top jaciuro is offline   Reply With Quote
Old Fri, Sep-19-2008, 01:19:33 PM   #7
Six
Everything is awesome
Six's Avatar
Reputation: 0 Six is an unknown quantity at this point
Thanks for the DIY
Jump to top Six is offline   Reply With Quote
Old Sat, Sep-20-2008, 05:24:29 PM   #8
Six
Six's Avatar
FYI, there are two versions of the fan. One with a 3 prong connector and one with two;
my dealer gave me the wrong one when they looked it up by VIN, I had to go back and they found the correct one.
Old Fri, Sep-26-2008, 03:45:29 AM   #9
Kendrick07
Kendrick07's Avatar
Reputation: 0 Kendrick07 is on a distinguished road
South Korea
Thank you, this noise has been bugging me like crazy lately.
16 M4 Coupe DCT - Alpine White/Black Full
09 Lexus GS350 - Sapphire Pearl/Black
04 M3 Coupe SMG - Jet Black/Black (sold)
Bikes
12 Honda CBR 1000RR - Black
09 Honda CBR 1000RR - White (sold)
06 Honda CBR 1000RR - Black (sold)
05 Honda CBR 600RR - Black (sold)
Jump to top Kendrick07 is offline   Reply With Quote
Old Sun, Oct-12-2008, 01:01:56 PM   #10
lucky_doggg7
lucky_doggg7
Reputation: 11 lucky_doggg7 is on a distinguished road
Great post. I hate crickets!
Jump to top lucky_doggg7 is offline   Reply With Quote
cricket, diy, noise, stopping
Cricket? marv800 Off Topic 18 Mon, Dec-31-2007 03:28:14 PM
"cricket" noise when going over bumps (right front) benz4matik E46 M3 (2001-2006) 3 Tue, Jun-19-2007 10:30:21 PM
DIY - Noise Cancelling Headphones for $20 finovski Off Topic 4 Tue, May-01-2007 08:28:04 PM
DIY and POPPING NOISE! crazy32184 E36 M3 (1992-1999) 4 Thu, May-19-2005 08:01:02 PM
My 95 M3 sounds like a cricket. OnUrleft E36 M3 (1992-1999) 15 Tue, Apr-05-2005 04:13:53 AM
Discussing DIY: Stopping cricket noise II in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
