#11 |
thanks mvez....
they came with the race car as a backup set....but i've already got a set of alum ones for backups....therefore...half price off....figure someone could use them...and they're just sitting there. |
#12 |
![]() Location: Toronto
What would you recommend? I'm not sure if I should go with steel ones or not.
#13 |
your options are: and it may not be a complete complete list.
gc street "rubber bushing'd" gc race "spherical bearing'd" turner motorsports "i'm sure they have both rubber and steel" go to their website rogue engineering, steel with rubber bushings.. your two choices are aluminum or steel.....why wouldn't one go with steel? other than weight, which is a whopping 2 lbs total. they're half off fella! |
#14 |
The car a is DD in the summer, Is there a harder or noisier ride with the ones your selling? How much do you what for them? Thanks for your help BTW.
#15 |
![]() Location: WI
TCKs are nice as well
'02 M3, '10 S4, '92 Porsche 911 AR, '08 A6 Avant, '06 A3 3.2, '08 Jeep Rubicon, '07 GTI |
#16 | |
///M POWERED
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: Heaven
http://www.turnermotorsport.com/html..._ID=TSU9940001 Buy the polyurethane rubber bushing versions for a daily street driven car. Buy the spherical bearing versions if you are building a race/track car, and you are willing to accept the slightly harsher ride. That's the only scenario where I would put a hard inflexible spherical bearing component on my car. The spherical bearing type camber arms will transmit more NHV to the chassis, and eventually to the passengers. Oh it definitely stiffens up your suspension all right...but there is no free lunch. You will have to put up with more NHV. (no way around that) As a matter of fact, stay away from all suspension componants that have rigid shperical bearings including RSM's and RTAB's if ride comfort is one of your primary objectives.
R E M E M B E R O U R T R O O P S ![]() True leaders are not those who strive to be first, but those who are first to strive and give their all for the success of the team. They can be identified by the clarity of their vision, the strength of their actions, and the integrity of their intent. A true leader has the confidence to stand alone, and the courage to make tough decisions. A true leader has compassion, and is willing to listen to the needs of others. He does not set out to be a leader, but he becomes one by the confidence that he inspires in others. He commands the respect of his peers, and is humbled by the admiration of his followers. True leaders are first to see the need, envision the plan, and empower the team for action. By the strength of the leader's commitment, the power of the team is unleashed. |
#17 |
Vert Crew Represent
![]() Location: Gaithersburg
http://cgi.ebay.com/ebaymotors/SPC-R...spagenameZWD1V
spc camber arm, if you search around you could find it cheaper, I don't think I paid more than 150$ shipped. Install is the expensive part, you gotta drop the diff to put these in! thanks bmw!
![]() 04 M3 Convertible 6 Speed Manual <HRE> <Eisenmann> <Active Autowerke> <BSW> <KW> <SPC> <Prosport> <AutoSolutions> <Vornsteiner> <Z06 Brakes> |
#18 |
Porsche 997
![]() Location: Austin, TX
I got these UUC from Sean @ D/A. Based on my research I found the following and decided on these given their quality - there are obviously others as nice:
The adjustable rear control arms have a range from +1.0° to -3.0° range. Co-developed with OE-supplier SPC Performance, the combination of OE engineering and UUC's enhancements make these arms truly "ultimate". With so many alternate choices, why UUC?
Center bar: plated 4130 chromoly steel. End components: CNC-machined anodized aluminum for lightness, stress-relieved for strength and durability. Inboard bushing: high-durometer squeak-free rubber. ![]()
![]() Porsche 997 - GJGM3 Replacement 997 Mods in Progress |
#19 | |
#20 |
| Adjustable Rear Control Arms | thedood | E36 M3 (1992-1999) | 93 | Sun, Oct-10-2010 10:55:09 PM |
| GC rear adjustable lower control arms | spankypokie | Parts for Sale/Wanted | 23 | Wed, Sep-16-2009 04:12:16 PM |
| Adjustable Rear Control arms... worth it? | camdinans3 | E36 M3 (1992-1999) | 6 | Wed, Jul-30-2008 05:12:21 PM |
| wtb : adjustable rear control arms | bmwbob | Parts for Sale/Wanted | 5 | Mon, Jun-18-2007 08:00:47 AM |
| RE SPORT adjustable rear control arms | STALKER | E46 M3 (2001-2006) | 13 | Sat, Mar-17-2007 05:28:24 AM |
