Old Thu, May-01-2008, 03:47:28 AM   #1
PremierPOWER
3rd Generation Baller
PremierPOWER's Avatar
Reputation: 0 PremierPOWER is on a distinguished road
Default Differential Fluid
I know the topic has been beat. Ive searched and found most have recommended Royal Purple 75w-140. I use Mobil 1 oil in the engine, and have had a lot of sucess with Mobil 1, even beyond cars/ trucks. (boats) Has anyone used Mobil 1 LS 75w-140 gear lube for their differentials? Thanks
Kevin
2004 ///M3 Jet Black SMG Vert
1995 ///M3 Cosmos Black 5spd Coupe
2008 GMC Yukon Denali XL
2007 Chevy 3500 Duramax
Originally Posted by camdinans3 View Post
you always gotta burst in and be like OH IM A HUGE BALLER hahahaha
WTB: LTW Wheels
Jump to top PremierPOWER is offline   Reply With Quote
Old Thu, May-01-2008, 03:36:49 PM   #2
Richardsperry
95 SC M3
Richardsperry's Avatar
Any fluid 75-90 or 75-140 will be fine provided you change it every 30K. If you track the ca, go for the 75-140 otherwise, it's not needed.
Old Thu, May-01-2008, 04:33:04 PM   #3
m3buzz
///M3Buzz
m3buzz's Avatar
Reputation: 0 m3buzz is on a distinguished road
I am using Red Line 75W-90, and also track it occassionally and (thanks to gauges) have never seen it get above about 200-210 degrees...key words there - "seen it." I generally take a look every once in a while on track days, but tend to leave the selector to the engine oil temp more than diff or tranny. Having said that, I'll likely go with 75W-140 RP next time I change it.
///M3BUZZ
GC CoiloversOPN Welded!
UR Underdrive Pulleys, RD Sways/UUC links, UUC Evo3 SSK, UUC TMEs,UUC System U, Fluidyne Alum. Rad., SS Brake/Clutch Lines,
M50,X-Brace, Halos/Projectors/6000k,Clears, Fan/ASC/CDV Delete, Stewart HD WP, Euro Rotors, VDO Console Gauges, Custom CAI
///Team Contour
Jump to top m3buzz is offline   Reply With Quote
Old Fri, May-02-2008, 06:55:25 PM   #4
jmeeder
jmeeder's Avatar
Reputation: 0 jmeeder is on a distinguished road
just make sure it is the one with the ls additive already in it
1999 M3 Titatinum Silver
Baureihe: E36
Fahrzeugtyp: M3 3.2
BMW-Typschlüssel: BG93
Motor: S52
Karosserie: Coupe
Katalogausfürung: USA
Lenkung: Links
Getriebe: Manuell
Produktion: 03/1999
MODS: Shark Injector, CAI
Jump to top jmeeder is offline   Reply With Quote
Old Fri, May-02-2008, 11:34:26 PM   #5
PhYrE
Mmmmm-3
PhYrE's Avatar
Reputation: 0 PhYrE is a glorious beacon of lightPhYrE is a glorious beacon of light
It has nothing to do with temperature. At any temperature (whatever it may be above a cold temperature... If I recall correctly and did the math right, the 75W is taken at 45C [if I recall, 30W is taken at 0C, and for every 5W less you subtract 5C, and for every 5W more you add 5C]. Anything above 45C (about 113F) and a 75W90 oil is thinner than it would otherwise be if it were a 75W140 oil.
But yes- 75W90 isn't the end of the world. Any 75W140 weight oil with a LSD additive will do. RP is popular.
-M
2008 BMW M3 Coupe (White on Fox Red)
CF everything / Lowering springs / EDC / Tint
AA Short Shifter
SOLD - 1997 BMW M3 Coupe (Estoril Blue]
VFE Supercharger Stage 1
Bilstein Sport Shocks/Struts
Euro-M3 Springs
Two-Piece Euro Rotors
JVC KD-AR5500 Headunit
Euro Headlights w/ TSX Projector Retrofit and HIDs
VDO Gauges
Harmon Kardon Amplifier retrofit
18-button OBC conversion retrofit
BMW Euro (clear) corners, tails, sidemarkers
ROH RT wheels / (f) 245/40/17 (r) 265/40/17 Toyo T1R
Jump to top PhYrE is offline   Reply With Quote
FS: BMW Differential Fluid + Royal Purple Transmission Fluid mrtt Parts for Sale/Wanted 13 Wed, Apr-16-2008 05:03:22 PM
Best differential fluid? jkalex05 E46 M3 (2001-2006) 16 Fri, Sep-14-2007 08:43:13 PM
583 Differential Fluid cost? M3GAMAN E46 M3 (2001-2006) 14 Thu, Nov-02-2006 07:16:32 AM
Differential Fluid. mufasis E46 M3 (2001-2006) 5 Mon, Aug-28-2006 10:17:03 AM
Differential fluid change questions ryanK Faults, Fixes and DIY 0 Thu, Feb-09-2006 01:31:34 PM
Discussing Differential Fluid in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
