Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted
Parts for Sale/Wanted Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods.
Old Mon, May-12-2008, 04:57:34 PM   #1
tom @ eas
tom @ eas's Avatar
Reputation: 0 tom @ eas is on a distinguished road
Default ▀▄ eas - e2 aurora 60LED angel eye kits for BMW - coming soon!
We have seen lots of Angel Eye kits on the market in the past 5 years. Everything from seperate lightsources, CCFL tubes, failing inverters and LED kits with gaps and warranty issues with vendors. What happens when you can't find something for your BMW on the market that suits your needs?
You simply design them yourself.
Introducing aurora, an entirely redesigned angel eye kit for your BMW from eas - unlike anything else on the market.
aurora produces a fully uniform look using a 60 LED array, which matches most Xenon maps for an OEM look and are very bright - these can even be seen in daytime. You will immediately know another vehicle with a set after yours are installed.
Appearance
A light-emitting diode, usually called an LED, is a semiconductor diode that emits incoherent narrow-spectrum light when electrically biased in the forward direction of the p-n junction, as in the common LED circuit. This effect is a form of electroluminescence. A LED is usually a small area light source, often with extra optics added to the chip that shapes its radiation pattern. LEDs are often used as small indicator lights on electronic devices and increasingly in higher power applications such as flashlights and area lighting.
Comparison photo of Orion (left) vs. aurora (right). No "pearl necklace" or "burnt out Christmas light" syndrome here. aurora emits its light from a 60 LED array for a uniform and finished look.
2-Stage Ring Clipping mechanisms
For years, angel eye users have been plagued by clips that simply do not fit correctly - we have a solution. Our 2-stage replaceable clips allow secure clipping onto your headlight housings without the need for "spacing" or guessing alignment, especially for those with adaptive headlamps. Simply clip into place and rest assured your rings will be sure without the need for gluing or falling off from road vibration or adaptive headlight movement.
If clips are ever broken, replacements are available without replacing an entire kit.
OEM Look
aurora halos feature a sleeved highly polished ring around the circuit board, giving a thicker OEM look when on or off. Since LEDs are directional, there is no "bleedoff" in light direction allowing for maximum light output facing forward.
Safety
A Heavy duty wiring harness is included to make installation quick and painless, while adding safety to your install. No light boxes or lamp sources are used unlike older kits. Installation takes about 1 hour and will be one of the favorite mods on your BMW.
Brightest Angel Eye rings on the market
aurora Angel eyes can be seen from well over 150 feet away in pure daylight - they are BRIGHT. Using high-powered LED technology, these are the brightest on the market. With a highly polished ring engineered to emulate the OEM ring when not lit, these will look as if your BMW were equipped with Angel Eyes from factory. Kits are engineered using high quality components and are rated at over 100,000 hours or 10 years of continuous illumination.
Remote feature
aurora angel eyes feature a remote feature that will automatically dim the rings when you enter or leave the vehicle. Unlocking the vehicle will emit a "fade in" and will fade out when the vehicle is locked or if left dormant for over 15 minutes to prevent battery drainage.
LIFETIME Guarantee
There's nothing worse than having a kit that will not work, for those that have purchased other kits elsewhere and have dealt with frustrating return processed or no warranty at all, we feel your pain. eas backs up all aurora angel eye kits with a limited lifetime warranty, making this the first and last set you will purchase for your BMW. if you should ever experience a problem with your kit, we will be there to help.
Preorder today or sign up on our waiting list to be notified when orders are shipping.
e2 - aurora 60 LED Angel Eye Kit (most BMWs)
http://www.europeanautosource.com/pr...oducts_id=1883
Features
- OEM like modern look, simply the brightest kit on the market
- 60 high powered LED array for maximum brightness, withstanding shocks, vibrations, frequent switching and extreme temperatures.
- CAD designed polycarbonate ring with UV protection and additional clearance for all headlight housings
- No dangerous light boxes or heat fixtures to mount, keeping safety and cleanliness underneath your hood
- No "cold weather" start problems
- Instant transformation to appearance of vehicle after installation
- 100,000+ hour life (over ten years)
- Easy installation
- Compatible with Halogen, Xenon, Auto Leveling and Adaptive Lights
- Limited lifetime warranty
Kit Contents
- 4 Highly polished LED Halos
- 1 Heavy duty wiring harness, with remote feature
- Backed by limited lifetime warranty
- Detailed instructions
Models Supported
1999-2003 e46 3-series Coupe (pre-facelift, non-sealed lamps)
1999-2005 e46 3-series Sedan
2000-2006 e46 M3 Coupe/Convertible
1995-2001 e38 7 series
1997-2000 e39 5-series
Simply demand the best for your BMW. Available in late June from eas and authorized retailers.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com web: www.europeanautosource.com
tel 866.669.0705 | ca: 714.369.8524 x22 | fax: 714.908.1796
Blog | Facebook | YouTube | Flickr | Twitter
Jump to top tom @ eas is offline
Rate Seller View Rating
Old Mon, May-12-2008, 05:00:07 PM   #2
tom @ eas
tom @ eas's Avatar
More pictures:
Comparison of Orion (left) and aurora (right)
Close-up of aurora
Jump to top tom @ eas is offline   Reply With Quote
Old Mon, May-12-2008, 05:00:59 PM   #3
tom @ eas
tom @ eas's Avatar
For those that requested - daytime pictures:
Orion on the left, aurora on the right.
Old Mon, May-12-2008, 05:01:30 PM   #4
tom @ eas
tom @ eas's Avatar
space reserved #3
Old Mon, May-12-2008, 05:31:36 PM   #5
dissto
the polish pimp
dissto's Avatar
Reputation: 0 dissto has disabled reputation
Poland
price?
growing up....
2004 SMG ///M3, A08, BBS CH-R satin, custom two-tone fender gills, custom two-tone front grill, v-csl splitter, v-csl trunk, depo corners, LED angels, dice, tein s-techs...
Jump to top dissto is offline   Reply With Quote
Old Mon, May-12-2008, 05:33:18 PM   #6
redice
hello
redice's Avatar
Reputation: 0 redice is on a distinguished road
Put me on the waiting list!!
Jump to top redice is offline   Reply With Quote
Old Mon, May-12-2008, 05:45:46 PM   #7
docjavier
01 E46 M3, 95 M3 & 850i sold
docjavier's Avatar
Reputation: 0 docjavier is on a distinguished road
Puerto Rico
Originally Posted by dissto View Post
price?
I want to know too. ????????
Active tunned, GC 500/550, GC sway bars, GC adj RCA, Powerflex RTABs, Treehouse Racing FCAB, Auto Solution SSK, ZHP knob alcantra boot, BHS pulleys, AFE Stage 1 intake, StopTech BBK, Dinan strut bars, Strass front lip, ACS roof spoiler, Racing Dynamics CF engine cover, Active Headers, Custom Performance Rasp Terminator, Super Sprint X pipe, Eisenmann Sport 4x83mm muffler, Orion LED, prolumen 6K & 8K in fogs, 19" Iforged Daytona polished, 18" SSR GT3 Pilot Sport. I love Focals those Utopias can rock, JL 500/5, JL W6 x 2, Alpine 9887.
Jump to top docjavier is offline   Reply With Quote
Old Mon, May-12-2008, 05:49:17 PM   #8
KrisHorton
Reputation: 0 KrisHorton is on a distinguished road
These look pretty nice. Personally, I like the Orions because of how they look. I know there are a lot of guys that don't like the spaces in between the LEDs, but I actually do. I do like the light output of the Auroras though, so who knows, I may switch in a few months. I'm also curious on what the price will be. I'm sure they'll be priced to compete with the Orions.
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=80552&dateline=120836  3121
2004 Alpine White M3 | Cinnamon Interior | SMG II
Vorsteiner CF Vented Race Hood | ACS Front Lip | ZShift CSL Diffuser | VMR V710 Wheels |Depo Smoked Corners
UmNitza Orion Angel Eyes | Blacked out Kidneys and Vents | JVT Header | KW V2 Coilovers | Borla midpipe | Borla cat-back
Painted Reflectors | B&W CF Roundels
Jump to top KrisHorton is offline   Reply With Quote
Old Mon, May-12-2008, 06:19:33 PM   #9
T-Werke
LSBFTW
Reputation: 0 T-Werke is on a distinguished road
very nice!, but geez these new LED angle eyes are coming out like wildfire, i think im going to wait a few months until all the new versions are released so i can find the perfect one for me...
Travis
Jump to top T-Werke is offline   Reply With Quote
Old Mon, May-12-2008, 06:23:14 PM   #10
leletyM3
640rwhp
leletyM3's Avatar
Reputation: 0 leletyM3 is on a distinguished road
Italy
Not bad at all..!
05 BMW ///M3 SMG - Jet Black/Gray
HPF Stg2 Turbo Kit 640rwhp, HPF Stg2 Feramic Clutch, HPF Carbon Fiber Stg3-4 Intake,HPF Catch Can, HPF Carbon Fiber Air Duct, HPF Methanol Switch, HPF Under Brace, HPF Subframe Kit, Custom AEM UEGO and AEM Boost Gauge in the OEM Mirror, Okada Plasma Coils, Eisenmann Race 83x4, Bilstein PSS9, Volk TE37 Time Attack, Toyo 275/30/19 & 245/35/19, Brembo BBK 380mm 6 pots & 345mm, Hardwired V1, 6K HID bulbs, 6K HID Fog Lights, 6K Umnitza Orion V2, Depo Smoked Corners, Solaris Bulbs, Full LEDs interiors,Umnitza LED licence plate lights, 30% Tint All Around, V-CSL V2Front Bumper with Race Lip, OEM CSL Bootlid, V-CSL Diffuser, ///M3 Monochrome, Flat Black Kidneys & Side Grills, Carbon Fiber BMW Emblems, Powerflex RTABs, Dension Ipod ICE>Link Plus, AudioControl unit, Phoenix Gold 600Ti, JL Audio 12W6v2
Jump to top leletyM3 is offline   Reply With Quote
▀▄ eas - e2 aurora 60LED Showroom Thread tom @ eas E46 M3 (2001-2006) 126 Thu, Apr-26-2012 04:01:24 PM
▀▄ eas | e2 aurora 60LED angel eye kit - Official Release tom @ eas Parts for Sale/Wanted 193 Thu, Jan-15-2009 04:52:24 PM
▀▄ eas - e2 aurora 60LED angel eye kits for BMW - first look tom @ eas E46 M3 (2001-2006) 168 Mon, Jul-14-2008 04:39:01 PM
▀▄ eas | e2 aurora 60LED angel eye kit - pre-release videos and pictures tom @ eas E46 M3 (2001-2006) 30 Sun, Jul-13-2008 09:15:13 PM
Default ▀▄ eas - e2 aurora 60LED angel eye kits for BMW - coming soon! tom @ eas M3Forum Sponsor Announcements and Specials 3 Wed, Jul-09-2008 10:41:32 PM
Discussing ▀▄ eas - e2 aurora 60LED angel eye kits for BMW - coming soon! in the Parts for Sale/Wanted Forum - Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
