Old Wed, May-21-2008, 12:15:46 PM   #1
fiveightandten
fiveightandten's Avatar
Default Jacking up the E36
I know there have been a few threads on this, but info/opinions are definitely scattered all over the board. I read the DIY at Pelican parts, and they're telling me to do things like use the rear diff as a jack point (broken carrying bolt anyone?), and to remove the hockey pucks and put the jacks directly on the chassis (huh? isn't that what the hockey pucks are for?).
What do you guys do to get all 4 tires off the ground. I have a jack pad. But I don't like trying to lift one side up, then the other. And if I pop the front end up first, I can't get my jack under the rear to get it on the crossbrace in front of the diff.
The best solution i've found is to put the jack on the front subframe to get the front end in the air, support that with jack stands on the hockey pucks...then use the jack pad to raise the rear one side at a time. It's just real slow going, and I don't like the weight shifting like that while it's on 2 jacks stands in the front.
Anything i'm missing here?
-Nick
Old Wed, May-21-2008, 01:05:15 PM   #2
M3cosmos95
I've never even been to Mt. Vesuvius!
M3cosmos95's Avatar
Reputation: 0 M3cosmos95 has a spectacular aura about
buy another jack
Ansel
MY EX-///M3 || Vanos DIY || 200k ///M Club:(ask me for membership!) || Supercharged ///95 Club(ask me for membership!)
Jump to top M3cosmos95 is offline   Reply With Quote
Old Wed, May-21-2008, 01:36:25 PM   #3
fiveightandten
Originally Posted by M3cosmos95 View Post
buy another jack
I have 2, but one is one of those little cheap jacks and the max height isn't enough to put the jack stand under the hockey puck. Not to mention, i'd need a second jack pad.
I thought about getting another, but surely there's a better way to jack the car up without buying 2 jacks and 2 jack pads.
I've done it with the emergency jack. But I don't trust that thing from just folding over all of a sudden and dropping the car.
-Nick
Old Wed, May-21-2008, 02:02:09 PM   #4
M3cosmos95
M3cosmos95's Avatar
yea never use that emergency jack...Mine collapsed on me and almost crushed my legs It did however dent one of my front fenders...and pissed me off! I will never use one of those again!
In the front you can jack it up using the cross bar...but me having an extremely low car have to use two jacks. But the front are easy you can use the jacking points then put the jack stands on the frame rails or cross member. The back is a bit harder...recently i have been using those ramps you drive the car up, then lower one side at a time onto jack stands. It works alright and you get a decent amount of height.
Ansel
Old Wed, May-21-2008, 02:07:57 PM   #5
fiveightandten
Yeah, the front is no problem at all. My big jack won't get under there with enough clearance to pump the handle. But I just pop one side up with the jack pad a few inches until I get the bumper lifted. That's fine. The issue is just getting all 4 corners in the air. You need to do this even for changing the oil, as the drain plug is on the side of the oil pan.
I suppose I could just blow $60-80 on a cheap secondary jack that has enough height to lift the back end...then pick up a 2nd jack pad.
2 jack pads, 3 jacks, 6 jack stands...I should've just bought a lift.
-Nick
Old Wed, May-21-2008, 02:17:47 PM   #6
M3cosmos95
M3cosmos95's Avatar
If i had a garage i would have!
Ansel
Old Wed, May-21-2008, 02:19:45 PM   #7
PhYrE
Mmmmm-3
PhYrE's Avatar
Reputation: 0 PhYrE is a glorious beacon of lightPhYrE is a glorious beacon of light
Jack up the front on the front subframe/crossmember. Of course be careful to clear the steering rack, also right about the same place. Insert jack stands at the jack points.
Use a rolled up newspaper (just to avoid exposing metal on the underside) between the bottom of the diff if you need both sides up.
Otherwise jack at any jack point if you need a corner (such as changing tires)
-M
2008 BMW M3 Coupe (White on Fox Red)
CF everything / Lowering springs / EDC / Tint
AA Short Shifter
SOLD - 1997 BMW M3 Coupe (Estoril Blue]
VFE Supercharger Stage 1
Bilstein Sport Shocks/Struts
Euro-M3 Springs
Two-Piece Euro Rotors
JVC KD-AR5500 Headunit
Euro Headlights w/ TSX Projector Retrofit and HIDs
VDO Gauges
Harmon Kardon Amplifier retrofit
18-button OBC conversion retrofit
BMW Euro (clear) corners, tails, sidemarkers
ROH RT wheels / (f) 245/40/17 (r) 265/40/17 Toyo T1R
Jump to top PhYrE is offline   Reply With Quote
Old Wed, May-21-2008, 02:55:23 PM   #8
Binzes
Stone>*
Binzes's Avatar
Reputation: 0 Binzes has disabled reputation
'nuff said.
If I started this thread feel free to troll, thread jack and be profane at your leisure.
1999 ///M3, BMW individual PINK...Like your mothers taint
Get it straight morons:
Benz = Mercedes Benz
Binz = Nickname given to me by my brothers
Busted fukcing Car Club- TheSt|G, Binzes, RaserX, zulezt
Jump to top Binzes is offline   Reply With Quote
Old Wed, May-21-2008, 03:19:21 PM   #9
Brandon318
Reputation: 0 Brandon318 is on a distinguished road
Step 1: Drive front of car onto 2x4 wood blocks to gain jack clearance.
Step 2: Place jack pad (saddle) beneath front sub-frame cross-member.
Step 3: Raise car and place jack stands underneath pucks.
Step 4: Place saddle under rear sub-frame cross-member, just forward of the differential.
Step 5: Raise car and place jack stands underneath pucks.
/// Brandon
Jump to top Brandon318 is offline   Reply With Quote
Old Wed, May-21-2008, 03:29:54 PM   #10
fitchesbass
I couldn't find the sports car of my dreams, so I built it
fitchesbass's Avatar
Reputation: 0 fitchesbass is on a distinguished road
^ +1 sounds about how I do it with a lower car.
-Derek
Prior BMWs:
E36 M3
E86 Z4MC
E92 M3
Jump to top fitchesbass is offline   Reply With Quote
e36, jacking
New M3... jacking points Loozen_it E46 M3 (2001-2006) 1 Sat, May-10-2008 05:15:49 PM
Rim Jacking TrackPro Off Topic 7 Tue, Mar-11-2008 06:19:45 PM
Jacking up the car 4getR34 E46 M3 (2001-2006) 5 Tue, Mar-11-2008 01:54:11 PM
Dateline.....I-jacking Porschetech Off Topic 1 Thu, Aug-02-2007 05:43:08 AM
Jacking up the M????? DarkVader E46 M3 (2001-2006) 2 Mon, Apr-18-2005 01:26:49 PM
Discussing Jacking up the E36 in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
