Apex Sniper
![]() Location: Calabasas
Below is a link to the dyno test results from extensive dyno test sessions I did in cooperation with Sean from Discovery Automotive, Peter Van Wingerden at HP Autowerks and Bob at Bimmer Performance Store.
This is the data that was used in the Roundel tuning article that was suppose to be in print some time back. All the dyno runs were done over the course of a two to three months on the same dyno. The peak numbers are the average of the three best pulls. As some of you are already aware, there were some issues with certain mid pipe designs causing a resonance that would force the VANOS to adjust wildly and resulted in a sharp torque drop in the lower RPM ranges. Some of you have reported this as "hesitation" and PM'd me about the problem. My understanding is that later production versions of the midpipes resolved this issue. We analyized the problem extensively, trying many combinations of exhausts and midpipe, both on the dyno and while driving onboard scan tool where we could watch the VANOS in real time. Peter, with the help of the guys at D/A and Gustav at GSP concluded that crossover location in the midpipe was the culprit. Moving the crossover location too far forward in the midpipe was detrimental to the low and mid range torque, even though it would otherwise produce a "hero" peak hp number on non-vanos cars. For comfirmation, Peter hand built a "custom" midpipe using a high grade Burn Stainless x pipe cross over. (see pics.) The final result was that we were able to maintain peak power levels and resolve the low end torque drop/hesitation issues. We also tested a "mod/straight" pipe with no crossover in it at all, this did not yield the best results even though it did solve the torque drop/hesitation issue. Further confirming the effect of improperly placed crossover. I have dozens of dyno sheets, with various layovers, rather than post them all I'll just keep and eye on the thread and see what you guys are most interested in. The dyno sheet that I posted was our best reproduceable result which shows an honest 37rwhp gain using D/A Race 91 octane software, coated CSL header, custom midpipe with Burns Stainless crossover, AFE intake, and Borla exhaust. (The UUC exhaust that was tested here, was a prototype that never went into production.) The test car is 2002 manual M3 with D/A 91 octane "race program", CSL Jet Hot coated headers, AFE intake, and the various exhuast systems, the car only had BHS underdrive pulleys. All dyno pulls including the baselines were done at A&A Corvette in Oxnard CA, 200ft above sea level. Here is a link to the spreadsheet summary... http://www.brouwersusa.com/Exhaust%20Matrix.xls
![]() Homepage Directory of DutchMan's Magazine Articles Lightweight Stereo Install Schematic Detailed Modification and Alignment Specs Big Brake Kit Excel Spreadsheet UPDATED Last edited by Fly'n DuthhMan; Fri, Apr-24-2009 at 08:05:05 PM. |
that is goodd data and test method...
amazing the loss of low end torque with some combo's |
Apex Sniper
For those of you data geeks... here is the summary of every run and configuration, including the baseline.
There are two worksheets in this file, one is a "Chart 1" visually summarizes all the data, and "Sheet 1" actually has all the data in it. http://www.brouwersusa.com/Dyno_Data...preadsheet.xls |
#4 |
![]() Location: Seattle
37whp is crazy... thats pretty impressive for just intake/headers/software/pullies/exhaust.
Motorcycling is wonderful in that way, especially racing. There's precious little bullshit when you're involved with it at the extremes. If you make a mistake, there's no blaming it on someone else-the ground comes up and slaps you right now, and no amount of smooth talking is going to buy you any more front-end grip or any more talent. Want to learn about personal responsibility? Here are the keys.
#5 |
![]() Location: Toronto
so where does that custom midpipe go? is it in section 1 or 2? im guess its in the section 1 place as you are not running cats? will we be able to get our hands on that custom midpipe ? thanks!
![]() 2005 CB ZCP 2009 SL63 AMG |
#6 |
![]() Location: NY
Very interesting as I have been thinking of putting my RDSport crossover section2 back on in favor of the SS X-pipe that's on the car now.
sig engineered by Fcukupayme |
#7 | |
![]() Location: NJ
Current ///M - 05' Silver Grey, 6spd 03' Topaz M3 and 98' R1 - SOLD
#8 |
Resident User
![]() Location: SEFLa
Are all the borla midpipes tested the v2 version (because only the last row mentions such).
Also, looking at those numbers is making me rethink my full borla catback plans (midpipe+muffler) Last edited by Mr.G3; Mon, May-26-2008 at 03:11:02 PM. |
#9 |
![]() Location: Hollywood, CA
How does a freaking mid-pipe effect the cam timing?
-Josh 2002 M3 Carbon Black 2012 Ducati Streetfigher 848 |
#10 |
![]() Location: NJ
hmmm this sounds good
midpipe goin into production ?
2002 AW/IR M3: Sold 2004 AW/Blk M3: Sold 2009 AW/FR E92 M3 |
| csl, d or a, dyno, exhaust, header, multi, results, system, test |
| Post Your Exhaust Dyno Results | Spent198 | E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013) | 18 | Tue, Jun-17-2008 04:04:46 PM |
| dyno results (kinda) and dyno question | King Luis | E46 M3 (2001-2006) | 4 | Mon, Jun-16-2008 09:31:22 PM |
| BMP Multi-throttle Intake System | Silver M3 Man | E36 M3 (1992-1999) | 14 | Wed, Apr-26-2006 12:17:00 AM |
| Dyno Results from changing Exhaust | Whirls | E46 M3 (2001-2006) | 8 | Tue, Mar-23-2004 10:25:18 PM |
| Borla Exhaust Dyno Results? Anyone?? | smiles | E46 M3 (2001-2006) | 8 | Thu, Aug-14-2003 03:55:21 AM |
