Old Mon, Jun-16-2008, 07:38:43 AM   #1
bosundave
Reputation: 0 bosundave is on a distinguished road
Default How to disable top speed limiter?
I thought this would be an easy find. But my search for "disable speed limiter" did not come up with much.
Does the Shark Injector disable the limiter? It is not advertised as doing that.
What software does the job?
EDIT: Nevermind. I did a Google search. Apparently Conforti's software DOES remove the limiter. Funny how that is not in his FAQ on his website. I wonder why?
Jump to top bosundave is offline   Reply With Quote
Old Mon, Jun-16-2008, 01:53:54 PM   #2
THATS FRESH
SSHNIPER
Reputation: 0 THATS FRESH is on a distinguished road
Dinan http://www.dinancars.com/store/Engin...p-1-c-456.html
GLENN
IMOCD
Jump to top THATS FRESH is offline   Reply With Quote
Old Mon, Jun-16-2008, 02:11:46 PM   #3
SilberFuchs
Visca el Barca!
SilberFuchs's Avatar
Reputation: 0 SilberFuchs is on a distinguished road
Most software remove the top speed limiter. You may also want to check out Discovery Automotive's software which is highly praised around the forum.
2005 TiAg/Blk M3 Coupe (6MT, Xenon, HK sound)
///Mods - performance: OE CSL airbox w/ MAP sensor, OE CSL headers (Swaintech ceramic coated) & cats, Supersprint resonated X-pipe & "Street" muffler, Schrick 280/272 cams & DLC rockers, SAP delete, ECU tune, OE CSL cabin air filter housing, Rogue Octane SSK & transmission mounts, ZHP shifter knob, hollowed CDV (Zeckhausen), Mason/GSP clutch pedal, Volk Racing CE28N 18x8.5F/9.5R wheels with 245/275 tires
///Mods - appearance: OE CSL front bumper & trunklid & diffuser, piano black kidneys & gills, Depo smoked corners, OE short center console with Euro tray, AC Schnitzer aluminum pedals, 35% tint
Jump to top SilberFuchs is offline   Reply With Quote
Top Speed of stock e46 M3 w/o speed limiter evistor E46 M3 (2001-2006) 67 Wed, Jul-01-2015 07:50:33 PM
Removing top speed limiter lucass81 E36 M3 (1992-1999) 31 Fri, Jun-19-2009 06:56:27 PM
Top speed limiter JoosyJoos E46 M3 (2001-2006) 1 Tue, Jun-21-2005 02:36:58 AM
I want to remove the top speed limiter... and do nothing else Obioban E46 M3 (2001-2006) 28 Sat, Feb-26-2005 11:05:52 AM
NA top speed limiter norris14 E36 M3 (1992-1999) 26 Fri, May-14-2004 11:38:16 AM
Discussing How to disable top speed limiter? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
