Old Thu, Jun-19-2008, 09:52:00 PM   #11
M3erz
Unregistered User..
M3erz's Avatar
Reputation: 0 M3erz is on a distinguished road
Kuwait
12mm Rear and 15mm Front
01 TopaZ/M Alcantara
Bored? Click Here!
Jump to top M3erz is offline   Reply With Quote
Old Thu, Jun-19-2008, 09:56:25 PM   #12
markomik
markomik's Avatar
Reputation: 0 markomik is on a distinguished road
Originally Posted by dpham41 View Post
Was this on stock size tires (225/255) or 245/275? I will be going with General UHP 245/275 when my PS2s wear out and will be using spacers. Just tying to find out if I will have any rubbing issues with 15mm F and 10mm R with the OEM 19' wheel/General tires/spacer combo.
Thanks.
You should be fine.
I just ordered 15mm front, 10mm rear spacers and am running 245/275 on my OEM ZCP's. I am also dropping my ride on some KW V2's. Haven't received anything yet, but based on my research there should be no rubbing. I guess I’ll find out very soon
Exterior: OEM LED Tail Lights || Umnitza Angel Eyes || VCSL Front Bumper || VCSL Diffuser || CF Emblems || Seibon CSL Bootlid || CF Gills & Grills || Smoked Corners & Side Markers
Wheels : OEM ZCP || 245/35/19 - 275/30/19 GT UHP || RE 15mm Front : 10mm Rear Spacers || RAD Locks || CF Emblems
Interior: OEM Euro Tray || OEM CSL Bootlid Liner || Ultimate Pedals || Embroidered Headrests || DICE IPod Interface
Performance: SE Air Filter || RE Power Pulleys || JVTR Headers || Custom Performance CRT || SS X-Pipe || RE El Diablo Exhaust || Suspension: KW V2 || RE RSM || PowerFlex RTABS
Jump to top markomik is offline   Reply With Quote
Old Thu, Jun-19-2008, 10:46:47 PM   #13
nrubenstein
The answer is that it depends very much on the wheels, tires, and your alignment.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison
2002 BMW M3 Alpinweiß/Black - Dinan/Bilstein, AS SSK, JBL MS-62C, IDQ-12v3, JBL MS-8
Old Sat, Jun-28-2008, 07:58:48 PM   #14
JYeo
JYeo's Avatar
Reputation: 0 JYeo is on a distinguished road
Hey, I have OEM CSL wheels and just purchased a set of PSS9 Coilovers. I am running 245 tires in front and 275 in the rear. Would it be strange to run 10mm spacers all around? I do not want any rubbing at all, and the drop on the coilovers will not be very aggresive.
I have been told to go 10mm in the rear and 12mm in the front, but I kind of wanted to go 10mm all around for simplicity sake. How would that look? Keep in mind my fronts wheels (OEM CSL) are already 0.5 inch wider than the usual ZCP wheels.
Any input at all would be appreciated!
Jump to top JYeo is offline   Reply With Quote
Old Thu, Sep-30-2010, 02:09:14 PM   #15
OU6799V
Reputation: 0 OU6799V is on a distinguished road
Spain
Then, for stock rims EVO 19'' with stock tires 225/255 and stock suspension with EVO 19'' rims which is max wheel separers size?
Jump to top OU6799V is offline   Reply With Quote
max, size, spacers, wheel
What size spacers for totally stock wheel set up but lowered Kkilo1323 E46 M3 (2001-2006) 19 Tue, May-22-2012 08:41:56 PM
10MM spacers need what size wheel bolt/ lug? AriZonaD54 E46 M3 (2001-2006) 1 Wed, Aug-13-2008 08:14:09 AM
What size wheel spacers to go with?? Diesel///M3 E36 M3 (1992-1999) 18 Wed, Jul-16-2008 07:28:18 PM
Max Wheel Size For e36 Coupe chafuro786 E36 M3 (1992-1999) 30 Wed, Jul-16-2008 06:04:02 AM
Max tire size ara7 E46 M3 (2001-2006) 6 Fri, Jul-08-2005 04:29:53 AM
Discussing Wheel Spacers, The Max Size? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
