Old Thu, Aug-14-2008, 12:25:01 PM   #11
bimmer777
I drive an AWD Turdbro
bimmer777's Avatar
Reputation: 0 bimmer777 is on a distinguished road
Ukraine
Thanks.
PS - nice pic from bear mtn.
Jump to top bimmer777 is offline   Reply With Quote
Old Fri, Aug-15-2008, 06:41:52 AM   #12
darkcrash21
///Mike
darkcrash21's Avatar
Reputation: 0 darkcrash21 is on a distinguished road
South Korea
What is the part numbers for the left and right output seals? I need to order them soon.
2002 ///M3 Carbon Black / CF interior
VF-Engineering Stage 2 ● Tial Q BOV ● Okada Projects ● AEM Water/Meth ● Stoptech BBK ST60/ST40 ● HPF Stage 1 Feramic Clutch ● HPF/Walbro Fuel Pump ● Mason Engineering F/R Strut Bar and Clutch Pedal ● Ground Control SuperStreet Double Adj Coilovers w/ Hyperco 600F/700R ● Treehouse FCAB ● UUC Rear Lower Control Arms ● Eibach F/R Adj Sway Bars ● Agency Power Headers ● CPI section 1 w/ 400cell cats ● RE X-pipe with EVC ● RE El Diablo Ti ● Platte Forme AG Rear Subframe Reinforcement ● lots and lots of other crap...
Jump to top darkcrash21 is offline   Reply With Quote
Old Fri, Aug-15-2008, 01:19:07 PM   #13
Rat Fink
Seven years of college, down the drain . . . .
Rat Fink's Avatar
Reputation: 0 Rat Fink is on a distinguished road
'taint no right and left. PN: 33107510289 qty(2)
For what's worth, here's a few pics of a naked M3 diff:
Sry, one's kinda blurry, too much coffee this morning.
Jump to top Rat Fink is online now   Reply With Quote
Old Fri, Aug-15-2008, 03:53:02 PM   #14
darkcrash21
///Mike
South Korea
thx!
So replacing the seals is pretty straight forward correct? Just pry out the old ones without scratching the diff. Press in the new ones and thats it? No extra parts needed besides the Seals?
Thanks.
Old Fri, Aug-15-2008, 04:06:08 PM   #15
matadorCE
Reputation: 0 matadorCE is on a distinguished road
what else besides the seals is needed? (ie. clips, dust boots, etc.)
Jump to top matadorCE is offline   Reply With Quote
Old Fri, Aug-15-2008, 07:09:19 PM   #16
JeST
Old Skool
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
Theres a spring clip that comes installed with the new seal. When your removing your old seal make sure the old spring comes out as well.
1988 M3 - Henna/black on black alcantara
2012 Ducati 848 Evo Corse
Jump to top JeST is offline   Reply With Quote
Old Sun, Aug-17-2008, 06:25:44 AM   #17
darkcrash21
///Mike
South Korea
do you have to drain the diff fluid before you change out the seals? I mean common sense says yes, but eh.. never did it before.
Old Sun, Aug-17-2008, 08:25:14 AM   #18
JeST
Old Skool
JeST's Avatar
China
nope no need
Old Fri, Sep-26-2008, 04:32:33 PM   #19
JeST
Old Skool
JeST's Avatar
China
Here's a link to a thread on a seal just replaced....
http://m3forum.net/m3forum/showthread.php?t=230322
Old Mon, Mar-01-2010, 11:43:59 AM   #20
DigitalPunk
Reputation: 0 DigitalPunk is on a distinguished road
Anyone know the part number for the input shaft seal?
Jump to top DigitalPunk is offline   Reply With Quote
differential, diy, output, seals, shaft
Output shaft torx bolts??? RoadyRacing E36 M3 (1992-1999) 3 Sat, Aug-30-2008 06:19:13 PM
Need help with the Output Shaft APIindy E46 M3 (2001-2006) 0 Tue, Mar-11-2008 01:38:41 AM
Leaking differential seals Terrapin E46 M3 (2001-2006) 6 Sat, Nov-10-2007 11:01:35 PM
Transmission output shaft collar nut torque epj3 E36 M3 (1992-1999) 3 Tue, May-29-2007 03:13:03 AM
K i got a problem. Output Shaft to Diff connection related Zlatko E36 M3 (1992-1999) 8 Fri, Jun-23-2006 06:13:26 PM
Discussing DIY: Differential output shaft seals in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
