| Forced Induction (F/I) Discuss the ever growing F/I options here! |
i was talking about tire damage.
yes over 18 psi, and with 4 digits at the rear wheels, wishbones have been bent, tire is damaged as shown below LEFT Wishbone, bent.... ![]() RIGHT Wishbone, bent.... ![]() |
tire damaged
![]() another shot ![]() there is no way on dynamics, so you need to strap down using the wishbones. posting these, to make sure that the tires get fried and totally useless with current power figures. I hope one person wont take these and make a thread on bimmerforums. Any M3 owners using DD, reinforce your lower wishbones. This is easy, remove your oem wishbones, and weld plates. Mert Last edited by Sertan; Tue, Jul-29-2008 at 08:22:51 PM. |
Simply Genius
![]() Location: Miami
Sorry to hear. I hope you get everything fixed.
#4 |
#5 |
took off the wishbones, and this is one of a few times where POWER/TORQUE has amazed me.
#6 |
M&M
![]() Location: PV So. Cal--> Shanghai
Mert, try dyno the car on a flat dyno, you should have more traction that way.
![]() Gone but not forgotten: 2005 Silver Grey M3 2005 Interlagos Blue M3 ZCP, AA supercharged 474RWHP (91 octane pump gas) Video: 40-120mph = 9.1 seconds (91 octane pump gas) Current rides: Daily Driver: Silver on black A6 (stock) Black on black CLK (stock) the most unreliable car i've ever own... Silver Buick 2.0T (stock) slowest car i've ever own LOL... Weekend: Black on red 997TT (stock) |
#7 | |
even a level dyno run did not improve. i am getting news from USA, from a top Supra tuner, who also approved that dyno dynamics has wheel spin on high powered cars. Mert Last edited by Sertan; Wed, Jul-30-2008 at 12:22:07 PM. |
#8 |
Yes, it's stock.....
![]() Location: NYC Area
You strapped the car in from the lower control arms? There's not supposed to be any lateral load on those pieces, for obvious reasons.
Why didn't you strap the car down from the rear jack points? There are hooks you can replace the factory pads with, and then you could strap the car down diagonally.
#9 |
Wow thats the strangest damage I have seen on a tire. Did the wheels lock up on the rollers?
Have you tried using Trackbite as used at drag races on the rollers? What size turbos are you using to produce that kind of power at such low boost? Are you measuring your boost at the intake manifold? Sorry for all the questions. |
#10 | |
Harold, according to dynamics, the tires should be pulled vertically to the rollers. By using the control arms, i can have a 90 degree vertical pull onto the rollers. when i strap as per your instruction, the car will pulled rearwards, not onto the rollers vertically. Rearwards pulling is not wanted on DD. anyway, thank you for thinking and sharing. |
| quick question regarding tire damage | brian22400 | E36 M3 (1992-1999) | 11 | Mon, Mar-24-2008 04:40:45 PM |
| Diff fluids, 83 22 2 282 583 (with FM boost) versus 83 22 1 470 080 (w/o FM boost) | gixxer | E46 M3 (2001-2006) | 8 | Thu, Nov-29-2007 04:41:13 AM |
| Front Tire Damage | ///Macht[030] | E36 M3 (1992-1999) | 37 | Wed, Aug-08-2007 08:55:16 PM |
| Dyno Day at New England Dyno & Tuning on May 3rd!! | bimmer143 | Northeast | 3 | Fri, Apr-25-2003 04:00:44 AM |
