Old Fri, Aug-08-2008, 03:24:07 AM   #1
R1blade75
04 M3 Vert / 04 R1
Reputation: 0 R1blade75 is on a distinguished road
Default Wheel Alignment, New Tires, Car Still Drifts Right
Ok Fellas, I need your input here.
http://forum.e46fanatics.com/showthr...599&highlight=
From 7/17/08
Ok fellas, I need your opinion. I’m running OEM 19” rims on my M3 and I replaced my rears with General Exclaims (275/30/19) in March 08. I did not have a problem with my car alignment while I was still running (wearing out) stock Contis in the front.
Yesterday, I had Tire Kingdom install General Exclaims (245/35/19) on the fronts and I noticed the steering wheel was shaking around 72mph. Also, the car drifted / pulled to the right side. I took my car back to Tire Kingdom to do an alignment and after 3 attempts and 2 hours later, the car still drifted to the right side. The tech told me alignment was performed correctly and the drifting could be caused by a number of reasons such as bad tires or bent arms. Since the car never drifted to the right side before, I’m guessing it might be bad tires.
Since I purchased the tires new from Tire Rack, they are going to send out a tire replacement.
Here’s my alignment numbers.
Do you guys know whether the alignment was performed correctly based on the numbers given
Update - 8/7/08
After having the car aligned by BMW and after Tire Rack resent 2 new front tires, the car still drifts to the right. I had tire kingdom switch out the front right wheel to the left and the car drifted to the left. Now, I'm perplexed to what is wrong with the car or wheels. According to both techs at BMW / Tire Kingdom, they said there is a radial pull.
Now, the question is, this will be my 2nd set of new tires from Tire Kingdom and the car stills behaves the same way. Even when I was wearing out my stock contis, the car never drifted at all.
Can anyone provide an idea to what may be causing this problem?
I don't believe I have suspesion damage as evidence.
Jump to top R1blade75 is offline   Reply With Quote
Old Fri, Sep-05-2008, 01:10:07 AM   #2
kwikieman146
kwikieman146's Avatar
Reputation: 0 kwikieman146 is on a distinguished road
pick up a cheap set of 18s with tires on em..and try it out? ...
TiAG///M3 6SP
///Dice///hyperwhite///CDV delete///Stoptech SS lines///Powerflex RTABS///BBS CH//Hardwired V1///Dinan Rear Strut Bar
Jump to top kwikieman146 is offline   Reply With Quote
Old Fri, Sep-05-2008, 02:07:00 AM   #3
Rat Fink
Seven years of college, down the drain . . . .
Rat Fink's Avatar
Reputation: 0 Rat Fink is on a distinguished road
THRUST ANGLE ALIGNMENT
Definition: Aligning front toe to the rear thrust angle instead of the vehicle's centerline to compensate for rear axle steer.
Jump to top Rat Fink is offline   Reply With Quote
Old Sat, Sep-06-2008, 07:01:40 AM   #4
M3Seeto
M3Seeto's Avatar
Reputation: 0 M3Seeto is on a distinguished road
agreed with the thrust angle issue .. Set it to zero
2004 BMW ///M3 - Alpine White | 6MT
Jump to top M3Seeto is offline   Reply With Quote
new tires mounted and wheel alignment steering wheel is not centered? supermane46m3 E46 M3 (2001-2006) 10 Thu, Apr-08-2010 03:29:13 AM
Is there really no need for a wheel alignment?... AMG_Killer E46 M3 (2001-2006) 7 Wed, Jun-11-2008 05:28:54 AM
good shop for wheel wheel alignment RanGer498 Northeast 0 Thu, Mar-01-2007 12:31:11 AM
Steering wheel alignment off after snow tires????? baltimoreM3 E36 M3 (1992-1999) 12 Thu, Feb-01-2007 11:03:46 PM
Bad alignment? Tires worn down in 3.5 months. (Alignment sheet included) UA///M3 E46 M3 (2001-2006) 10 Mon, Oct-09-2006 04:36:55 AM
Discussing Wheel Alignment, New Tires, Car Still Drifts Right in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
