#21 |
Texas 2 step
Engine looks stock - what are the mod limits in that class?
09 E90 M3 DCT | Turner Studs | RedNeck cutouts | Britax Seat | Diaper survival kit | Bassified |
#22 |
![]() Location: NJ
The Gold Reflective Film is an aerospace material capable of reflecting 78% of all radiant heat with continuous operating temperatures of 450 degrees centigrade. The material is metalized polyamide polymer laminated glass cloth with a high temperature pressure sensitive adhesive. The film is lightweight at only 5oz per square yard, and is easy to apply and remove. Typical applications include but are not limited to, engine covers, side pods, suspension, under trays/floors, seat bottoms, fire walls and bulkheads. The minimum air gap to heat source is just 1mm.
Gold Reflective Film forms to any shape, is far more reflective with greater weight saving and is preferred over aluminized cloth and waffle board. CONSTRUCTION: Metallized polyimide film laminated to glass cloth with high temperature acrylic adhesive protected by a release liner. FEATURES: Excellent heat reflective characteristics and is easy to install. Withstands 675°F of radiant heat for a minimum of 8 hours PROPERTY VALUE* TEST METHOD: Thickness w/o liner .0065” +/- 10% ASTM-D-3652 Adhesion off stainless steel 32 oz/inch of width min. ASTM-D-1000 Weight w/o liner 5.04 oz / sq yd LTM 25A UV Stability of Adh: Excellent Color: Gold Shelf Life: 1 year when stored under conditions of 70 degrees F. (21 degrees C.) and 50% R.H. Adhesive residue removal: Any adhesive residue remaining after removal of Gold Racing Tape can be dissolved using MEK, toluene or gasoline *Values are not intended for Engineering Specifications. Before using, user shall determine the suitability of the product for his intended use, and user assumes all risk and liability whatsoever in connection therewith. Seller assumes no liability beyond the replacement value of material. Priced per 12"x24" adhesive backed section. The 8 hours is where I got mixed up. You usually hear that there is a maximum amount of time that something can be in contact with radiant heat, not a minimum time. Available at bimmerworld.com http://store.bimmerworld.com/shared/...immerworl&All= |
#23 |
Established 1998....
![]() Location: Al Manama, Bahrain
cool! I want some
EURO 04 M3 Current Mods: GC DA's, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II + Alpine KCA-420i, Black Roundels, ///MFEST Badges, Depo Corners, M5 SMG Knob, Screen protector for OEM 16:9 display, VCSL: Bumper + Race Lip, CF Trunk, CF Diffusor, DIETZ TV in Motion, AP Headers, RT Cats, SS Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, GM SMG Paddles, OEM CSL Steering, OEM CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R Projectors + 3k D2S, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears Soon To come.....OEM CSL Roof, Inner Projectors ........ ![]() |
#24 |
Can anyone tell me how much im gona need to order as they sell 12"x 24" sheets. I need enough to cover my manifold and OEM airbox
Thanks.
#25 |
Old Skool
![]() Location: Zoo York
I'll get dimensions for you on Friday.
1988 M3 - Henna/black on black alcantara 2012 Ducati 848 Evo Corse |
#26 |
Back home in Jersey
![]() Location: Central Jersey
Then you must have the money! b/c thats the first thing I would've said I'm short on
Just pay someone for the time and material ![]()
2002 Topaz/Black M3-Slicktop-SMG: OEM CSL Bootlid, Mini-CSL Battery, TMS Pulleys, Stoptech SS Lines, Borla muffler & Midpipe, Hotchkis Sways, Eibach Springs, RE RSMs, PowerFlex Rtabs, PowerFlex Subframe Bushings, TMS Subframe Reinforcement, Blk Grills, Blk Side Gills, VCSL Center Console, Euro Front Bumper, Hamann Fog Ducts, ACS Lower Lip Spoiler, FUCY Rear Diffuser, LED Tail upgrade w/ outer ring mod, D/A street software, RPI Scoops, e92 m3 18" rims w/ PS2s
#27 |
Back home in Jersey
Pretty interesting stuff though. I'm sure some big turbo guys who can suffer from heat soak could benefit from this. Playing off that, I wonder how it would work on end tanks on intercoolers or something like that
#28 |
Old Skool
Turbo's have turbo blankets and exhaust manifolds has it's own heat wraps. You can use this stuff on everything else though.
#29 |
JeST, Wicked thanks Bro! Will order once i get the info from you. Thanks
#30 |
| extra, gold, intake, manifold, material, spare |
| Help! Intake Manifold | Superman#1 | E46 M3 (2001-2006) | 3 | Tue, Feb-12-2008 02:27:56 PM |
| Intake Manifold Pressure | dotgoner | E46 M3 (2001-2006) | 4 | Tue, Nov-20-2007 05:37:19 PM |
| Fs: Oem Intake Manifold And Stock Intake | NM3FAN | Parts for Sale/Wanted | 0 | Mon, Sep-24-2007 08:04:43 PM |
| Intake Manifold?????? | Fabiolous10 | E46 M3 (2001-2006) | 12 | Fri, Jun-01-2007 08:29:41 PM |
| Intake manifold Qs | park828 | E36 M3 (1992-1999) | 12 | Fri, May-14-2004 07:00:55 PM |
