Old Thu, Oct-02-2008, 09:56:45 PM   #1
FiftyPenceM3
Fund Accountant
Reputation: 0 FiftyPenceM3 is on a distinguished road
Guernsey
Default DIY How-To : How to remove and dismantle BMW M3 Side Mirrors
First we will use the following link to remove the doorcard:
http://forum.e46fanatics.com/showthr...ghlight=rattle
Screws are in red, plastic clips in white. Photos courtesy of paraklas of e46********.com in regard to the doorcard removal procedure
I left the door handle, speakers etc all connected.
Remove the mirror plug from the control box
Remove the two bolts from the mirror and pull the rubber grommet and wiring harness through
Dismantling Process for BMW E46 M3 Side Mirrors
Tools required:
T15 Torx screwdriver
Pliers
A little determination
First we will look at the parts:
Overview:
All Parts
The Baseplate
Baseplate aperture from inside, the wiring harness passes through here
Here we can see the wiring harness passing through the baseplate aperture and the screws which hold the motor in place
Foam piece which attaches to the baseplate
Mirror Glass Mount
Motor and Wiring Harness
The fixings which all have a T15 Torx head
Onto the process:
Here we see the mirror housing with the glass removed. The three screws which hold the glass mount are clearly shown
On removing the glass mount we find the backing/cover plate with the 5 screws clearly marked:
On removing the backing plate we find one final screw:
The motor mechanism can then be removed from the mirror housing through the aperture
Next we will look at the baseplate
Baseplate aperture with wiring harness passing through also showing screws
Remove the two screws which hold the motor to the baseplate and unhinge the motor from the baseplate. This picture shows the ridge on the motor which acts as a hinge
Next, pull the wiring harness through the baseplate aperture as much as possible and poke this rubber grommet into the aperture and pull through with pliers
You will now be left with the baseplate on its own, here is a picture of the aperture, note the holes above the two X marks, the mounting screws pass through here.
And the motor and wiring:
Close-up of the motor which is externally the same on both manual-folding and electric-folding mirrors. Just the internals and of course the weight are different. The screws holding the motor together are T10 torx
Jump to top FiftyPenceM3 is offline   Reply With Quote
Old Thu, Oct-02-2008, 10:01:31 PM   #2
steeezm3
steeezm3's Avatar
Reputation: 0 steeezm3 is on a distinguished road
Great DIY!
I thought you were asking a question then we'd get a bunch of replies like this
Steve,
2011 ZCP E92 | 1998 Integra Type R #0563 (track)
Past: 05 M3 (x2) | ITR (x2) | 00 NSX
Jump to top steeezm3 is offline   Reply With Quote
Old Thu, Oct-02-2008, 10:06:37 PM   #3
FiftyPenceM3
Fund Accountant
Guernsey
Haha, if it were a question I would have put a question mark at the end of the thread title
I hope someone finds this useful.
I just swapped out my manual folding mirrors with electric folding mirrors by swapping the internals as I was fortunate enough to locate some brand new genuine OEM electric folding mirrors on eBay which were painted silver/grey. I have a TiAg M3 so just swapped the internals and will sell on the silver/grey manual folding mirrors.
Old Thu, Oct-02-2008, 10:20:30 PM   #4
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
thanks for the write up but what is this blue wire? why is it not connected?
Tischer aka GetBmwParts
Old Thu, Oct-02-2008, 10:27:40 PM   #5
FiftyPenceM3
Fund Accountant
Guernsey
On removing the wiring harness and motor from the baseplate this wire got caught and stripped the whole way through while I was struggling to get the rubber grommet through the aperture. It is not meant to be like that and will just be soldered back together.
I have placed this in the correct DIY section.
Old Fri, Oct-03-2008, 12:19:51 AM   #6
castaway
castaway's Avatar
Reputation: 0 castaway is on a distinguished road
Poland
awesome write-up. i will be giving this a shot in the next few weeks.
2003 ///M3 6MT
Steel Gray / Imola
Jump to top castaway is offline   Reply With Quote
Old Fri, Oct-03-2008, 03:25:55 AM   #7
gtb5
gtb5's Avatar
Reputation: 0 gtb5 is on a distinguished road
Hong Kong
Wow thanks it would help my installer to know more about the installation when I do get the carbon mirrors.
GC07 - CSL - TE37 - OEM - 547R - C22- 565R
8-year-old M3 is sold!!
Jump to top gtb5 is offline   Reply With Quote
Old Mon, Oct-27-2008, 01:58:01 AM   #8
greys
Reputation: 0 greys is on a distinguished road
removing the door panel is very useful.
i was just wondering what the yellow was for?
on a scale of 1-10 with 10 being the hardest, how hard is it to remove the door panel?
Good stuff,
Chris
Jump to top greys is offline   Reply With Quote
Old Mon, Oct-27-2008, 12:50:38 PM   #9
nuc1
Meh
nuc1's Avatar
Reputation: 0 nuc1 is on a distinguished road
Good stuff,
Chris
First time probably a 2. After that, about a .5. So your first side will be a PITA, the other side of the car cake. There is a very good DIY over on e46fanatics that can supplement the one in this thread if you need extra help/pictures.
Remember to pull UP first on the inside mirror plastic cover of you will be buying a new one....
Mike
02 TiAg/Black 6MT
Go
- BW CSL Intake - Dinan ITBs - Ported & Polished Head - Schrick 288/280 - ARP Head/Main/Rod Bolts - Epic Rod Bearings - CP Pistons - Beisan VANOS - Okada Coils - SS V1 Stepped Headers & Catless Sec 1 - OEM Sec 2 - AA Gen 6 Sec 3 - OEM CSL MAP & Pressure Rail - CSL Software - 4.10 Polished Diff - TTFS Tune
Stop
- Brembo 355F/345R - Stoptech Pads (Street) - GC Street/Track SA 525/550
Show
- OEM Euro Front Bumper - OEM CSL Trunk - Polished OEM 19s - OEM Euro Folding Mirrors - OEM LEDs w/ BFD - Sunroof Delete - Dynavin - JL 12W6 - JL 300/2 & 500/1 - Focal K2P
18 Acura MDX White/Black Family Truckster
11 Tundra Super White/Black Actual Truckster
Jump to top nuc1 is offline   Reply With Quote
Old Mon, Oct-27-2008, 01:39:06 PM   #10
FiftyPenceM3
Fund Accountant
Guernsey
The following link was included within my original post to give you a detailed how-to on removing the door card. Please read the original post thoroughly.
Many thanks to the OP on E46fanatics for the door card DIY.
My Electric Folding Mirror DIY
Completed mods: OEM CSL Trunk, Diffuser & Wheels, EAS Aurora Angel Eyes, Bimmian & 42 Draft Designs interior & licence plate LEDs, Ultra LEDs parking lights, Hoen-USA xenon-match foglights, Eibach 15F/5R spacers, Rogue Engineering Lightweight Aluminum adjustable rear control arms, OEM CSL Front brake discs, rear M3 replacement discs & Axxis Ultimate pads, Eurosport Designs Straight-cut exhaust tips, KW v2 Coilovers, Rogue RSMs, Kenwood DNX-8220BT Double DIN HU, Autolumination.com Eagle Eye 5 reversing bulbs
For Sale in Classifieds:, GrafxWerks Illuminated Door Sills
My M3 is an ex-Military vehicle as confirmed by my dealer!
bmw, dismantle, diy, howto, mirrors, remove, side
DIY How-To Remove and Dismantle BMW M3 side mirrors for Electric Folding Swap FiftyPenceM3 Faults, Fixes and DIY 11 Sat, May-16-2009 05:33:57 AM
DIY on how to remove the MAF? ggolamco E46 M3 (2001-2006) 9 Tue, Apr-03-2007 10:05:03 PM
how to remove the passenger side (side curtain) airbag dtm996c5 E46 M3 (2001-2006) 1 Sun, Dec-24-2006 04:27:38 PM
Christmas DIY #1: Peanut Butter Side Moldings (gratuitous pics of DIY and me) Teh_Ginger E36 M3 (1992-1999) 43 Thu, Dec-21-2006 05:22:01 PM
?? Side mirrors steeltoe02 E46 M3 (2001-2006) 2 Wed, Sep-18-2002 05:30:41 PM
Discussing DIY How-To : How to remove and dismantle BMW M3 Side Mirrors in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
