#31 |
Pizdous
![]() Location: Pompano Beach
had the same thing happened to me.. turned out to be bad gas...
![]() 2004 Carbon Schwarz M3 8000k Hids Dixis titanium Spirit exhaust Tein S-tech K&N 63 fipk |
#32 |
Unregistered User
![]() Location: Conesus Lake NY
Okay, my bad...the original code I posted was erroneous. E 10 is a communication error of the OBD with the car. I had the key in the 1st position, should have been in second.
I had the following codes: 1b 8C C4 63 Translation: 1) Engine noise too high 2) Misfire Cyl #1 3) Control unit self-test. Safety concept master check I have no idea what this means, somebody drop some knowledge. The cylinder misfire is scaring me. Update: I have been looking on the Google, and it seems cyl misfiring may be a function of my Bremi ignition coils. I had mine replaced (I think) on a service bulletin and it says that it is warrantied to 8 yrs/unlimited mileage for that problem. Could this be the cause of the craziness? If so, my stealer should honor it--hopefully.
2001 M3|2004 NSX|2005 RR HSE WM Last edited by ozone; Fri, Oct-24-2008 at 03:51:33 AM. Reason: Update |
#33 |
Unregistered User
Bump for some help. Could it be the ignition coils? Something else?
2001 M3|2004 NSX|2005 RR HSE WM |
#34 |
Unregistered User
Bump again. Can somebody help me interpret the codes on post #32?
#35 |
Unregistered User
OK, final bump before I head to Fanatics for troubleshooting.
| engine, high, light, rpms, turned |
| engine sounds different at high rpms | donileo | E46 M3 (2001-2006) | 4 | Wed, Oct-24-2007 01:43:25 PM |
| High RPMS | 1FASTLSB | E46 M3 (2001-2006) | 12 | Mon, Sep-10-2007 06:26:12 PM |
| SMG Bang on 1,2,3 in high RPMs | islavov | E46 M3 (2001-2006) | 17 | Fri, Aug-18-2006 07:53:59 PM |
| Slight Hesitation High rpms | Rated///M | E46 M3 (2001-2006) | 21 | Fri, Jun-23-2006 02:14:28 PM |
| high rpms | Kerplunk | E36 M3 (1992-1999) | 7 | Wed, Nov-19-2003 02:45:06 AM |
