Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Garage > M3 Car Care and Detailing
M3 Car Care and Detailing Place to discuss keeping your M looking its best.
Old Mon, Oct-27-2008, 06:14:18 PM   #1
mocheen
mocheen's Avatar
Reputation: 0 mocheen is on a distinguished road
Default How do you remove hardened tree sap from roof?
I parked under a tree on a hot day and now there is tree sap on the roof of my car. I tried to wash and wax it off, but it is hardened. I almost want to try and crack it off, but I am afraid to scratch up my paint. I even tried bug and tar remover, but it did not work either. Any suggestions?
Black 19" HRE 441R wheels, AA Exhaust, Rogue rasp eliminator,Dinan Stage III Software,Dinan Stage 2 suspension, Dinan front and rear Strut Bars, Dinan Cold Air Intake, Dinan Floor Mats, UUC SSK, UUC Carbon Pedals,EAS black carbon interior, Orion V2 Angel Eyes,led license plate lights, Clear Bra, Depo Smoked Corners,smoked side markers,black kidney and side grills,OEM led tail lights,tint all around,Vorsteiner full carbon rear diffuser, Strassentech Replica front lip and Painted Bumper Reflectors.
Jump to top mocheen is offline   Reply With Quote
Old Mon, Oct-27-2008, 06:25:15 PM   #2
B///MW
Criss Of Arabia...
B///MW's Avatar
Reputation: 0 B///MW is on a distinguished road
Ohhh dude that's hard to remove, why not try scratching it with you finger carefully and wax the area right away??
Nom Nom Nom
Jump to top B///MW is offline   Reply With Quote
Old Mon, Oct-27-2008, 07:50:48 PM   #3
Ninja K
FUBAR
Reputation: 0 Ninja K is a jewel in the rough
Somalia
Try claybar. Remember to use alot of the lube spray that's usually provided in off the shelf packs.
Please don't ban me
Jump to top Ninja K is offline   Reply With Quote
Old Mon, Oct-27-2008, 08:13:18 PM   #4
YemThwee
YemThwee's Avatar
Reputation: 0 YemThwee is on a distinguished road
The Bug'n'Tar remover will work. DONT try to scratch it off with your nails. Keep applying the product - leave it on for a bit and keep rubbing it. It will eventually come off. Scratching might damage the paint if you get too close to the coat...
GL
Jump to top YemThwee is offline   Reply With Quote
Old Tue, Oct-28-2008, 01:18:16 AM   #5
chicagobob
Dr. Law
chicagobob's Avatar
Reputation: 0 chicagobob is an unknown quantity at this point
3M adhesive remover.
Bobby
e46 M3 JB/IR, BBS RGR w/ Michelin Pilot Super Sports, Dinan Stage 1, Dinan Exhaust, UUC Motorwerks Rasp-X, Huper-Optik tint, Depo Smoked, Body painted corners w/ license plate delete, V-CSL trunk, ZHP Shifter, Alcantara Boot and E-Brake, Pioneer AVH-5300BT w/ Navi, Focal Solid 4 running 165 KRX2 all around, MB Quart ONX1.1500D w/ 12" Diamond Audio Hex Pro 12", V1 Hardwired, Cheetah GPS, Blinder M-20 Xtreme, Powerflex RTABs.
Looking for Jet Black CSL front bumper and Diffuser. PM me if you got em.
Jump to top chicagobob is offline   Reply With Quote
Old Tue, Oct-28-2008, 07:08:02 AM   #6
Jasoncor
Grumpy Young Man
Reputation: 0 Jasoncor has a spectacular aura about
that usually scratches the paint
Jump to top Jasoncor is offline   Reply With Quote
Old Tue, Oct-28-2008, 12:41:49 PM   #7
TOGWT
Reputation: 0 TOGWT is on a distinguished road
United Kingdom
Tree Resin (Sap):
(Appears like a dark brown/ red coloured raised surface mark) some of the most common resinous tree sap types are: White Pine, Walnut (also secretes an oily residue) Maple, Oak, Popular, and Blue Spruce, none of which are water soluble, the acidic content of the sap will etch the paint surface; causing a concave surface.
A lot depends upon the type of sap, which is actually an acidic resin emitted from the tree, the resin deposits can be removed by allowing one of the following to dwell on the resin for approx five mins; Isopropyl alcohol (IPA), a safe solvent like Stonerís Tarminatorô, or turpentine (especially effective on pine resin) which is made from tree resin, in severe cases it can be used to break down the resins in tree sap, use as a last resort only and use sparingly and do not rub hard and give it some time to work (dwell) use detailerís clay to remove any surface debris once resin is removed.
Once you remove the sap deposits, the paint or clear may be cracked, which may entail some expensive refinishing. Factors as to the amount of time it takes to remove sap and what damage it has caused are dependent on temperature and time the sap has been on the paint surface. Be careful and take your time removing it, remember always let the products do the work for you.
Tree sap that is still soft can be removed by soaking with Isopropyl Alcohol (or Stonerís Terminator) wet the area with the product and allows it to remain on the surface for 3-5 minutes, then wipe with soft dry towel. For tree sap that has hardened, carefully scrape the top of the spot off with a plastic razor blade to expose the softer sap inside.
Jump to top TOGWT is offline   Reply With Quote
Old Tue, Oct-28-2008, 03:36:23 PM   #8
tommiboy08
tommiboy08's Avatar
Reputation: 0 tommiboy08 is on a distinguished road
hand sanitizer
Jump to top tommiboy08 is offline   Reply With Quote
Old Mon, Nov-03-2008, 10:47:33 PM   #9
mocheen
mocheen's Avatar
Thanks for the tips. I will try it out this weekend.
hardened, remove, roof, sap, tree
tree sap. jerrym M3 Car Care and Detailing 1 Wed, Mar-07-2007 02:53:27 AM
Tree sap sadclown M3 Car Care and Detailing 6 Mon, Sep-04-2006 10:09:21 PM
Tree sap/bird **** on roof e46er M3 Car Care and Detailing 8 Mon, Oct-10-2005 11:28:06 PM
Tree Sap on Convertible top. SOURCE1064 M3 Car Care and Detailing 6 Tue, Oct-04-2005 12:48:39 PM
Tree Sap Removal Trick!!!! mfree E36 M3 (1992-1999) 8 Sat, Aug-06-2005 01:53:43 PM
Discussing How do you remove hardened tree sap from roof? in the M3 Car Care and Detailing Forum - Place to discuss keeping your M looking its best. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
