![]() Location: North Jersey
So I have a noise coming from my M3 that I am stumped on and need some help to diagnois.
I have a single "pop" sound coming from the front right or front left side of the car either when I turn the steering wheel almost full lock to the right or full lock to the left. I also sometimes hear the noise when I'm going over bumps or dips on the road. The noise is predominantly coming from the front right side but the front left side also makes the noise sometimes. I can't really describe the noise, but it sounds like the "pop" sound you hear when you lower your car after it's been jacked up and the spring settles on the perch. I've inspected my wheel bearing and there is no play in the front wheels. I've disconnected my sway bar and tried driving, but the "pop" sound is still there without the sway bar connected. When I jack up the car and turn the steering wheel full lock, there is no noise. The noise only occurs when there's weight on the wheels. OK, I should clarify. The suspension is modified, I am running Ground Control D/A Coil Overs and Dinan Sway Bar. I'm pretty much stumped on this one and would appreciate any suggestions. Thanks.
2006 M3 ZCP NASA NorthEast Region Time Trial TTB Class Last edited by TrackMastaFlex; Sun, Nov-16-2008 at 04:30:17 AM. |
it could be the inner control arm bushing has developed play...
control arm, where it connects to the subframe....i had mine develop play...and every time i would roll back out of the garage....click.
its the sound of virgins losing their viginities when you roll by! lol
but yeah lets us know if snooks right, good piece of info! |
#4 |
another thing...stock suspension or aftermarket? camber plates?
#5 | |
![]() Location: Boston
![]() '04 Dinan M3 JB on cinnamon, Torque wins races horsepower sells cars |
#6 |
2006 M3 ZCP NASA NorthEast Region Time Trial TTB Class |
#7 |
lucky_doggg7
![]() Location: Lake Forest
Check the coil spring to make sure it is seated in the perch correctly. Good luck.
#8 |
Why so serious?
Did you resolve this issue? I'm having something similar and my indy tech can't seem to locate it. Everything is tight in the front suspension. Everything is stock, no suspension upgrades.
| pop, sound, strange |
| "strange" feeling with SMG....gonna really make me seem like a noob.... | shadowless | E46 M3 (2001-2006) | 17 | Thu, Mar-13-2008 10:35:54 PM |
| What is this whole "Pop your collar" nonsense? | EKaru | Off Topic | 49 | Wed, Feb-20-2008 02:07:45 AM |
| "POP" sound from rear coils???? | STALKER | E46 M3 (2001-2006) | 28 | Thu, Apr-26-2007 01:39:21 AM |
| """"""""1st Mini M3 Meeting in Qatar"""""""""" | Silver///M | Member Photos and Videos | 34 | Mon, Dec-25-2006 05:57:32 AM |
| strange "pinging/noise" when...... | Carlos Trahin | E36 M3 (1992-1999) | 3 | Thu, Oct-23-2003 06:31:36 PM |
