Old Sun, Nov-16-2008, 10:19:56 PM   #1
xM P0W3Rx
lovin life
xM P0W3Rx's Avatar
Reputation: 0 xM P0W3Rx is on a distinguished road
Default Parking brake...What parking brake?
So an hour ago I went quadding with a friend and when it came time to the ATV's away my car was in the way of where we keep them. I move my car up a few feet and than continue to put my ATV away. When my friend an I finish we come back to his driveway to see my car is gone!...across the street up a small incline and in a pile of leaves lies my car. I run over their to evaluate the damage...I am unbelievably lucky seeing my friends driveway isn't a usual driveway and has two big rock walls on each side and to see that no damage was done. My car was half way in the street and was holding up a lot of traffic which resulted in a few phone calls to the PD. All in all I'm very lucky my M is still Ming without any known damage. Just thought id share.
Are our parking brakes a little weak or is it just me?
NYC Valve Adjustments
My Reviews
Your resident supercar salesman.
Ferrari Lamborghini Koenigsegg Zenvo Bugatti
Jump to top xM P0W3Rx is offline   Reply With Quote
Old Sun, Nov-16-2008, 10:33:16 PM   #2
JeST
Old Skool
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
Remove your rear brakes and check the parking brake pads. It should take about 3-4 clicks before the parking brake start to get really tight and hold the car.
If it only requires a slight adjustment you can just tighten down the 2 11mm nuts at the base of the ebrake handle. If it's really loose I would not recommend this as you'll cause excess strain on the ebrake line and you'll risk snapping the line.
If it's too loose lift the rear of the car in the air. Remove the wheels and look through the lugbolt holes. You'll see the star adjustment for the ebrake pads. I usually adjust until the pads are keeping the rotor from rotating then i'll back off a few turns. Then after that's done i'll adjust the ebrake line.
1988 M3 - Henna/black on black alcantara
2012 Ducati 848 Evo Corse
Jump to top JeST is offline   Reply With Quote
Old Sun, Nov-16-2008, 10:48:10 PM   #3
xM P0W3Rx
lovin life
xM P0W3Rx's Avatar
Thanks, Ill have to do that. My brake doesn't get tight until the very top.
My Reviews
Old Sun, Nov-16-2008, 10:58:39 PM   #4
LightWerkz
Automotive Lighting Innovations
LightWerkz's Avatar
Reputation: 0 LightWerkz is on a distinguished road
always park it in gear, the parking brakes suck on these things
Caesar Rowinski - LIGHTWERKZ
2009 BMW M3 Sedan - Space Gray
FS: PFC Pads
Jump to top LightWerkz is offline   Reply With Quote
Old Sun, Nov-16-2008, 10:58:55 PM   #5
JeST
Old Skool
JeST's Avatar
China
If it doesn't get tight until the top do the longer step. You won't be able to get away with just tightening down the 2 11mm's at the parking brake. I'd check to see how much parking brake pad life is left first though.
works great for me.
Old Sun, Nov-16-2008, 10:59:28 PM   #6
C M3 FLY
C M3 FLY's Avatar
Reputation: 0 C M3 FLY is on a distinguished road
+1
Before I bought my current 02 E46 M, I was going to purchase an 04 which the dealer let me keep for 3 days. That car had a weak e-brake and I thought it was just that car, but when I got my 02- it was the same case. Then I thought it was just my cars, but I met up with another forum member a while ago and his e-brake was in the same shape....
Depo///Vorsteiner///Rogue Engineering///Tein///H&R///Optima///Turner Motorsports///Bilstein
MY M3 IS FOR SALE..............
http://www.m3forum.net/m3forum/showthread.php?t=256964
Jump to top C M3 FLY is offline   Reply With Quote
Old Sun, Nov-16-2008, 11:03:18 PM   #7
LightWerkz
LightWerkz's Avatar
works great for me.
And we are glad it does. Obviously a properly adjusted ebrake should work 100%.
As a precaution though, its a better idea to leave it in gear and use the parking brake. Most people dont realize they have an issue until their car starts to roll down the street.
Seems to be a common issue.
FS: PFC Pads
Old Sun, Nov-16-2008, 11:05:08 PM   #8
ohnoes
Reputation: 0 ohnoes is on a distinguished road
True, but there are times when you can't, such as when getting out of the car really quickly with the engine on.
Jump to top ohnoes is offline   Reply With Quote
Old Sun, Nov-16-2008, 11:08:41 PM   #9
JeST
Old Skool
JeST's Avatar
China
I'm glad your happy, but sarcasm is lost on me. Maybe you need to properly adjust yours
Old Sun, Nov-16-2008, 11:10:22 PM   #10
LightWerkz
LightWerkz's Avatar
Mine feels great After I caught it rolling down the street and adjusted the crap out of it!!!!!
FS: PFC Pads
brake, brakewhat, parking
Parking brake problem phantom3 E36 M3 (1992-1999) 3 Sun, Dec-30-2007 05:40:09 PM
This is why you should always set the e-brake after parking! torresmd E46 M3 (2001-2006) 74 Mon, Apr-02-2007 11:55:19 PM
parking brake bypass billsm3 Audio/In Car Entertainment (I.C.E.) 1 Thu, Aug-31-2006 01:55:40 PM
Parking brake worn out SilverStallion E46 M3 (2001-2006) 1 Fri, Jan-13-2006 04:40:10 AM
Parking Brake TOKU E46 M3 (2001-2006) 5 Fri, Apr-12-2002 03:37:00 AM
Discussing Parking brake...What parking brake? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
