Old Wed, Dec-03-2008, 03:58:24 AM   #1
wally828
Reputation: 0 wally828 is on a distinguished road
Default Tire Pressure
I just put 245/35-19's (front) and 275/30-19's (rear) on my car, and I'm wondering what the ideal air pressure would be for the tires. I got them mounted/balanced/installed somewhere, and the guy told me that he inflated the tires to the specifications of what the car calls for inside the door jam. Being that I have different size tires (and now different size wheels since I went from factory 18's to factory 19's), would this air pressure rating now change? The guy said it stays the same no matter what wheels and tires you put on, which I find hard to believe since all tires are different sizes. Any help here?
Jump to top wally828 is offline   Reply With Quote
Old Wed, Dec-03-2008, 04:02:53 AM   #2
delirium45
Bottom Feeder
Reputation: 0 delirium45 is on a distinguished road
check the door jam... it tells you what to run for tire pressures. different size doesn't matter... its PSI (pounds per square inch)
_ Garrett
2011 Rocky Mountain Region GTS4 champion & "Rookie of the Year"
2012 Rocky Mountain Region GTS3 champion
2013 National GTS3 - 4th place
Thanks Sponsors: SCR Performance
Jump to top delirium45 is offline   Reply With Quote
Old Wed, Dec-03-2008, 04:09:23 AM   #3
Archimedio
Major Infractioner
Archimedio's Avatar
Reputation: 0 Archimedio is on a distinguished road
The only pressures the door jam on my 05 shows are the super high (41/48 IIRC) pressures for a fully loaded car with weight in the trunk, not for normal 1-2 passenger driving. Those are much lower. Don't go by the door jam. Look in your manual.
Jump to top Archimedio is offline   Reply With Quote
Old Wed, Dec-03-2008, 04:11:51 AM   #4
wally828
so you're saying whether I have 18's, 16's, or 19's on my car, the air pressure is still going to be what BMW calls for? I just feel like there's different amounts of air that could go into a tire due to it's size/area.
Old Wed, Dec-03-2008, 05:05:37 AM   #5
delirium45
Bottom Feeder
Oh sorry, i've personally never checked the door jam... i just knew that had some of that info there... i guess that is for the fully burdened vehicle. Then yes, owners manual.
And yes, unless you are deviating far away from the OE sizes i would run the recommendation in the manual.
_ Garrett
Old Wed, Dec-03-2008, 05:42:57 AM   #6
zemperaye
zemperaye
zemperaye's Avatar
Reputation: 0 zemperaye is on a distinguished road
On your tires it will say max PSI. Do not set it to that. More than likely its like 50-55 or so PSI max. I would go with something in the low 40s.
Jump to top zemperaye is offline   Reply With Quote
Old Wed, Dec-03-2008, 05:46:19 AM   #7
yaja23
M Addict
yaja23's Avatar
I usually do 36 / 38.
Old Wed, Dec-03-2008, 12:38:07 PM   #8
JerseyShoreM3
E . ` ' / . F
JerseyShoreM3's Avatar
Reputation: 0 JerseyShoreM3 is on a distinguished road
Wow...
That must be a joke.
Jump to top JerseyShoreM3 is offline   Reply With Quote
Old Wed, Dec-03-2008, 01:34:46 PM   #9
tenfifteen
Pale Geek Rigour
tenfifteen's Avatar
Reputation: 153 tenfifteen is a splendid one to beholdtenfifteen is a splendid one to behold
I don't have my car handy, but I believe the door sill (jamb, whatever) has 33f/38r recommended pressure for the ZCP (225/255). I'll check the car when I get back to the train station tonight.
I asked Continental about the appropriate pressure when moving up to a 245/275 from stock. Their response:
I have received correspondence from our product engineer and here is his response:
The best answer we can give is to try to match the load carrying capacities. If we do that, then there is no change in load carrying capacities between the sets - and therefore no change in inflation pressure.
Sincerely,
Continental Tire North America Inc.
Customer Relations
Jump to top tenfifteen is online now   Reply With Quote
Old Wed, Dec-03-2008, 04:22:36 PM   #10
gpoints
elitist D-bag
gpoints's Avatar
Reputation: 0 gpoints will become famous soon enough
for the most part, psi is personal preference. I run 42F/40R on 245/275's. As long as you're somewhere between the door jam #'s ans the max psi, you should be fine.
There are stupid threads and stupid people. Stupid people are the ones who make, stupid threads.
I run 87 octane because they don't make anything lower.
Starting OR Posting in these threads will make your car slower:
Which rims Should I buy?
Which color ___ looks best?
Where can I buy this wing?
Why don't other owners wave at me?
Jump to top gpoints is offline   Reply With Quote
pressure, tire
Tire Pressure aks753 E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) 3 Sun, Jun-01-2008 03:23:32 AM
Tire Pressure Monitor - How does it work? - Sensor in the tire? 04E46conv E46 M3 (2001-2006) 8 Sat, Oct-13-2007 02:14:04 PM
tire pressure.. czechm3out E46 M3 (2001-2006) 14 Sat, Apr-23-2005 11:11:03 AM
Tire Pressure rodneyr E46 M3 (2001-2006) 1 Fri, Dec-27-2002 09:34:18 PM
Discussing Tire Pressure in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
