Old Sat, Dec-06-2008, 01:00:40 PM   #1
samer110
samer110's Avatar
Reputation: 0 samer110 is on a distinguished road
United Arab Emirates
Default E60 M5 brakes fitting on E46 M3
I have a complete set of used front and back E60 M5 brakes that I got for free, I was wondering if anyone managed to get the kit installed on an E46 M3. I tried to google it but no luck, has anyone come across someone who has done that? and if so do you know what parts they required to make it work?
If I can have this to work I would save myself tons of cash on BBKs...
Jump to top samer110 is offline   Reply With Quote
Old Sat, Dec-06-2008, 02:18:22 PM   #2
nrubenstein
You'll need custom caliper brackets. The center bore on the rotors is wrong, so you'll want to stick with stock M3 rotors. Measure the thickness and see if it is compatible.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison
2002 BMW M3 Alpinweiß/Black - JBL MS-62C, IDQ-12v3, JBL MS-8
1989 325is Alpinweiß/Black - S50B30, GC/Koni, Sways, BBS RX, Hybrid C61-2, Sundown SA-12, JBL MS-8
1989 M3 Alpinweiß/Black - S50B32. 321hp.
Hers: 1996 Porsche 911 Turbo Black/Black
Hers: 1988 325iX Coupe Diamondschwartz/Black 5spd - Korman lengthened front driveshaft, Cam, Bilstein, H&R Sport, snow chains.
Jump to top nrubenstein is online now   Reply With Quote
Old Sat, Dec-06-2008, 02:26:40 PM   #3
babydevilj
Sperm Dispenser
babydevilj's Avatar
Reputation: 0 babydevilj is on a distinguished road
Won't work. Tried it. Not cost efficient.
Jump to top babydevilj is offline   Reply With Quote
Old Sat, Dec-06-2008, 02:40:27 PM   #4
Jeffxxx
LSB FTW
Jeffxxx's Avatar
Reputation: 11 Jeffxxx is on a distinguished road
I have M6 rear brakes and they took a lot of work to put on. Don't know about the fronts.
Featured in the August issue of Performance BMW
Jump to top Jeffxxx is offline   Reply With Quote
Old Sat, Dec-06-2008, 03:50:35 PM   #5
Hi5ingmf
Hi5ingmf's Avatar
Reputation: 0 Hi5ingmf is on a distinguished road
Poland
I thought the center bore was the the same on E60 5ers.... 72.5, the E39 was 74.1
Jump to top Hi5ingmf is offline   Reply With Quote
Old Sat, Dec-06-2008, 03:55:59 PM   #6
nrubenstein
I didn't realized they'd standardized it again. It was incredibly stupid.
Old Sat, Dec-06-2008, 10:47:37 PM   #7
samer110
samer110's Avatar
How did you manage to get them fitted? Did you have to remove any parts and what parts of the M5 brakes did you use?
Old Sat, Dec-06-2008, 10:50:21 PM   #8
samer110
samer110's Avatar
yeah the M5 rotors were huge and the center bore was too deep, I would have had to change practically everything; I have a set of csl rotors, they are wider and thicker than stock M3s, I will try them out with that and see how much of a gap there is still. As for the caliper brackets, they aren't that difficult to make, I just need to take the correct measurements and I can have them made at some machine shop...
brakes, e46, e60, fitting
Does E46 M3 front brakes fit on 325ci E46 coupes? MilanoGTR Faults, Fixes and DIY 0 Sun, Sep-02-2007 11:21:53 PM
Fitting four race tires/wheels in an E46 M3 sfarmer13 M3 Track: Racing and DE 6 Sat, May-19-2007 03:30:45 PM
E60 M5 Brakes in E46 M3 asiupang E46 M3 (2001-2006) 4 Thu, Aug-10-2006 04:01:14 AM
E46 M3 Bbs Ch Fitting Issues? PEEWEE_D_M3 E46 M3 (2001-2006) 11 Sun, Jul-16-2006 08:19:08 PM
Any possible way of fitting an E90 CD-player in an E46 M3 ??? Kaveh E46 M3 (2001-2006) 6 Wed, Mar-29-2006 09:06:02 PM
Discussing E60 M5 brakes fitting on E46 M3 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
