Old Sat, Mar-27-2010, 09:51:10 PM   #31
lols
Reputation: 0 lols is on a distinguished road
I just did this, and noticed...that road noise is alot louder than before. Or is it just me ? I'm wondering if something was left out ? Or a step I could have missed ?
thx
e.d.
Jump to top lols is offline   Reply With Quote
Old Sat, Mar-27-2010, 11:27:59 PM   #32
khanyam3
Back in the day member
khanyam3's Avatar
Reputation: 0 khanyam3 is on a distinguished road
Cambodia
I was charge $574 for this job at the stealership from long beach bmw. DIY is definitely the way to go.
2004 BMW ///M3 SMG with a couple of oem stuff
Jump to top khanyam3 is offline   Reply With Quote
Old Sat, Apr-24-2010, 02:09:09 PM   #33
Dan S
Reputation: 0 Dan S is on a distinguished road
I just did this on the driver's side door.
I would recommend disconnecting the 4 connections on the old unit prior to pulling it out. I found that the easiest way to get it out of the door was to slide it down to the bottom of the door. Then push the window rail in as you force the actuator out. It was a PITA but it worked.
When putting the new actuator in I did the same thing in reverse order. I would not recommend connecting the 4 connections until the unit is in the door.
Jump to top Dan S is offline   Reply With Quote
Old Mon, Jun-07-2010, 02:05:30 PM   #34
Surk///M
Reputation: 0 Surk///M is on a distinguished road
Thanx for this DIY..just did my pass side door actuator..PITA to remove old unit..but doable if you move bottom window rail fwd enough once detached.. Dbl check your alignment and i also lubed the window regulator cables while in there with white grease..
Jump to top Surk///M is offline   Reply With Quote
Old Sun, Dec-26-2010, 09:55:17 PM   #35
amobile
Reputation: 0 amobile is on a distinguished road
Default Re: Just replaced my driver's side door actuator - DIY, Hints, & Tips
Hi all and thank you for this very helpful thread.
I have a similar problem on my E46 coupe (the driver door locks but doesn't unlock; other door , trunk and tank lock work without problems) and I would like to ask you if there's a sure way to know if the problem originates from the door actuator or from the GM5 module.Thank You.
Jump to top amobile is offline   Reply With Quote
Old Mon, Dec-27-2010, 04:38:04 AM   #36
e46fanatic...
e46fanatic...'s Avatar
Reputation: 0 e46fanatic... is on a distinguished road
I had the same problem you have and the Actuator fixed it.
As the OP mentioned DO NOT reconnect the new actuator when everything is not put back together because once power is connected to the actuator all the windows roll down which can cause a mess if you're like me and had the window rail undone
Also make sure before you attempt to take the actuator out, disconnect the key lock mechanism in the handle.
http://forum.e46fanatics.com/showthread.php?t=600213(Scroll down)
Jump to top e46fanatic... is offline   Reply With Quote
Old Mon, Dec-27-2010, 09:01:10 AM   #37
amobile
Thank you.
I found that DIY yesterday and already removed the door panel and vapor barrier but my torx tool broke when I tried to unscrew the three T30 bolts from the side of the door (from the actuator) and I'm going to buy a new good tool today and try again.
I also got to the GM5 module and took it out in order to have a look and found some stains on the TYCO relays. Don't know if that matters.
Anyway, there's something that bothers me.
When I lock the car using the key remote, all doors lock. When I press unlock all doors but the driver's unlock.
But, when I do the same thing from the lock button (near the gear shift) in the car , the driver's door doesn't respond at all (not even locking). All other doors behave correctly.
When I say all other doors, I mean the passenger door, trunk lock and tank lock.
Old Mon, Dec-27-2010, 05:41:51 PM   #38
e46fanatic...
Thank you.
I don't even remember if mine did the same thing with the interior lock switch, but is the door completely closed when you engage the switch because I think it only works when the doors are closed, but I rarely use that switch so I don't remember...
One thing you could do is get real close to the door lock actuator and when you unlock it through the key fob feel/hear if there's movement. I could hear and feel mine trying to unlock, but nothing would happen. That's why I started with the actuator.
Old Mon, Dec-27-2010, 07:51:14 PM   #39
amobile
Yes, the door is completely shut.
The sound coming from the door seems to be normal, except the pin doesn't pop up.
Old Tue, Dec-28-2010, 01:31:57 AM   #40
DMan
The Lurker
DMan's Avatar
Reputation: 0 DMan is on a distinguished road
Great DIY.
In the picture below, what is the bolt at the top left corner closest to the door pin? I've had to tighten mine a couple of times because when it gets a little loose I get a very slight rattle. I have a feeling when I roll the window up and down it loosens this bolt.
D-Man
'99 M3 (gone)
'01 CLK55 (gone)
'07 A4 (gone)
'05 A6 (gone)
'03.5 M3 6MT
'06 Cayenne Turbo
Jump to top DMan is offline   Reply With Quote
actuator, diy, door, driver, hints, replaced, side, tips
Brand New Driver Side Door Actuator babydevilj Parts for Sale/Wanted 1 Fri, Feb-27-2009 03:25:52 PM
Need part number for driver side door actuator FCars4Ever E46 M3 (2001-2006) 8 Sat, Dec-13-2008 06:58:08 AM
Power steering DIY and Door lock actuator are back Brandon318 E36 M3 (1992-1999) 0 Fri, Oct-24-2008 07:36:30 AM
Door actuator DIY?? Surk///M E46 M3 (2001-2006) 20 Tue, Sep-11-2007 11:54:24 PM
my door does not work from the outside (driver's side) LIL RAJA E36 M3 (1992-1999) 12 Mon, Sep-26-2005 10:07:00 PM
Discussing Just replaced my driver's side door actuator - DIY, Hints, & Tips in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
