Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013)
E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013) {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm}
Old Sun, Dec-28-2008, 07:22:06 PM   #1
Da Jemster
Institutionalized User
Da Jemster's Avatar
Reputation: 0 Da Jemster is a jewel in the rough
Default Need help from wiring gurus....
I'd like to hardwire my radar detector. I opened up the casing behind our rear view mirror, which I believe has the light sensor (correct me if I'm wrong).
1. Will that red wire be constant power? Or will it just be on when I turn on the car? I've always wired my radar detectors to only be on when the car is on.
2. If that red wire is indeed constant, which of the other five wires (brown, white, blue/yellow, blue, brown/black) should I tap into?
3. Where should I tap my other wire from the radar detector?
TIA
--Jem
2008 E93 - AW - DCT - Stock...for now
2004 E46///CB-BLK///SMG II///D/A tuned///AFE Stg 2///SS Stepped///SS Metallic Cats///Eisenmann SS X-pipe///SS Race///4.10 diff///ACS CF Front Lip///6000K Xenons & Fogs///CF Grills & Gills///Angel Eyes///Clear Corners w/Solaris///Painted Reflectors///Black'd Sides & Tails///TEIN S
Jump to top Da Jemster is offline   Reply With Quote
Old Sun, Dec-28-2008, 07:24:10 PM   #2
M3Tech
M Powered
M3Tech's Avatar
Reputation: 0 M3Tech is on a distinguished road
TIA
--Jem
I think that you need to buy a multimeter. If you don't know how to use it, or even if you don't know what it is, then you will end up messing up your car.
Jump to top M3Tech is offline   Reply With Quote
Old Mon, Dec-29-2008, 06:59:36 AM   #3
JIO
Reputation: 0 JIO has disabled reputation
This is what I did and it was very easy, especially the wiring.
http://www.e90post.com/forums/showthread.php?t=97545
Jump to top JIO is offline   Reply With Quote
Old Mon, Dec-29-2008, 03:40:37 PM   #4
Da Jemster
Da Jemster's Avatar
I do have one. I just didn't wanna dig for it. Anyways, the "red" wire is not constant. This is what I used. The "blue yellow" and the "blue" are constant.
Thanks. Somehow the E93 above-lighting console is different from the pictures.
gurus, wiring
little help please from ps gurus....:) nick///M3 Member Photos and Videos 12 Sun, Mar-16-2008 06:49:24 PM
Laptop Gurus whatcop? Off Topic 10 Sun, Jan-20-2008 10:57:57 PM
Calling All Mobile Audio Gurus!!! LOC wiring Questions carlos3679 Audio/In Car Entertainment (I.C.E.) 1 Wed, Jun-20-2007 03:04:43 PM
Angel Eye Wiring - Wiring to lights only? LightWerkz E46 M3 (2001-2006) 5 Mon, Jun-18-2007 11:42:00 PM
Any wiring gurus in orange county? al4t1gbundy Pacific 2 Tue, Mar-06-2007 12:41:00 AM
Discussing Need help from wiring gurus.... in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
