Old Fri, Jan-02-2009, 02:39:38 AM   #1
iigigol0ii
Reputation: 11 iigigol0ii is on a distinguished road
Romania
Default Wheel bearings
Well, ho do i know if my wheel bearings need to be changed?
When driving, if i have the music down it sounds kind of like i have truck tires on, almost like i can here and very slightly sometimes feel the vibrations from them. Lately from the back when i turn the wheel a little bit i hear a loud ticking coming from the back wheel...
Are those my wheel bearings? are there any DIY's? I did a search and was unsuccessful
Jump to top iigigol0ii is offline   Reply With Quote
Old Fri, Jan-02-2009, 02:44:46 AM   #2
Jackalope
Jackalope's Avatar
Reputation: 0 Jackalope is on a distinguished road
The best way I know of to check them is first do a visual inspection looking for any grease seeping out or metal shavings in the area as these are a good indication of a problem. second ifyou see no such issues put the wheel back on and rotate it slowly by hand and see how it feels. Does it spin freely with a little drag? Or do you feel any roughness or chopiness as you spin it? If so then its toast. As for a DIY sorry I don't know.
Jump to top Jackalope is offline   Reply With Quote
Old Fri, Jan-02-2009, 03:24:55 AM   #3
nrubenstein
Front wheel bearings are pretty easy to check. Jack up the front of the car and spin the left and right wheels. If one makes more noise than the other, it's probably a bad wheel bearing. (They should be pretty much silent, although it's impossible to rule out caliper rubbing without actually removing the caliper. If you take the caliper off, ANY noise when you spin it means the wheel bearing is bad.)
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison
2002 BMW M3 Alpinweiß/Black - JBL MS-62C, IDQ-12v3, JBL MS-8
1989 325is Alpinweiß/Black - S50B30, GC/Koni, Sways, BBS RX, Hybrid C61-2, Sundown SA-12, JBL MS-8
1989 M3 Alpinweiß/Black - S50B32. 321hp.
Hers: 1996 Porsche 911 Turbo Black/Black
Hers: 1988 325iX Coupe Diamondschwartz/Black 5spd - Korman lengthened front driveshaft, Cam, Bilstein, H&R Sport, snow chains.
Jump to top nrubenstein is online now   Reply With Quote
Old Fri, Jan-02-2009, 02:24:01 PM   #4
travisbickle
Reputation: 0 travisbickle is on a distinguished road
In my experience, when wheel bearings go they make a high pitched constant squeek. The squeek will change pitch or go away altogether when the car is loaded to one side or the other when cornering.
'03.5 M3|Jet Black|Cinnamon|Nav|HK Removal|BBS LM 19s|TCK D/A Coilovers 400F/500R|TCK Camber Plates|TCK Rear LCAs|Powerflex RTABs|TMS Subframe Reinforcement|Borla Cat Back|AA Stage 1 Gen 2 SC|Mach V Motorsports TLC
Jump to top travisbickle is offline   Reply With Quote
Old Fri, Jan-02-2009, 02:31:55 PM   #5
jaciuro
When will they learn that the left lane is for passing only?
jaciuro's Avatar
Reputation: 0 jaciuro has a spectacular aura about
Puerto Rico
My wheels are quiet on a straight drive but when a turn kicks in I hear that truck tire sound. The harder the turn, the louder the truck tire sound. Is this any indication of a wheel bearing issue given that I don't hear the high pitched squeal?
2004 E46 M3 6-SPD Titanium Silver/Gray Leather
StopTech ST60/380mm, PowerFlex RTABs, Streamline Intake Tube & Filter
2005 Suzuki GSX-R 1000 Black/Yoshimura TRC (Stolen!)
2002 Subaru WRX Stage2+Sold
Jump to top jaciuro is offline   Reply With Quote
Old Fri, Jan-02-2009, 04:44:27 PM   #6
00o00
00o00's Avatar
Reputation: 0 00o00 is on a distinguished road
this is what my car looked like when I had to replace the drivers side rear...
at first we thought it was leaking... but it was totally gone
Current Mods: Hardwired V1, Matte Black Side and Front Grills
Matte Black ///M3 emblem, TCK SA's (500/500),
Vorshlag Camber Plates, TCK RSM, Powerflex RTABs,
Hotchkis Front Sway Bar, Turner Rear Sway Bar,
GC adjustable endlinks, UUC red Transmission mounts,
CDV delete, AutoSolution SSK (30% reduction),
BR Racing Rear Strut bar, Turner Adjustable Rear Camber Arms,
APEX ACR-8 (18x9.5 square), Nitto NT-05's (265),
Vorshlag 15mm Spacers (rear), Vorshlag Studs,
Turner Front Strut Re-Enforcement, Mason Engineering Strut Bar
and SS Race
Waiting to be Delivered or Installed: Aluminum Pedal Set
Jump to top 00o00 is offline   Reply With Quote
Old Fri, Jan-02-2009, 04:47:13 PM   #7
The Fly
Reputation: 0 The Fly is on a distinguished road
My symptoms of a bad LR bearing were similar to Jaciuro's, except that it would do it in only one direction. It was more of a low-pitched humming sound than high pitched, like a mud tire at that corner. Replaced it and it's cured.
Jump to top The Fly is offline   Reply With Quote
Old Fri, Jan-02-2009, 07:27:40 PM   #8
sean454
sean454's Avatar
Reputation: 0 sean454 is on a distinguished road
lift car up. try and move tire in and out by placing hands at 12 and 6. if there is any play in it... Wheels bearings.
2005 CB/CINN SMG. Mods: Vcsl bumper, Vcsl vented hood, Black CF gills, Gunmetal Csl's, K&N, Agency Power exhaust w/ Ti tips, depos, umnitza 6000k, Led halos, Led Sidemarkers/reverse lights, xenon int lights, Custom Carbon fiber interior, M5 smg knob, Pioneer Avic-Z1 Nav/Dvd, Gunmetal Paddles.
Jump to top sean454 is offline   Reply With Quote
Old Fri, Jan-02-2009, 08:06:51 PM   #9
nrubenstein
Of the 9 bad wheel bearings I have had, only one of them was apparent through that test.
Old Fri, Jan-02-2009, 08:18:19 PM   #10
The Fly
Yep. I tried the test too and it passed. It's gotta be pretty bad to fail that test.
bearings, wheel
Wheel bearings jacclark M3 Track: Racing and DE 6 Fri, Aug-24-2007 06:12:13 PM
Wheel bearings or...?? bfaskier Faults, Fixes and DIY 8 Wed, Jun-14-2006 11:08:24 PM
Groaning noise from front wheel. Wheel Bearings? Blue///M3 E36 M3 (1992-1999) 5 Sat, Jun-03-2006 03:28:53 AM
Wheel bearings johnj3nks E36 M3 (1992-1999) 3 Thu, Apr-21-2005 01:12:19 PM
Wheel bearings. 04E46 E46 M3 (2001-2006) 6 Thu, Feb-17-2005 12:24:54 PM
Discussing Wheel bearings in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
