#11 |
Essayons
![]() Location: Fircrest, WA
The looking for play test by pushing on the wheel is only good when they are really bad. I have heard both a humming noise and a low speed tick from bad wheel bearings in the past. Just jack the car up and inspect the outer portion of the bearing and check to see that it spins smoothly without any noises.
3/01 production, TCK Coilovers 550F/600R, Vorshlag camber plates, TCK RSM's, TMS rear control arms, Powerflex RTAB's, Rogue FCAB's, OEM strut tower bar, tower reinforcement plates, reinforced subframe, TR MT1 wheels, Stoptech BBK, ZHP shifter, Rogue tranny mounts, Agency Power Headers, Random Tech cats, Rogue pulleys, Conforti tune, Borla Mufflers, AFE Stage II intake, 3.91 gear set, Clutchmasters clutch and lightweight steel flywheel, CF trunk, ... |
#12 |
where exactly is the wheel bearing?
#13 |
![]() Location: Farmington Hills, MI
David 2001 ///M3 OEM: 6-Speed | Titanium Silver Metallic | Imola Nappa Leather | Power Seat Package | Cold Weather Package | Width adj. front seat with lumbar | Xenon | Moonroof | In-dash CD | HK | BMW alarm | Univeral transceiver Mods: OEM Strut brace | OEM 19" wheels (street) | RAC RS110 9.5"(f)/10"(r) wheels (track) | Brembo 355(f)/345(r) BBK | Motul RBF600brake fluid | ACS rear shock tower brace | D/A Race software | SS Stepped Headers/S-pipe/X-pipe w/resonator/Race muffler | RE pullies | aFe CAI stg1 | Bimmerworld intake elbow | Bimmerworld CF brake ducts | BMW Motorsport thermostat | TCK D/A coilovers w/#600(f)/#700(r) | GC camber/castor Race plate | Powerflex FCAB | GC front sway bar links | h-Sport sway bars | RE Tranny mounts | TCK RTAB | GC RLCA| TCK shock mounts | V-CSL CF trunk | V-CSL CF diffuser | McMahan 4pt rollbar | TMS oil cooler | RE Octane SSK |
#14 |
My rear wheel bearings went bad a year ago and thats the same noise I had, a humming/shuffling noise. It would get louder as I went faster.
#15 |
![]() Location: Washington, DC
Grr. The sound of my bad rf wheel bearing was apparently masking the sound of the bad right rear.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 2002 BMW M3 Alpinweiß/Black - JBL MS-62C, IDQ-12v3, JBL MS-8 1999 323i KP/GTS2 Alpinweiß - Hood-in-the-windshield mod 1990 325is Brilliantrot/Tan - GC/Bilstein, Sway 1989 325is Alpinweiß/Black - S50B30, GC/Koni, Sways, BBS RX, Hybrid C61-2, Sundown SA-12, JBL MS-8 1989 M3 Alpinweiß/Black - S50B32. 321hp. ![]() Hers: 1996 Porsche 911 Turbo Black/Black Hers: 1988 325iX Coupe Diamondschwartz/Black 5spd - Korman lengthened front driveshaft, Cam, Bilstein, H&R Sport, snow chains.
#16 |
When will they learn that the left lane is for passing only?
![]() Location: Tampa Bay - FL
Now, the harder the turn at high speed (because it isn't audible at low speed) the more prominent the sound becomes, usually during an on or off ramp. It's just as one person put it, like a truck tire, but only on fast, long duration turns like an on or off ramp.
It is definitely coming from the rear of the car and doesn't have the symptoms of a diff issue, especially since there is no problem at low speed. Maybe the bearing is just starting to go bad? I spin the rears and they are stiff, not too bad though, possibly given the effort required to work through the diff to get the other one to spin as well.
2004 E46 M3 6-SPD Titanium Silver/Gray Leather StopTech ST60/380mm, PowerFlex RTABs, Streamline Intake Tube & Filter 2005 Suzuki GSX-R 1000 Black/Yoshimura TRC (Stolen!) 2002 Subaru WRX Stage2+Sold |
#17 |
Goin' crazy... wanna come?
![]() Location: Parker
Sounds exactly like the wheel bearing.
2005 Interlagos Blue M3 - Cinammon Interior - ZCP - 6MT - Premium - HK Sound Performance Mods: D/A Race Software, D/A VAC Lightweight UnderDrive Pulleys, Streamline Panel, Ceramic Coated Stainless headers, Race-cats, B&B Tri-Flow, Motons, Vorshlag plates, GC Adj. Rear Camber Arms, GC Race Hybrid FCAB, Powerflex RTABs, H-Sport Sways, GC adjustable endlinks, GSP Clutch Pedal, 40% Autosolutions SSK, Rogue Trans Mounts, PFC WC/GAC front brake kit, PFC-01s for the track. Click Here for nightmare ECS story. - LOL, it was deleted, guess it shows the sponsors can get away with anything here. |
#18 |
Chin 3/3 @ VIR Full
![]() Location: Chapel Hill, NC
My bad front left made an oscillating humming noise once I got up to about 75mph. Also, taking a turn to the right (that would load up the left front bearing) and then driving straight would make it worse. Mine was replaced under CPO, but I had to take a tech for a drive to prove it because the SA thought "everything sounded perfect" after he took it for a drive...
#19 |
The only reason I doubt it being my fronts is because when I had both front wheels up off the ground, they spun VERY easily and spun for a long while then slooooowly came to a stop, nothing sudden - and there was no noise, grinding, squeaking or otherwise.
It has to be the rear bearings. Is there a way to test them w/o taking it all apart? I know the diff and other wheel cause it to be tough to spin as it's all connected, but when I do, I didn't hear any noise.
#20 | |
cuchef
![]() Location: north palm beach
Any luck with solving the "truck tire" sound problem? I'm having the same issue!
[SIGPIC][/SIGPIC] |
| bearings, wheel |
| Wheel bearings | jacclark | M3 Track: Racing and DE | 6 | Fri, Aug-24-2007 06:12:13 PM |
| Wheel bearings or...?? | bfaskier | Faults, Fixes and DIY | 8 | Wed, Jun-14-2006 11:08:24 PM |
| Groaning noise from front wheel. Wheel Bearings? | Blue///M3 | E36 M3 (1992-1999) | 5 | Sat, Jun-03-2006 03:28:53 AM |
| Wheel bearings | johnj3nks | E36 M3 (1992-1999) | 3 | Thu, Apr-21-2005 01:12:19 PM |
| Wheel bearings. | 04E46 | E46 M3 (2001-2006) | 6 | Thu, Feb-17-2005 12:24:54 PM |
