I was reading SMG training reference manual and saw this.
"Emergency Acceleration Emergency Acceleration is possible regardless of the shift mode (A-Mode or S-Mode) or the DRIVELOGIC position engaged. Depressing the accelerator pedal quickly to the floor without the brake pedal depressed will engage emergency acceleration. The engine RPM will come up very quickly and the clutch will be pulsated to ensure maximum acceleration. Wheel spin will be limited even if DSC is switched off. When this mode is activated subsequent shifts must be made manually." So if you are in N and depres accelerator pedal quickly will it accelerate? Or am I reading this wrong? |
#2 | |
Fukin Germans
![]() Location: Miami
"Auto racing, bull fighting, and mountain climbing are the only real sports ... all others are games." - Ernest Hemingway "I spent a lot of my money on booze, birds, and fast cars - the rest I squandered" - George Best 2008 F1Racerforum Game: Beeboo from f1rf.c says: "rain or shine, Massa's destiny is divine; and he'll make everyone whine ”"Official M3 Boobies Club: Boob #53 Break-In and Warm-Up for noobs |
M3 Devil
![]() Location: Mississauga
it will not do nothing on N
only one u have it on one ... u press the gas fast, the engine will rev then clutch will be ingaged fast.
2011 E92 M3, Competition Package, Le Mans Blue/Black/Carbon, MDCT Modds: Euro Front Bumper, BMW Carbon Fiber Front Splitter & boot spoiler, Akrapovic, Matt black competition wheels, SS brake lines, KW V3 + KW EDC isolators, EVO sport pulley kit, Macht Schnell air filter & scoop. Gone but not forgotten: Euro 2004 E46 M3 |
#4 |
He never drives it, He just rubs it with a diaper
![]() Location: Caldwell, NJ
so basically this is almost like a Launch Mode?
#5 | |||
![]() ![]() ![]() ![]() ![]() ![]() Location: Switzerland
Drivelogic program is selected by the rocker switch for S or A. Quote:
![]() It is similar to a launch in that it is intended to maintain traction when dodging an emergency situation, not really designed for stoplight dragging. However if you keep your foot down when shifting to second, DSC may bog when hitting second to keep traction.
#6 |
Always want more boost!
![]() Location: SA Town, Texas
How do you engage burnout mode without engaging launch mode?
Sold 2002 BMW ///M3 SMG - Steel gray, AA Gen 2 Level 3+ Meth |
#7 |
Fukin Germans
dsc off and just really mash your foot on the gas....Hard.
#8 |
![]() Location: Washington, DC
Translation, if you hit the kickdown switch, you engage this mode. This is why the M3 uses the gas pedal of an automatic 3'er - one nice modification is to retrofit a pedal without a kickdown switch so you don't have that annoying feel.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 2002 BMW M3 Alpinweiß/Black - JBL MS-62C, IDQ-12v3, JBL MS-8 1999 323i KP/GTS2 Alpinweiß - Hood-in-the-windshield mod 1990 325is Brilliantrot/Tan - GC/Bilstein, Sway 1989 325is Alpinweiß/Black - S50B30, GC/Koni, Sways, BBS RX, Hybrid C61-2, Sundown SA-12, JBL MS-8 1989 M3 Alpinweiß/Black - S50B32. 321hp. ![]() Hers: 1996 Porsche 911 Turbo Black/Black Hers: 1988 325iX Coupe Diamondschwartz/Black 5spd - Korman lengthened front driveshaft, Cam, Bilstein, H&R Sport, snow chains.
#9 |
Acceleration boost (S6)
To activate the acceleration boost, it is necessary for the DSC to be deactivated and the S6 shift program to be active. Only with this setting is it possible to perform a "racing start". The shift lever must now be pushed forwards and the accelerator pedal depressed. The acceleration boost is performed once the shift lever has been released. Subsequent gear shifts must be initiated manually. There are two modes included in the acceleration boost S6 position. The "racing start" and the "burnout" modes. The difference in the activation of these two modes is the rate at which the accelerator pedal is depressed. Depressing the accelerator slowly to the floor activates the "racing start" mode. In this mode the clutch is pulsated at a high rate (up to 8 times a second) and the vehicle accelerates at the fastest speed possible without spinning the tires. The wheel speeds on the front and rear axles are compared with each other and the car pulls away according to the clutch biting point in order to achieve optimum propulsion. Depressing the accelerator pedal very quickly to the floor activates "burnout" mode. This mode releases the clutch totally and completely when the shift lever is released. In this mode the rear tires are very likely to loose traction and the rear of the car to become unstable. Wheel speeds are ignored and the driver is in total control of wheel spin. |
#10 | |
![]() Location: paramount CA.
1. 2006 Lotus Exige (sold) 2. 2008 Mini Cooper S (currently own) 3. 2011 E92 M3 (sold) 4. 2002 E46 M3 (sold) www.GonzalezOrnamental.com |
| acceleration, emergency, mode, smg |
| SMG will not up shift under hard acceleration? | harry$ | E46 M3 (2001-2006) | 14 | Wed, Sep-07-2011 09:18:36 PM |
| 2006 M3 w/ SMG Acceleration problems | MD | General BMW Discussion | 4 | Tue, May-29-2007 12:47:45 PM |
| Sudden acceleration while in 1st and parked with SMG? | konaforever | E46 M3 (2001-2006) | 21 | Thu, May-26-2005 08:49:14 PM |
| EMERGENCY HELP: SMG problems | M4Power | E46 M3 (2001-2006) | 16 | Mon, Jun-28-2004 07:40:17 PM |
| Emergency Acceleration... | M3Fan | E46 M3 (2001-2006) | 0 | Wed, Jul-31-2002 11:10:00 AM |
