#31 | |
BlueHairMafia
![]() Location: St. Augustine, Florida
if i remember discountdirecttires.com or something like that sells them... tire rack has gone to the plastic ones and mackin the distributor of volks send out plastic ones with their wheels as well.. so obviously if used correctly then given that all these big names use them they are probably ok... i decided to go with plastic ones first just to test fitment, since they were really cheap (around 12.00 shipped) then if they fit and i feel i need aluminum ones i will already know what size to order... there are plenty of 74 to 72.6 rings out there because one of the models of the goofy 5 series has a 74.1mm hub bore so many companies make the bmw 5x120 to fit that wheel and use the centering ring to make up for the difference for other models... apparently during the wheel making process it is much easier to adjust offsets as opposed to center bore of the wheel..
Jan Obrien says tHe womeN in That group gossip about her (“One piece of gossip that went around was that we’d been evicted from our last apartment,” she says); spread lies about her; discourage other residents from befriending her and give her dirty looks whenever she tries to use community facilities, like the rec room. |
#32 | |
"Just Six"
Current Mods: Painted front reflectors, matte black fender gills, carbon fiber roundels, Depo smoked corners, 19" Ruff Racing wheels wrapped in Hankook Ventus V12's (245/35F & 275/30R), Status Gruppe coilovers (7K/8K), RE RSM's, Powerflex RTAB's & FCAB's, DICE, CSL Rep Diffuser, CF Hamann Rep Lip, Magnaflow exhaust, Ebay headers, Streamline filter, Afe elbow, RPI scoops, ZHP knob, and EE LED tails. WTB: OEM Front strut bar, Evolve stage II tune, 4.10's, and CF CSL rep Bootlid |
#33 |
Roadrunner
![]() Location: Stavanger
I have actually used duct tape on 3 cars to eliminate these vibrations.
If you can get aluminium ones, get them, I have had several plastic ones that have been broken when installing the wheels. My rule of thumb with wheels are that you should be able to fit the wheel on the hub and let go without any bolts in and the wheel should not fall off. If in doubt, put the wheel on the hub and try to move the wheel up-down-sideways, and if you can, you need rings. The tape trick is a good way of troubleshooting, and I have used it with success on 3 of my cars, and also on friends cars. Good luck, but I think your vibrations will go away when you get the rings installed.
2004 M3 SMG Carbon black Mods. V-max delete, M-track mode, CSL SMG software K&N FIPK kit, CSL Diffuser, 12" RF subwoofer, KW v3 coilovers, GC camberplates, Umnitza Orion v2 angel eyes, Depo black side indicators, matte black kidney and sidegrilles, 6% lamin-x head, fog, turn and tail lamp tint, Vader black VMR VB3's, My M3's thread 1990 850cia BMW black Mods. Supercharged, Eibach pro springs, Bilstein shocks, camber plates, 19" Work wheels, Alpine navi, JL audio stereo system, tinted tails, CSi body kit, custom stainless exhaust. To-do list: Alpina hood, tinted windows |
#34 | |
BlueHairMafia
#35 | |
BlueHairMafia
but they also have a website... http://www.lakeshorewheelandtire.com...category&id=34 more specifically http://www.lakeshorewheelandtire.com...34&prevstart=0
#36 |
"Just Six"
thanks guys, you have been most helpful!
#37 | |
BlueHairMafia
#38 | |
"Just Six"
I saw the plastic rings (like you ordered on ebay) but they didn't have OD = 74.00mm ID = 72.56mm on ebay but they did have OD = 74.1mm ID = 72.56mm. Do you think these will work or will that .1mm make a huge difference?
#39 | |
Roadrunner
Also to remove them from the hub when changing wheels may cause them to break. Aluminium poses another problem calld galvanic corrosion, aluminium and steel don pair up very good, and they will corrode into each other in time. That white powder that you see on your hubs when removing your alu wheels, that's corrosion. If you only remove your wheels when changing tires, maybe the plastic ones are the one you need. As for duct tape, or any other tape, start with a double layer, put the wheel on the hub and check for movement, add/remove tape until the wheel does not move on the hub.
#40 | |
BlueHairMafia
http://www.covalenceadhesives.com/Se...ls.aspx?ID=579 extreme weather.. lol... should hold up forever... it is close to 1mm thick though.. i may just put them in place and put the foil tape over them as opposed to taping them on both sides since it is that thick... we shall see.. it will essentially be an aluminum ring.. haha
| calling, experts, hubcentric, ring |
| Hubcentric Ring Install | SECRET M | E46 M3 (2001-2006) | 4 | Tue, Mar-25-2008 12:41:56 AM |
| calling all brake experts | Silver///M | E46 M3 (2001-2006) | 13 | Tue, Sep-25-2007 06:09:45 AM |
| where to buy hubcentric ring for volk ce28n | trd_gerry | E46 M3 (2001-2006) | 3 | Sat, Feb-17-2007 11:24:53 PM |
| Need help to get the hubcentric ring for Time attack | NightKidz | E46 M3 (2001-2006) | 0 | Thu, Jan-25-2007 03:58:19 AM |
| Calling all CD Player experts!!! | ///Mphantom | E36 M3 (1992-1999) | 1 | Sun, May-25-2003 01:47:23 AM |
