Old Tue, Feb-03-2009, 01:42:16 AM   #1
vRooooM
///M Life
vRooooM's Avatar
Reputation: 0 vRooooM is a glorious beacon of lightvRooooM is a glorious beacon of light
Default RPI Scoop Dyno Charts?
Searched and couldn't find any RPI scoop dyno carts/graphs. Are there any? thanks.
04 SG/IR
SMG, Prem. pkg -Assist, NAV, adj. width, xenon, univeral transceiver, HK
Mods
M5/M6 SMG Shift knob, Royal F1 paddles, Streamline P/F, IceLink Plus, RG4v2, D/A software, TCKline D/A, V-CSL Trunk/Diffuser, RPI Scoop
07 S60 R
Jump to top vRooooM is offline   Reply With Quote
Old Tue, Feb-03-2009, 02:37:19 AM   #2
NorthwestM3
Essayons
NorthwestM3's Avatar
Reputation: 0 NorthwestM3 is on a distinguished road
The number is going to vary depending on the number of fans used. I would take any dyno graph for these with a grain of salt. Not enough fans is going to result in low numbers for the top end. Too many or even the right amount and you are going to get inflated low end and midrange numbers. The only real measurable method would be acceleration and 1/4 mile time gains. Even then you are subject to varying weather and track conditions unless they are done on the same day.
3/01 production, TCK Coilovers 550F/600R, Vorshlag camber plates, TCK RSM's, TMS rear control arms, Powerflex RTAB's, Rogue FCAB's, OEM strut tower bar, tower reinforcement plates, reinforced subframe, TR MT1 wheels, Stoptech BBK, ZHP shifter, Rogue tranny mounts, Agency Power Headers, Random Tech cats, Rogue pulleys, Conforti tune, Borla Mufflers, AFE Stage II intake, 3.91 gear set, Clutchmasters clutch and lightweight steel flywheel, CF trunk, ...
Jump to top NorthwestM3 is offline   Reply With Quote
Old Tue, Feb-03-2009, 03:02:17 AM   #3
douging
Reputation: 0 douging is on a distinguished road
What if it was a before/after on the same dyno, same fans, and same day?
- Doug
2003 E46 M3 | Steel Grey/Black | 6MT
Euro M3 rotors, Hawk HPS pads, Turner stainless lines
my M3 pictures
Current project: Inspection II
Jump to top douging is offline   Reply With Quote
Old Tue, Feb-03-2009, 05:36:21 AM   #4
NorthwestM3
Essayons
Do to the nature of how the product develops hp by directing air into the intake it still will not be an accurate measure of actual road conditions. You could get a measure of a specific speed like it adds 2hp at 80 MPH in 3rd gear with fans supplying air at 80 MPH. Other than that it is not going to be an accurate measure of gains at other speeds unless you could vary the speed of the supplied air to match the increase in wheel speed on the dyno. That would take an obscenely expensive wind tunnel that could change wind flow as fast as the car could accelerate.
The only realistic empirical evidence is going to be running with identical road and weather conditions and collecting the acceleration data.
Old Tue, Feb-03-2009, 07:01:41 AM   #5
M3MurkU
Reputation: 0 M3MurkU is on a distinguished road
the point is for highway roll on's these help, they may give you 2hp or 8hp, either way there cheap, and effective, i have them on my car and it does feel faster and smoother at 110mph..
Jump to top M3MurkU is offline   Reply With Quote
Old Tue, Feb-03-2009, 04:44:47 PM   #6
vRooooM
///M Life
vRooooM's Avatar
04 SG/IR
Mods
07 S60 R
Old Tue, Feb-03-2009, 05:21:54 PM   #7
lucky_doggg7
lucky_doggg7
Reputation: 11 lucky_doggg7 is on a distinguished road
Here you go...
http://www.myz4mcoupe.com/images/Sca...yDynoPlots.JPG
Granted, these dyno plots are on a Z4 M Coupe, which has a different ECU (later generation hence updated engine software) than the E46 M3, and the scoop is tested with a mix of other components, but at least one can get an idea of what the scoop will do.
Also do a search for SP Engineering, as they have a version of the scoop and in that post, dyno results are in that post. Here is my $.02, for a $100 bux, it can't hurt.
Jump to top lucky_doggg7 is offline   Reply With Quote
Old Tue, Feb-03-2009, 06:36:31 PM   #8
Mash3
Look out below!
Reputation: 0 Mash3 is a jewel in the rough
You'll inch away from a stock car at 100+mph! Awesome!
Can't hurt, though. Can it?
GC
Forum Member Since 2003. . . 2004 M3, SG/ IR. 75k miles. Original owner.
Jump to top Mash3 is offline   Reply With Quote
Old Tue, Feb-03-2009, 10:07:42 PM   #9
AlPhA M3
Reputation: 0 AlPhA M3 is on a distinguished road
ill be installing mine once it stops snowing and let u all know.. ive heard great reviews
tiag m3.. 6mt, HRE'S ,stoptech stg.2, EE leds, v-csl rear diffusor ,tien , shark injector, a/p exhaust, re rasp pipe,streamline filter, steamline elbow, RPI scoops, re tranny mounts, cdv delete, re clutch stop, uuc revo3,, WAY MORE TO COME
Jump to top AlPhA M3 is offline   Reply With Quote
Old Tue, Feb-03-2009, 10:10:25 PM   #10
Detroit_M3
Detroit_M3's Avatar
Reputation: 0 Detroit_M3 is on a distinguished road
It is like $150 for a piece of plastic...
Jump to top Detroit_M3 is offline   Reply With Quote
charts, dyno, rpi, scoop
RPI Air scoop waiyip E46 M3 (2001-2006) 116 Tue, Nov-02-2010 12:24:53 AM
Dyno charts with a Gruppe M exhaust? amstel78 E46 M3 (2001-2006) 15 Mon, Jun-22-2009 02:48:12 PM
RPi Ram Intake Scoops with Dyno. [14 whp] tightie E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013) 44 Wed, Feb-25-2009 12:03:14 PM
RPI Scoops....whats the scoop? King Luis E46 M3 (2001-2006) 21 Sun, Oct-19-2008 07:43:26 PM
Official: Dyno Charts and Timeslips JMWeb E46 M3 (2001-2006) 99 Wed, Dec-22-2004 11:38:33 AM
Discussing RPI Scoop Dyno Charts? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
