| Cars for Sale/Wanted Place to list your private cars for sale. ONLY BMW's. |
BMW 2001 E46 M3 RACECAR FOR SALE! This racecar was built in 2007 and has only been maintained by Patrick BMW and Fall-line Motorsports – www.fall-linemotorsports.com. It was primarily used for N.A.S.A GTS Challenge and Driving Schools. In 2008 it had 7 starts and 7 wins, won a 2008 N.A.S.A GTS4 National Championship at Mid-Ohio, and holds 3 track records in NASA/SCCA. This car has no fancy custom parts; the car is extremely fast and reliable. Doubt you will ever find a better built E46 M3 Racecar for this price! This car is being priced to sell now! -E-mail Ryan@ryanosieckiracing.com for detailed pictures. -Visit www.ryanosiecki.com for videos. -Fast Facts- -This is race ready car! -Transmission recently replaced with Brand New OEM Part in beginning of 2008 - New Lightweight Flywheel installed with Brand New Parts in beginning of 2008. -Brand new clutch discs and spring just installed, Never Used. -Differential has only 3 weekends on it. -Spherical bearings throughout. -Weight – 2,800lbs w/o driver. -Dyno Jet Results – 316 RWHP – 250 RWTRQ. (Have Dyno Sheet from 2008 NASA Nationals) -Original Chassis - never wrecked - never needed body work. - Very well built NASA GTS4 / BMWCCA CM car. -Has log book for SCCA/NASA. The car exceeds all safety requirements with the best equipment installed. -Lap Times- -Elkhart Lake, WI, Road America – 2:26.1 -Joliet, IL, Autobahn South Track – 1:31.9 -Joliet, IL, Autobahn Full Track – 2:34.1 -New Lexington, OH, Mid-Ohio Pro – 1:31.9 -New Lexington, OH, Mid-Ohio Club - 1:34.6 -IF YOU WOULD BUILD THIS CAR IT WILL COST over $115,000! -YOUR CHANCE TO GET A PROVEN RACE CAR THAT IS READY TO RACE IN SLOW ECONOMIC TIMES FOR $59,500! THIS IS WHAT CAN BE YOURS TODAY: BODY, INTERIOR, AND CHASSIS $10,500-CUSTOM 1 ¾ CHROMOLY CAGE BUILT BY FALL-LINE MOTORSPORTS, NASCAR BARS ON BOTH SIDES, SUB-FRAME RE-ENFORCEMENTS, SHOCK TOWER SUPPORTS IN REAR, A&B PILLAR GUSSETS, CAGE PAINT $2,350-FIBERGLASS HOOD, DOORS, AND DECKLID – MADE BY MA SHAW $1,900-BIMMERWORLD CARBON RACEWING $1,500-RECARO SPG PRO RACER SEAT $1,000-CENTER JACK POINTS $900-RECARO POLE POSITION SPG SEAT $850-AMD DIRECT WIRE TRANSPONDER AND DISPLAY $650-SCHROTH PROFI III BLACK 6PT P/U BOLT LAP $600-TEGRIS SPLITTER UNDERTRAY – SAME MATERIAL USED ON NASCAR CUP CARS $500-SAFECRAFT 5LB 1301 FIRE SUPPRESION SYSTEM WITH CLAMPS $500-MOMO HUB ADAPTER WITH QUICK DISCONNECT $400-VAC BILLET ALUMINUM E36/E46 FLOOR MOUNT $350-PLASTIC SIDE WINDOWS INSERTS $350- E46 SOLID REAR SUBFRAME MOUNT KIT $350-BLACK ANODIZED PANEL TO REPLACE REAR SEAT BACK $350-FALL-LINE 3-PIECE CARBON DASH $250-RECARO BRACKETS $250-FALL-LINE CARBON FIBER DRIVER SIDE FLOORPAN $220-MOMO 350 MM BLK SUEDE 3 SPOKE STEERING WHEEL $200-BLACK ANODIZED PANEL TO REPLACE LOWER SEAT BACK $200- WINDOW NET $200- DRIVERS RIGHT NET $150- TOW HOOKS $150-RECARO SLIDERS $150- E46 SOLID DIFF MOUNT KIT $120- 14” LONGACRE MIRROR WITH BRACKETS $100-ROLL BAR PADDING $40- OMP BLUE ALUMINUM QUICK-RELEASE BONNET PIN KIT $40-OMP STAINLESS STEEL SPRING CLIP LATCH KIT $23,920 TOTAL BRAKES AND WHEELS $3,300- BREMBO 4 PISTON 14.0” GT- FRONT ($700 Value Rotors have 1 weekend on them) $2,800- BREMBO 4 PISTON 13.6” GT- REAR $1,800- SSR COMPETION – 18’x 9.5’ (Comes with used Hoosier Wets 275-35-18 Tires Alone $1200 new) $1,800- SSR COMPETION – 18’x 9.5’ (Comes with used Pirelli Racing Slicks 265-35-18 Tires $1500 new) $30- E46 CARBON ROTOR BACKING PLATES $225- E46 M3 CARBON BUMPER DUCTS $190- TC KLINE PRO WHEEL STUDS $75- 3” SILICON DUCT HOSE $10,520 TOTAL MOTOR AND DRIVE LINE $3,600-DIFFSONLINE VARIABLE RAMP 3 CLUTCH CUSTOM DIFF W/ 4.10 GEARSET $2,500-FALL-LINE MOTOSPORTS CUSTOM DIFF/TRANS COOLERS $2,300-AIM MXL PISTA DATA ACQUISITION SYSTEM $2,400-SUPERSPRINT STEPPTED HEADERS $2,150-DINAN CAMSHAFTS $1,900-JB RACING ULTRALITE FLYWHEEL W/ 5.5” TWIN DISC CLUTCH (Brand new clutch discs/never used) $1,500-CUSTOM 3” EXHAUST $1,400-DINAN COLD AIR INTAKE & MASS AIR $1,300-DINAN THROTTLE BODIES $1,000-2ND FUEL PUMP SO IT WILL NOT HAVE STARVATION ON THOSE RIGHT HANDERS $900-DUAL PASS 3 ROW SS PLATE OIL HEAT EXCHANGER $500-CUSTOM DME TUNED FOR 100+ OCATANE FROM OSCAR VELEZ (Octane level can be changed) $400- AIM LAMBDA CONTOLLER KIT WITH SENSOR $325-FALL-LINE MOTORSPORTS UNDERDRIVE PULLEYS KIT $250-VAC MOTORSPORTS SOLID ENGINE & TRANSMISSION MOUNTS $150- SPAL 16” CURVED ELECTRIC FAN $130-AIM USB B-FEMALE CABLE WITH MOUNT AUTOSPORT $100 AIM OIL PRESSURE SENSOR $100-AIM CUSTOM WHEEL SPEED SENSOR $100 AIM FUEL LEVEL SENSOR $23,005 TOTAL SUSPENSION AND STEERING $3,400- MOTON CLUBSPORT 2 WAY DAMPERS (REAR COILOVER) $1,000- SHOCK REBUILD BY PERFORMANCE SHOCK INC. ONLY 1 WEEKEND ON REBUILD $750-CUSTOM RRT RACING CONTROL ARM, OFFSET CUP, 1" SPACER $600-GROUND CONTROL SWAYBARS $550-TCKLINE CAMBER/CASTOR PLATES $500-TCKLINE REAR LOWER CONTROL ARMS $350-TC KLINE E46 ALL TRAILING ARM MONO BALL KIT $300-E46 SPORT TIE RODS $200- REAR DOUBLE SHARE BRACKET $135- HYPERCOIL 4” TALL x 2.25” 750LB $135- HYPERCOIL 8” TALL x 2.25” 325LB $60- HYERCOIL 2.25” HELPER SPRING GUIDE $50- HYPERCOIL 2.25” HELPER SPRING $8,080 TOTAL MISCLENOUS $30,000- 300 hours of Labor/Tuning $20,000- Current Cost of a 2001 E46 M3 $50,000 TOTAL -IF YOU WANT TO BUILD THIS CAR IT WILL COST $115,525! -GET A FAST CAR IN SLOW ECONOMIC TIMES FOR $59,500! P1020278.JPG P1020284.JPG P1020285.JPG P1020292.JPG P1020571.JPG
Ryan Osiecki 2008 NASA GTS4 National Champion Last edited by RyanOsiecki; Wed, Feb-04-2009 at 02:55:47 PM. |
Wow what a sick race car... It would be my dream to be able to buy a dedicated race car. Good luck with the sale.
03 ///M3 SG - TMS modifications |
Bump!
Ryan Osiecki 2008 NASA GTS4 National Champion |
| 2001, e46, proven, race, racecar, sale |
| 2001-2006 E46 M3 Eisenmann Race 83mm Exhaust For Sale... | hdsr09 | Parts for Sale/Wanted | 2 | Tue, Aug-08-2006 10:19:39 PM |
| RE: 2001-2005 E46 BMW M3 Eisenmann 83mm Race Exhaust on eBay... | hdsr09 | Parts for Sale/Wanted | 4 | Sat, May-07-2005 04:21:22 PM |
| sale of 2001 E46 | mw360 | E46 M3 (2001-2006) | 0 | Fri, Aug-22-2003 02:05:52 AM |
