BMW decided to apply the subframe foam fix.
FYI, i got the current SIB in hand and have all the current part/number necessary for the foam fix. These P/N can be found/bought from tisher too. This SIB cannot be found on the TIS software. Question 1) Should i add the TMS kit (epoxy method to the subframe fix) 2) Has anybody had further subframe mount failure with the foam fix? 3) Possibility of the crack growing again after the FOAM fix ? ---------------------------- Update SIB INFO NEWest SIB for subframe foam FIX - UPdate FEB 2009 SIB41 04 08 (not available in TIS) Note on repair - Crack must not exceed 20MM for the Foam repair Quote "The following Procedure apply only to cracks at or around the left rear mounting point for the rear axle carrier" Parts needed 83190445721 - Structural foam pack (includes 2 cartridge pack, enough for one vehicle) 51711906001 - Body Plug - 10mm 07147127539 - Body Plug - 12mm Locally sourced - 3/8" clear plastic tube ( approx 10" needed) Art #08901003 - Wurth AdhesiveFlex Seam Sealer ( For more info refer www.wurthusa.com) The recommended applicator for the structural foam is the MIXPAC pneumatic applicator; model number DP400-85-01. This applicator may be contained from Conveniently PAckaged Adhesives (CPA) : website : www.forcpa.com ------------ The procedure is the same as the old SIB except for extra wording ,formating and P/N on the FEb 2009 SIB. I will still scan them tomorrow.
2004 BMW ///M3 - Alpine White | 6MT Last edited by M3Seeto; Sun, Sep-02-2012 at 06:09:59 PM. |
#2 | |
3) The crack shouldn't continue to grow if the repair is done properly. |
///M
can you please PM me the SIB and part numbers and etc...
thanks in advance |
#4 |
![]() Location: Sydney
me too, please, as i plan to do the foam fix as preventive measure. thanks
#5 |
![]() Location: Scottsdale, AZ
Could you please post the SIB and part numbers?
I will be going in for the TMS sub-frame reinforcement, which I will then follow with injecting the foam as well. Thanks! Chris
#6 |
No longer driving an e46 after 1 e46 or another for a decade
i've always wondered if there are people out there who've done both the foam & the kit...
![]() Silver Grey/Cinnamon Premium, Nav, Xenons, CWP; TC Kline S/A Coilovers; Gunmetal RAC RG4 v.2 19x9/10"; Stoptech BBK; OEM CSL Bootlid & Diffuser, V-CSL v2 bumper; Dinan SSK, Dinan exhaust, & Dinan Front Strut Tower Brace
#7 | |
![]() I figure since i'm only going to be pushing more and more power...no harm in reinforcing to the max ![]()
#8 |
lol, do you know if there have been others?
#9 |
#10 | |
![]() Location: Alexandria
I'm rather surprised that this foam fix has not gotten more interest and attention, particularly as preventative maintenance, or even that some vendor hasn't come up with their own foam kit (big hint, hint vendors...) |
| fix, foam, info, kit, needed, subframe, suggestion, tms |
| TMS subframe kit...where to go? | yellokyd03 | Northeast | 14 | Sat, Oct-11-2008 11:10:58 PM |
| Does the BMW foam fix for subframe cracks really work? | meriel | E46 M3 (2001-2006) | 33 | Mon, Aug-11-2008 12:00:44 AM |
| TMS Subframe Reinforcement Kit Questions | meriel | E46 M3 (2001-2006) | 18 | Thu, Jul-24-2008 03:54:59 AM |
| TMS Subframe Reinforcement Kit, What Gauge Is It? | bemrman | E46 M3 (2001-2006) | 5 | Mon, Mar-17-2008 01:08:06 PM |
| Rear Subframe cracked-TMS reinforcement kit? | jcheun4 | E46 M3 (2001-2006) | 20 | Sat, Dec-29-2007 03:17:46 PM |
