Old Tue, Mar-03-2009, 12:45:41 AM   #1
e46M3cab
Reputation: 0 e46M3cab is on a distinguished road
Default Camber plates with OEM stock springs?
Hi, anyone that has added camber plates to their OEM stock springs?
Can you tell me the max front camber you have been able to dial in?
Please post left and right numbers and whose plates you own...
Thank you
Jump to top e46M3cab is offline   Reply With Quote
Old Tue, Mar-03-2009, 12:59:22 AM   #2
Need4Spd
Need4Spd's Avatar
Reputation: 0 Need4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond repute
I would be surprised if a lot of people do this because the design of the suspension is such that the camber plates add ride height of maybe 1/4" to 1/3", and most people don't want to raise the car any more than it already sits. W/o gaining that height you can still get some decent neg. camber by simply removing the locating pins under the shock tower cap and moving the top of the struts inwards towards the engine. I suggest trying that "free and easy" camber mod first and seeing if you like it. How much neg. camber you get with plates will depend on the plates you choose, and whether they are adjustable or not. Dinan fixed plates give more modest camber because they are fixed and are designed for serious street but not necessarily the extremes you could run on a track. Track camber settings could eat the inner edges of your front tires in very few miles.
Past car: '05 M3 'vert, 6MT, custom 18" RAC RG63 Hyperblack monolites, Continental Extreme DW 245/40 and 275/35, Nav, HK, BT, Euro rotors, Custom Performance Rasp Terminator (2nd Gen.), Silverline DICE iPod adapter, EAS Aurora 60 LED Angel Eyes, "-CDV," "free & easy" camber mod (-1.7 degrees), Koni S/A shocks, Rogue Engineering RSMs and transmission mounts, Bimmerworld silicone intake boot, spacesaver spare from LeatherZ, updated OEM RTABS
'11 Jaguar XFR
Jump to top Need4Spd is offline   Reply With Quote
Old Tue, Mar-03-2009, 01:08:53 AM   #3
tony(topaz,SMG)
Reputation: 0 tony(topaz,SMG) will become famous soon enough
I have Turner street camber plates on a stock suspension and have set them at -2.5 on the alignment rack with plenty of camber to spare. I have never measured them at the max but I'm sure -3.0 might be possible.
Jump to top tony(topaz,SMG) is offline   Reply With Quote
Old Tue, Mar-03-2009, 01:11:21 AM   #4
Tonester
Reputation: 0 Tonester is an unknown quantity at this point
Viet Nam
If you rotate your stock top hat you can get up to 5deg negative camber.... its just a pain to adjust.
If you pull the pin and push the strut inwards. you get up to 1.9deg camber.
Jump to top Tonester is offline   Reply With Quote
Old Tue, Mar-03-2009, 01:24:36 AM   #5
e46M3cab
Thanks, I have pulled the pins, I currently get-1.0 max.
I have a bizzarre requirement for my autocross club, I have a seperate post detailing them.
I cannot swap hats.
Has any one else added camber plates to stock springs?
Old Tue, Mar-03-2009, 05:02:42 AM   #6
Tonester
Viet Nam
I cannot swap hats.
You do not need to swap hats... just remove the 3 bolts holding the strut to the tower... lower it.. rotate the top hat and reinstall... depending on which location you have it rotated to you will have anywhere from 3-5deg neg camber on stock top hats.
Old Tue, Mar-03-2009, 02:58:49 PM   #7
Need4Spd
Need4Spd's Avatar
Link or post so we can help figure this out maybe?
'11 Jaguar XFR
Old Tue, Mar-03-2009, 03:01:42 PM   #8
EricSMG
40 something
The better camber plates do NOT raise the ride height. Some even lower it a tad. Vorshlag plates, for example, will lower the front ride height about 1/4" with no other changes.
Old Tue, Mar-03-2009, 03:29:25 PM   #9
HaroldC
Yes, it's stock.....
HaroldC's Avatar
Reputation: 0 HaroldC is on a distinguished road
I cannot swap hats.
What exactly are the rules?
They would allow camber plates but not allow swapping hats?
Is there wording that mentions adjustable vs. fixed camber plates?
Jump to top HaroldC is offline   Reply With Quote
Old Tue, Mar-03-2009, 03:39:02 PM   #10
vmwerks
Valley Motorwerks
Reputation: 0 vmwerks is on a distinguished road
South Korea
+1 Vorshlag plates are the best street track plates available, we use them in almost everything.
Jump to top vmwerks is offline   Reply With Quote
camber, oem, plates, springs, stock
Hamann Adjustable Strut Bar, Stock Camber Plates, Stock Taillights M3MarkSMG Parts for Sale/Wanted 8 Wed, Jan-28-2009 12:58:59 AM
Max camber with stock springs and camber plates? 98_1LE E36 M3 (1992-1999) 1 Mon, Oct-13-2008 12:36:46 AM
FS: GC Race Camber/Castor Plates for 60mm springs daver408 Parts for Sale/Wanted 4 Fri, Feb-01-2008 09:01:28 PM
PSS9 - camber plates and springs hsmith M3 Track: Racing and DE 8 Wed, May-23-2007 05:31:24 PM
Discussing Camber plates with OEM stock springs? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
