Old Thu, Mar-05-2009, 07:50:45 PM   #11
ClarkeBurns
At the limit of lateral adhesion
ClarkeBurns's Avatar
Reputation: 0 ClarkeBurns is on a distinguished road
Thanks a lot for putting this out. It's a huge help as I'm shopping for headlights.
Previous:
1995 Avus M3
2004 Mystic M3
Current:
1999 Hellrot M3 (80k miles)
Looking to buy: OEM high arch spoiler in Hellrot (or whole trunklid)
Would consider a GT style wing as well (w/o risers).
Zionsville competition cooling kit, Samco hoses, Stewart WP, clears + black kidneys, AA Gen III muffler, X-brace, Sparco front strut tower brace, H&R front sway, oil pump nut secured, ZKW headlights, Motion Motorsports underpanel, V1 hardwire, 17x9 LTW5s in 245/40 Michelin Pilot Super Sports all around, AST4100s with 550F/650R, Vorshlag camber plates, Brembo drilled rotors, PF pads.
More to follow.
Jump to top ClarkeBurns is offline   Reply With Quote
Old Thu, Mar-05-2009, 08:02:49 PM   #12
Anubis
Dr. Awesomesauce
Anubis's Avatar
A few things I wanted to clarify:
1) OEM color temperature isn't really pure white. Pure white in most automotive applications is closer to 5000k then it is to 4300k. 4300-4500k is very very white, but it's on the yellow end, and does have a yellow tint to the overall output. It is the OEM color temperature because it's the brightest acceptable output. There's a reason that HID systems are 35W and halogens are by law limited to 55W. Headlights that are TOO bright are distracting and can cause problems for other drivers.
2) You said that the startup current draw from Hella Gen 3s was ~14-15A. It's more like 18-20A. That's right. 20A.
3) You said that an 8000k PnP HID kit will be barely better or no better than stock halogen H1 output from euro ellipsoids. I disagree. It's significantly worse. Trust me, when I've got my Osram Night Breakers in my Bosch halogens, the output will be on par with the output from my 55W 5000k PnP HID kit that was running in my ZKWs. It's not only about how bright the light is - it's about where it goes and how much it distracts you. PnP HID kits are super distracting. I couldn't stand mine, even properly aimed.
4) You also failed to mention the fact that running HIDs in your low beams only means that your stock high beams are going to look ridiculous and will not match in color temperature, which will distract you even more.
5) You failed to mention the fact that HIDs should never be run in high beams or fog lights (due to flashing high beams restarting the HIDs in the fogs too quickly and decreasing their lifespan and the horrible lifespan from flashing high beams with HIDs).
6) Brett removed all of the information related to his DIYs. It's not there anymore. His OBC-LBF fix only applied to 18-button OBCs and disabled the ENTIRE Check Control system. Simpler than disabling the LBF with wire-cutting, but it does prevent you from realizing when a brake light is out or when something that you can't see easily is messed up. Cutting the four wires is much less ghetto than disabling the entire Check Control system, IMO.
7) Nice videos overall, though. I enjoyed them.
Originally Posted by kramerbuccs24 View Post
cliff notes?
http://www.m3forum.net/m3forum/showthread.php?t=217994
Old Thu, Mar-05-2009, 08:20:12 PM   #13
97_4dr_5spd_m3
Old College Kid
97_4dr_5spd_m3's Avatar
Reputation: 0 97_4dr_5spd_m3 is on a distinguished road
great job...
E36M3 Price (fn) = $23,235.64 - .06(mileage) - 1,802.85(coupe) - 1,718.44(vert) - 442.10(age of M3)
2012-2010 Mket Price (fn) = $16,593.86 - 0.05(per mile) - 2,907.51(coupe) - 2,262.52(vert) + 16.35(age)
Sedan Price (fn) = $20,183.43 - 0.04(mileage) - 340.09(age)
Coupe Price (fn) = $22,133.90 - 0.06(per mile) - 465.11(age)
Vert Price (fn) = $31,164.49 - 0.09(per mile) - 1,019.64(age)
Jump to top 97_4dr_5spd_m3 is offline   Reply With Quote
Old Thu, Mar-05-2009, 08:48:32 PM   #14
kerph32
Unregistered user
Reputation: 0 kerph32 is on a distinguished road
wow, nice work. where was this 3 years ago??
High Def too
Mike
1997 Cosmos M3
2009 BSM 335d
DIY: Washer Fluid
Jump to top kerph32 is offline   Reply With Quote
Old Fri, Mar-06-2009, 02:50:10 AM   #15
97_4dr_5spd_m3
Old College Kid
actually I have a question....
what would be a solution for matching your Fogs to your headlights if you were to want to upgrade??
Old Fri, Mar-06-2009, 03:44:05 AM   #16
dust4life
I hope you like drinking and sarcasm
dust4life's Avatar
Reputation: 0 dust4life is on a distinguished road
through part 1, going to get some and blow through the rest
god i need to source some zkw's....
Jump to top dust4life is offline   Reply With Quote
Old Fri, Mar-06-2009, 06:11:02 AM   #17
mirus
Reputation: 0 mirus is on a distinguished road
Thanks for posting those. I am definitely a noob that found that very useful. I think in the third video you said that plug and play can cause the car's central computer to report an error. I just wanted to clarify. Are you talking about plug and play HIDs, or plug and play halogen headlights, or both? I don't want to do the HIDs and I also don't want to get error messages and issues with my car's electrical system, so I want to make sure that if I go with DEPOs or ZKWs nothing will happen.
Jump to top mirus is offline   Reply With Quote
Old Fri, Mar-06-2009, 06:16:51 AM   #18
Anubis
Dr. Awesomesauce
Anubis's Avatar
If you run ZKWs or DEPOs without HIDs, you will have no issues with electrical systems or error messages. When he says Plug and Play, he's referring to PnP HID kits.
Old Fri, Mar-06-2009, 01:03:00 PM   #19
Diesel///M3
Oh no you d'nt!
Diesel///M3's Avatar
Reputation: 0 Diesel///M3 has disabled reputation
So Anubis, are you saying that your PnP 55w 5000k kit was not preferable. I only ask because I was considering this same setup. I am also a noob at lighting, and value anyone's opinion on this that has expertise. What would be your personal favorite setup?
"Its not who we are underneath, but what we do that defines us."
-Jay
Upgrades: AA Gen III, AA track pipe, AA tune, H&R Sports, blown Bilsteins, TMS aluminum RSMs, UUC tranny mounts(red), UUC sways, TMS RTABs, M50, CAI, 10mm front spacers, X-brace, Brembo/Hawk, SS brake lines, ltw flywheel/JB clutch, CDV delete, Alpine HU
Coming soon: Powerflex subframe bushings, RE RSMs, UUC RTABS, Koni's, AA diff support bracket, new diff mounts, AA 3.5" CAI, Euro 3.5" HFM, Bimmerworld 3.5'-3" elbow, UUC SSK/DSSR, 140a alternator, 6000K HID heads and fogs...
Jump to top Diesel///M3 is offline   Reply With Quote
Old Fri, Mar-06-2009, 03:19:24 PM   #20
Anubis
Dr. Awesomesauce
Anubis's Avatar
I didn't like my HID kit. At all. There were too many hotspots, the upticks distracted me, and I felt like I couldn't see the road well. I also felt distracted.
My personal favorite setup would be a projector retrofit of some kind, FX35 bi-xenon or TSX. If you insist on HIDs, then consider that route. If not, you may want to look into modding your cutoff shield slightly (there's a link at the end of the HID lighting FAQ thread in my sig) so that the upticks are smaller. You'll still have hotspots, but at least the upticks won't distract you and dazzle other drivers.
Also, 55W HIDs are really going to be overkill. They're already bright enough at 35W. You might be able to avoid an Low Beam Faliure message if you go 55W (for some reason it happens less with 55W kits).
Just my opinions.
e36, lighting, noobs, part, tutorial, video
BMW E36 M3 Pre-purchase Info and Advice (3 Part Video) YOUTUBE slammedm3 E36 M3 (1992-1999) 18 Thu, Oct-16-2008 05:01:19 AM
BMW E36 M3 Pre-purchase Info and Advice (3 Part Video) YOUTUBE slammedm3 Member Photos and Videos 0 Sun, Oct-05-2008 01:18:51 PM
Quest For Better Lighting Part II - review of LightWerkz TFX xenon retrofit ///Malicious Member Photos and Videos 23 Wed, Aug-29-2007 08:19:11 AM
SMG Launch Control Tutorial Video!! finovski E46 M3 (2001-2006) 7 Fri, Jul-21-2006 04:25:29 PM
••ü•• Tutorial/Lighting FAQ umnitza E46 M3 (2001-2006) 10 Mon, Jun-27-2005 02:08:28 AM
Discussing E36 Lighting for noobs- 4 part Video tutorial in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
