Old Sun, Jun-07-2009, 06:05:01 AM   #11
CBS
CBS's Avatar
Reputation: 0 CBS is on a distinguished road
Just reef on it.
Jump to top CBS is offline   Reply With Quote
Old Sun, Jun-07-2009, 06:08:33 AM   #12
kkamakasi
울산박
kkamakasi's Avatar
Reputation: 0 kkamakasi is on a distinguished road
South Korea
Originally Posted by CBS View Post
Just reef on it.
what does that mean?
Gone...... and forgotten
Jump to top kkamakasi is offline   Reply With Quote
Old Sun, Jun-07-2009, 06:35:25 AM   #13
Itsablurr
Reputation: 0 Itsablurr is on a distinguished road
Originally Posted by kkamakasi View Post
so once the clamps are off they can't be re-used?
i tried putting the old ones back on after installing the OEM plenum back on the car after removing the delage airbox but couldn't get the original clamps back on...
sure you can re-use them.
I've had mine on and off numerous times. To take them off just squeeze with a pair of pliers and pop off with a small flathead. To put them back on just squeeze closed slightly with your fingers so you can fit the pliers, then squeeze, and you should hear a nice snap when they clamp closed. Piece of cake.
...or you can also get the tool like cali posted.
2003.5 M3: BBS LM - TC Kline - Vorshlag - Borla
2001 S54 M Roadster: BBS Motorsport 3pc Magnesium - TC Kline - 3.73LSD - HMS Rollbar - Stromung
1967 Chevelle 2dr Coupe: Cragar S/S - Dynomax
Jump to top Itsablurr is offline   Reply With Quote
Old Mon, Jun-08-2009, 12:04:14 AM   #14
carpainterinaz
carpainterinaz's Avatar
Reputation: 0 carpainterinaz is on a distinguished road
just read this post and decided to add to it just replaced my starter in my m car those pliers in the picture work great got a set on the snap-on truck for like 18 dollars as far as the clamps go they can be reused but for any one looking i bought 6 from the dealer with my bodyshop price for 2$ a peice list is only like 2.50 the part number for them are 11 61 7 831 745 they call them muffler clamps but they are the right parts i didnt have to use them but have them for the next time if i need them
Jump to top carpainterinaz is offline   Reply With Quote
Old Thu, Jun-11-2009, 03:57:32 AM   #15
OptionLessM
Obliging
OptionLessM's Avatar
Reputation: 0 OptionLessM is on a distinguished road
are you selling that delage airbox you took off? pm'd
There is no need to be upset...
Jump to top OptionLessM is online now   Reply With Quote
Old Thu, Jun-11-2009, 11:14:21 AM   #16
kkamakasi
울산박
kkamakasi's Avatar
South Korea
sold... long time ago
Old Thu, Jun-11-2009, 11:16:15 AM   #17
kkamakasi
울산박
kkamakasi's Avatar
South Korea
is it going to be easier to PUT THE CLAMPS BACK ON with this tool?
Old Thu, Jun-11-2009, 12:03:24 PM   #18
Surk///M
Reputation: 0 Surk///M is on a distinguished road
I just removed my Intake manifold to clean T-bodies and replace front TPS.. took clamps off with screwdriver, but almost impossible to put back without those Lisle pliers.. def a must for $20, made remove-install simple..cyl 5-6 are only tricky ones..i also used new clamps, but if you use this tool to remove--you should be able to re-use original clamps..
Rad R10 wheels--Conti-Xtremes--JVT headers--HF Cats--SS MidPipe--AP Muffler--BMC Filter & Elbow--CSL Custom mapped Software--PSS9 Coils--Stoptech Pads--RE RTAB--PF FCAB--Rogue SSK--HID Fogs
Jump to top Surk///M is offline   Reply With Quote
Old Thu, Jun-11-2009, 05:00:37 PM   #19
Fastdog911
Fastdog911's Avatar
Reputation: 0 Fastdog911 has disabled reputation
if you do botch it up the part # is11617831745 63mm
[IMG]2002 SMG, Topaz Blue, BHS pulleys, all options. UUC Exhaust, GC Sway bars, SS lines, BHP Pads F1 paddles, GSP brake pedal, Huber Optik 20%, Iforged rims and a bunch of other things.. FOR SALE!
1970 911T Tangerine
1972 911T Albert Blue
Jump to top Fastdog911 is offline   Reply With Quote
Old Mon, Dec-14-2009, 05:10:50 PM   #20
jyi
jyi's Avatar
Reputation: 0 jyi is on a distinguished road
There are two types of clamps. The one closer to the throttle body is slightly bigger and the design is different. As you can see from the two different part numbers.. Part #3 and Part #15
The clamps closer to the throttle body (Part #15 in the picture above), I can figure out how to put it back on as the design is simple enough so that I know where to place the Lisle tool to snap it back into place. However the clamps further away from the throttle body (Part #3) has a different design so I'm not sure how to use the Lisle tool to put it back on. Can someone chime in?
Jump to top jyi is offline   Reply With Quote
clamp, intake, manifold, removal
Spare intake manifold + extra material = gold intake! JeST E46 M3 (2001-2006) 94 Tue, Jan-24-2012 12:12:24 PM
Help! Intake Manifold Superman#1 E46 M3 (2001-2006) 3 Tue, Feb-12-2008 02:27:56 PM
Fs: Oem Intake Manifold And Stock Intake NM3FAN Parts for Sale/Wanted 0 Mon, Sep-24-2007 08:04:43 PM
Intake manifold Qs park828 E36 M3 (1992-1999) 12 Fri, May-14-2004 07:00:55 PM
Funky Hose Clamp Removal ???? xochytl E36 M3 (1992-1999) 2 Sun, Jul-13-2003 09:41:23 PM
Discussing Intake manifold clamp removal in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
