Old Thu, Mar-12-2009, 03:37:00 AM   #11
JeST
Old Skool
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
Originally Posted by MatthewRyan View Post
Can anyone give better directions to this screw? Lol, sorry but I'm not sure where the actuator is... would I have to remove the door panels?
No need to remove anything. Just open the door and look at where the mechanism (door lock actuator) holds the door shut.
Red arrow is pointing at the rubber grommet that's hiding the alan screw.
1988 M3 - Henna/black on black alcantara
2012 Ducati 848 Evo Corse
Jump to top JeST is offline   Reply With Quote
Old Thu, Mar-12-2009, 01:50:05 PM   #12
kktvr4
Reputation: 0 kktvr4 is on a distinguished road
China
Its working like a charm now.
Thanks guys and JeST.
Jump to top kktvr4 is offline   Reply With Quote
Old Thu, Mar-12-2009, 04:52:18 PM   #13
MatthewRyan
Reputation: 0 MatthewRyan is on a distinguished road
JeST, you are the MAN.
Jump to top MatthewRyan is offline   Reply With Quote
Old Thu, Mar-12-2009, 05:11:50 PM   #14
The Nebulizer
The Nebulizer's Avatar
Reputation: 0 The Nebulizer is on a distinguished road
Thanks for the info Jest.
Mine just started doing this and was planning to search (I knew I had seen something like this long ago.) Thanks for the reminder and picture.
Jump to top The Nebulizer is offline   Reply With Quote
Old Wed, May-06-2009, 06:08:12 AM   #15
loayoweis
Reputation: 0 loayoweis is on a distinguished road
Originally Posted by JeST View Post
Each door has a alan screw that can remedy this. You can find this alan screw under a rubber grommet, about the size of your pinky nail, near the door lock actuator. Remove the grommet and tighten the screw down snug. This should take care of the problem but you can also add some spray lube (HHS2000 is a good one I use). I believe the driver side is clockwise and the passenger side is counterclock wise to tighten down (or vice versa).
I have screwed mine snug but it still requires a long pull before the door unlocks. I also lubricated around the latch. Any other ideas? A local indy shop recommended perhaps they can remove the door panel and inspect the latch?
Should I try loosening the alen screw?
Thanks,
Loay
Jump to top loayoweis is offline   Reply With Quote
Old Wed, May-06-2009, 11:23:05 AM   #16
ClutchKickChris
Reputation: 0 ClutchKickChris is on a distinguished road
WD40 isn't a lubricant at all. It stands for water displacement and is used to rust proof metal.
05 M3 ZCP
Jump to top ClutchKickChris is offline   Reply With Quote
Old Wed, May-06-2009, 07:47:12 PM   #17
loayoweis
I went and purchased a can of silicone spray lubricant and applied it and it did not make much of a difference.
I took it to an indy shop and without removing the door panel they were able to adjust the latch and also clean it so as to apply only a little bit of lubricant. I was told too much of this can make this worse.
At any rate, it feels much better now. Thank God !
Regards,
Loay
Old Wed, May-06-2009, 09:14:22 PM   #18
anomaly
Vert Crew Represent
Reputation: 0 anomaly is on a distinguished road
too funny I had this problem the other day and I was thinking I need to post about it on the forum!!! I also noticed that when I unlock using the transmitter I can't pop the door knob down with the door open.. is it supposed to be this way? I will need to try the allens key method when I get home tonight!! thanks people!
04 M3 Convertible 6 Speed Manual
<HRE> <Eisenmann> <Active Autowerke> <BSW> <KW> <SPC> <Prosport> <AutoSolutions> <Vornsteiner> <Z06 Brakes>
Jump to top anomaly is offline   Reply With Quote
Old Mon, Jun-15-2009, 01:32:20 PM   #19
kmow
Flying Tiger
kmow's Avatar
Reputation: 0 kmow is on a distinguished road
Hong Kong
The only problem I have with WD40 is it's really weak. It'll work well for a little bit but it wont address the issue especially if there's extra slack, caused by repeated use over time, in the door lock actuator. Tightening down the alan screw I posted above removes the slack which makes opening the door normal again.
took 3 minutes (2 for finding right allen wrench and 1 to tighten n clean up)
+1...
three times a charm
Current Ladies
2004 E46 M3 SMGII
2005 E46 330Ci M Package
Former Ladies
BMW 1997 323i E36
BMW 1995 323i E36
AUDI 1996 A4 (B5) 2.8L Quattro
AUDI 1988 90S Quattro
AUDI 1986 4000CS 2.2L Quattro
Jump to top kmow is offline   Reply With Quote
Old Mon, Jun-15-2009, 10:17:13 PM   #20
itchyn
Reputation: 0 itchyn is on a distinguished road
BTW, the allen key in the OEM trunk toolkit fits perfectly.
Jump to top itchyn is offline   Reply With Quote
door, handle, sticky
Part of the vinyl door panel is slightly tacky / sticky der Fahrer E46 M3 (2001-2006) 1 Thu, May-29-2008 02:57:01 AM
sticky driverside door lock? dust4life E36 M3 (1992-1999) 3 Fri, Nov-23-2007 08:50:54 PM
door handle help b3m2w5 E46 M3 (2001-2006) 1 Tue, Mar-06-2007 01:01:17 AM
sticky door hydroman1969 E36 M3 (1992-1999) 0 Thu, Jan-20-2005 12:27:20 PM
Door Handle beerplease E36 M3 (1992-1999) 2 Wed, Mar-24-2004 02:52:59 PM
Discussing Sticky door handle. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
