Old Wed, Mar-11-2009, 04:59:33 PM   #1
imapirate30
Reputation: 0 imapirate30 is on a distinguished road
Germany
Default Heated seat doesn't work on driver side
i have a 1995 e36 M3, the switch lights up/appears to work fine and the passenger heat/switch all work top notch. Just the Driver side heated seat doesn't heat when i turn it on.
Any Sugesstions ?
Jump to top imapirate30 is offline   Reply With Quote
Old Wed, Mar-11-2009, 05:01:55 PM   #2
badgtho
Team Nexen Racing
badgtho's Avatar
Reputation: 0 badgtho is just really nice
Any Sugesstions ?
unplug the harness for the heated seat under the seat and throw a meter on it. see if you're getting juice.
if you are then the element is damaged.. this is common on older cars and the replacement is a PITA.
if you are getting no voltage to the harness under the seat then move upstream and test the switch by swapping it with the other one.
if the switch lights up i'm going with a bad element in the seat but i guess you never know.
Current - '99 estoril/mulberry coupe || Past - '97 alpine/anthrazit coupe || 10,000+ post club || OG club
Badgtho can be rude but he certainly knows more than you.
A Moment of Zen, brought to you by BadGTho:
Originally Posted by salty View Post
At any rate, our MDX is running 5w20 and it can tow 3500 pounds.
Jump to top badgtho is offline   Reply With Quote
Old Wed, Mar-11-2009, 06:59:19 PM   #3
imapirate30
Germany
alright thank i'll check that out and see
Old Wed, Mar-11-2009, 07:01:12 PM   #4
ETK90
Reputation: 0 ETK90 is on a distinguished road
Bulgaria
joo know way too much
Jump to top ETK90 is offline   Reply With Quote
Old Wed, Mar-11-2009, 07:18:54 PM   #5
99TitanM3
99TitanM3's Avatar
Reputation: 0 99TitanM3 is on a distinguished road
I have the same problem with my drivers side seat. The button doesn't light up though either.
Jump to top 99TitanM3 is offline   Reply With Quote
Old Wed, Mar-11-2009, 07:24:48 PM   #6
badgtho
Team Nexen Racing
badgtho's Avatar
you may have a different problem.
in your case i'd pull the switch and confirm that it's receiving juice.
once you've confirmed that proceed with what i told the other guy to do.
Old Wed, Mar-11-2009, 07:36:52 PM   #7
99TitanM3
99TitanM3's Avatar
Alright man thanks. I'll have to check it out after work.
Old Wed, Mar-11-2009, 07:40:15 PM   #8
badgtho
Team Nexen Racing
badgtho's Avatar
let me know what you find.
Old Wed, Mar-11-2009, 07:43:03 PM   #9
Zuletzt
Hater
Zuletzt's Avatar
Reputation: 0 Zuletzt is on a distinguished road
Same problem as OP but I dont care enough to fix it. I dun really care that much if my ass is warm...as long as I have heat blasting at my face Im good.
Ryan
Jump to top Zuletzt is offline   Reply With Quote
Old Wed, Mar-11-2009, 08:04:51 PM   #10
imapirate30
Germany
any idea of parts number of heated seats element ?
driver, heated, seat, side, work
Help- Seat Diagram (Driver Side) coke4class E46 M3 (2001-2006) 4 Fri, Feb-20-2009 05:30:23 PM
Driver Side Seat 4liter E36 M3 (1992-1999) 10 Thu, May-22-2008 09:56:46 PM
Driver Side Seat 4liter Faults, Fixes and DIY 0 Thu, May-22-2008 08:32:46 PM
Driver heated seat emfollin E36 M3 (1992-1999) 9 Fri, Sep-16-2005 03:26:20 AM
WARRANTY-on rubbed driver side seat? hotM3cab E46 M3 (2001-2006) 2 Tue, Sep-13-2005 03:44:52 AM
Discussing Heated seat doesn't work on driver side in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
