Old Thu, Mar-26-2009, 03:12:24 AM   #1
SUMOM3
Reputation: 0 SUMOM3 is on a distinguished road
Default AA BOV change... Some info inside...
By no means Am i an engineer or anything, but have many years playing around with SC/Turbo applications.
After much debate and people bringing up the issue of BOV lag issues, I thought of a new project. Few enthusiasts thought of a modification to help relieve the throttle plates slapping clsed due to the pressure not completely being relieved by the AA BOV that is provided. I am assuming that many think that the BOV diameter is "too small"???
Well, Im going to do some testing and measurements of the AA BOV and the Vortech MONDO BOV.
As it stands "Rumors are, that the AA BOV was orginally designed to a capacity of 4-6 psi.
As it stands, looking at Vortechs site, it shows the MONDO BOV being rated 0-10 psi (up to 12).
Now if this is simply the facts and its true... Well im thinking of just cutting out the flange and getting the vortech flanged welded on.
Things i need to find out:
1. I need measurements on the overall size of this MONDO BOV, and the air inlet.
2. Try and see if it will even fit in the tight spot were the BOV is currently in.
3. Try and find a used Vortech BOV
Thoguhts, Advice, Opinions are welcome.
Performance: AA Ecu tuning ~ AA GenIV Exhuast ~ Rouge Sec I Piping ~ AA Short Shifter ~ Ebay Headers ~ AA Gen3 Stage2 SC~Snow Performance Methenol Injection ~ Dyno Tune progressive Nitrous ~ BMW Motorsports 4.10 diff. ~ BAV Auto Coils ~ HPF Upgraded fuel pump~ few more I cant remember right now
Suspension: TCK S/A Coilovers 500/600 ~ TCK Camber kit ~ Powerflex RTAB ~ Rear Subframe Reinforcment (HPF)~ Rear subframe poly bushings
Interior/Exterior: CSL Front Bumper w/ 1 pc race lip~ Vorstiener Vented Double cf hood~Depo Corners ~ Painted front reflectors ~ Recaro SRD ~ EAS CF Interior ~ CF Diffuser ~ LM Reps~ TMS Studs with Blox lugs
Stereo: Aluma Pro 2-ways F/R ~ Arc Audio 12' sub ~ Arc Audio Amps ~ Custom rear setup ~ Alpine Deck w/ touch screen ~ Alpine Ipod interface ~ Alpine Sirius Interface
Soon to come: Im Broke dammit!
Jump to top SUMOM3 is offline   Reply With Quote
Old Thu, Mar-26-2009, 03:19:15 AM   #2
mm28
M&M
mm28's Avatar
Reputation: 0 mm28 is on a distinguished road
Hong Kong
sounds straight forward enough, i think is going to work
Gone but not forgotten:
2005 Silver Grey M3
2005 Interlagos Blue M3 ZCP, AA supercharged 474RWHP (91 octane pump gas)
Video: 40-120mph = 9.1 seconds (91 octane pump gas)
Current rides:
Daily Driver:
Silver on black A6 (stock)
Black on black CLK (stock) the most unreliable car i've ever own...
Silver Buick 2.0T (stock) slowest car i've ever own LOL...
Weekend:
Black on red 997TT (stock)
Jump to top mm28 is offline   Reply With Quote
Old Thu, Mar-26-2009, 05:11:53 AM   #3
MSpired
Reputation: 0 MSpired is on a distinguished road
Good idea. I believe CA Automotive in the UK has replaced a few AA BOV's with some Blitz units. Try contacting them and getting some info if they are willing to share.
Jump to top MSpired is offline   Reply With Quote
Old Thu, Mar-26-2009, 05:39:44 AM   #4
SUMOM3
So i did some additional searching and found some nice info reading in some mustang forums.
There are actually several different BOV's we can choose from but it all boils down to size.
1) Vortech MONDO BOV: Its a tad bit taller than a coke can, but much bigger than a coke can in circum.... Keep in mind, the flange will add addition length over...Price: $275 (Satin) $306 (polished)
Info:
Vortech Maxflow Bypass/Blowoff Valves improve supercharger operations by opening to relieve unwanted pressure during deceleration, this reduces heat build-up and eliminates compressor surge. These units feature a "rolling diaphragm" design which provides ultra-quick valve response along with unmatched reliability.
2) Tial: makes a very nice 50mm opening (claims to be the biggest openeing available of all BOV's). $243
info:For use on turbo-charged and super-charged applications (Paxton, Vortec, etc.). The body and all internal components are CNC-machined from 6061 aluminum alloy. It features a large 1.98 in (50.5mm) valve; we believe this is the largest valve available with the highest flow capacity. The V-Band design aluminum mounting clamp gives a very clean and unique appearance. The clamp is anodized and uses Stainless Steel hardware for a long lasting, corrosion-free appearance.
The blow off valve seal utilizes a Viton O-ring that is clamped in place to prevent the possibility of sticking to the seat and pulling out. The valve stem and guide are teflon-lubricated, hard anodize-coated for wear resistance.
The Blow Off Valve also comes with a machined aluminum banjo-type air fitting and bolt, with over sized 10mm hose barb for quick actuator response. The actuator has a high temp silicone Nomex-reinforced diaphragm for long life.
3) ATi Procharger BIG RED (best reviews so far as far as performance &Quality) $360-$415
I havent seen any info in depth about this unit yet. Im not too sure about what psi rating this unit has. I also have not seen the size of the unit as well. But it looks HUGE!
Old Thu, Mar-26-2009, 06:12:42 AM   #5
SUMOM3
Info found on e46psi:
As all 6 throttle plates snap shut, the air quickly accumulates in the intake plenum (manifold) causing a significant spike in pressure. This pressure spike was one of the reasons why Active Autowerke chose to not use the brittle and plastic OEM BMW plenum (more info - Forced Induction 101 section III). The Active Autowerke bypass valve then opens and relieves the pressure buildup by re-circulating the trapped air into the system and away from the plenum.
Although sufficient for level I cars (5.5psi), this airflow system is inadequate for higher levels where boost pressures reach in excess of 7.5psi. Having personal experience with this system, I can attest to the delay being as much as a full second on long gear pulls (4th gear and up). In situations where every second counts, this delay can dictate the outcome of your race or pass.
So, what is the root cause of the delayed, “laggy”, shifting? A definite cause has yet to be established, but the general consensus among a small group of dedicated BMWPSI.com members is that the bypass valve is simply ineffective. When open, the bypass valve attempts to re-circulate an enormous amount of air away from the plenum and into the backside of the Rotrex supercharger unit. The bypass valve has an opening of 40mm while the intake on the backside of the blower has a diameter of 30mm. This decrease in diameter causes a “bottleneck” of airflow and leaves unwanted pressure against the butterflies (throttle plates) preventing them from opening - hence the lag.
Fortunately, an Australian BMW enthusiasts and devoted member of BMWPSI.com took the time to document his “fix” for the lag. What follows is a step by step tutorial on how to rid delayed shifting on E46 M3s equipped with an Active Autowerke supercharger system.
__________________________________________________ ________________________
So that settles it! I think I will go with the Tial BOV knowing that its 50.5mm (10.5 bigger than the AA BOV)
Old Thu, Mar-26-2009, 08:43:28 AM   #6
Saintly
Reputation: 0 Saintly is on a distinguished road
[QUOTE=SUMOM3;3822101]Info found on e46psi:
Fortunately, an Australian BMW enthusiasts and devoted member of BMWPSI.com took the time to document his “fix” for the lag. QUOTE]
I did all the tests here and going bigger will help no doubt but I am running 10.5psi+ and have no issues. It is strange that some do still have the issues and others don't. I believe that there might be something more to it. I will be interested in your findings. Maybe it has something to do with where people are taking their vacuum line from
508rwhp Dynodynamics AA charged 9psi race gas(no nos) 11.618@122.65mph
521rwhp Dynodynamics AA charged 9psi race gas(125shot) 11.412@126.09mph(Best trap 129.72mph)
611rwhp Dynodynamics AA charged 9psi race gas(150shot) 11.7@129.49mph
631Rwhp highest HP to date.
Now: 528rwhp Dynodynamics 13psi Pump Fuel AA Charged
552rwhp Dynodynamics 13psi Race Fuel AA Charged
Jump to top Saintly is offline   Reply With Quote
Old Thu, Mar-26-2009, 09:45:03 AM   #7
odiedog52
Reputation: 0 odiedog52 is on a distinguished road
Where do you recommend we take our vacuum from?
I am having the same issue, massive lag between shifts and I did your bypass mod as well. People just think I shift really slow.
I also see spikes of 10, 11, 14 psi, etc at the end of my runs which may be attributed to this?
2002 TiAG M3 AA Gen 3 Level 2 supercharged with meth injection and nitrous wrecked
Best Time: 12.34 @ 115.74 (no nitrous)
469rwhp/321tq (no nitrous)
Jump to top odiedog52 is offline   Reply With Quote
Old Thu, Mar-26-2009, 09:50:15 AM   #8
SUMOM3
[QUOTE=Saintly;3822323]
The vacuum source is being taken exactly where AA instructions tell you to do so, which is off the Fuel rail.
Its very awkward... I feel the "pause" in shifts and its very noticeable. Keep in mind though, I still have the CDV valve as well, but if the facts are that the AA BOV is indeed 40mm, and its bottle necking from the manifold, then thats an issue. Also if the kit was only made with the intent orginally for 4-6 psi, then oviously this needs to be changed out.
Afterall... Dont we all strive to gain from little modifications? Reliability, Power, most importantly the need to always make things better...
By all means, the AA BOV is by far a very nice product and is proven to work... But as their intent to make more power was by adding a bigger blower, and injectors for more fuel, maybe the thought of the BOV was there, but not changed due to , "it works just fine"....
You also have to take in consideration that they are/did make available the upgrade at a very affordable cost and then eventually just made it the "current" kit, and Still managed to keep the cost the same! GOTTA LOVE AA FOR THIS!!!
Old Thu, Mar-26-2009, 11:55:47 AM   #9
votE46
votE46's Avatar
Reputation: 0 votE46 is on a distinguished road
subscribed!
Jump to top votE46 is offline   Reply With Quote
Old Thu, Mar-26-2009, 01:08:21 PM   #10
Saintly
Fuel rail for vac is correct. I have seen some take it off the intake manifold. I know that some tuners play with the throttle maps and cam overlap to help solve this issue. I am more puzzled at why some do and some don't there must be a reason. My thoughts are that if the lag was the direct cause of a too smaller outlet of the bypass then we all would have the problem, where as this is not the case and I know a few running 11-12psi boost like me with the AA bypass and no problems.
bov, change, info, inside
New here, been lurking, quick question, info inside. Bin_jammin E36 M3 (1992-1999) 13 Wed, May-28-2008 06:01:15 PM
FS:04 M3 with extras.Info inside RedZeater Cars for Sale/Wanted 30 Thu, Dec-20-2007 12:14:28 AM
talked to my dealer's GM...gave some inside info ampbmw E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013) 33 Tue, Mar-06-2007 01:37:23 PM
You want free music....:D (INFO INSIDE) Grimm333 Off Topic 5 Wed, Feb-23-2005 12:28:31 AM
Do you need image hosting for your sig??? (More info inside) Grimm333 Member Notes and Requests to Admin/Mods 9 Thu, Dec-09-2004 01:08:28 AM
Discussing AA BOV change... Some info inside... in the Forced Induction (F/I) Forum - Discuss the ever growing F/I options here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
