Old Thu, Apr-02-2009, 06:25:10 PM   #1
Fatz
Reputation: 0 Fatz is on a distinguished road
Default Car won't start - diagnosis
I know there are many threads regarding problems with starting. I thought it may be helpful to document my experience for others. Last week my car wouldn't start when I was leaving work. The lights, radio, etc. all came on, but nothing happened when I turned the key. I try to jump the car and it still won't start. My mechanic was convinced it was the battery, so I took it to him and he put a tester on it and said it "was on the poor side of mediocre" and should be replaced regardless. Ok, so I replace the battery and she starts right up. Wow, her was right, problem solved...
So I head out to lunch on Monday and again the lights come on but nothing happens when I turn the key. I tried to jump it again and still nothing, so I sent the whole car to the mechanic.
The battery tested fine and he couldn't detect any load on the battery when the car was turned off. Finally he becan chacking the ignition system and discovered that the clutch switch wasn't registering the clutch being depressed and therefore wasn't completing the circuit to start the car. I am still waiting for him to replace the switch, so I haven't absolutely confirmed that the problem is gone, but it appears that the switch was the culprit.
I hope this helps someone in the future.
BTW, what would be great is for someone technically inclined to come up with a quick temporary fix. Can the clutch switch be bypassed without messing up anything else? Since the switch isn't a part that gets replaced often, the dealerships diddn't have it in stock. My car is likely out of service for 2-3 days just waiting to begin the work. I'd much rather be driving it without the clutch switch.
Jump to top Fatz is offline   Reply With Quote
Old Thu, Apr-02-2009, 09:11:35 PM   #2
Viper966
Reputation: 0 Viper966 is on a distinguished road
yes, you can bypass teh clutch....
just twist the 2 wires together...
and just remember not to start the car while it is in gear...
Jump to top Viper966 is offline   Reply With Quote
Old Thu, Apr-09-2009, 03:50:48 PM   #3
Fatz
Default Still not solved
Well, two days after having the clutch switch replaced, the problem is back. Mechanic pretty much at a loss, says the only two things that would keep the ignition from engaging is the clutch switch and the alarm. He doesn't think the alarm is the problem as that would be very rare. but suspects that the clutch master cylinder may be hanging up, preventing the clutch from being depressed sufficiently to trip the switch.
I took a look at the clutch master cylinder and it appears to be depressing completely without any stickiness. There are four wires into the clutch switch. I think I'll try to jump accross the wires to eliminate the switch from the problem. There are quite a few post about starting problems, but I haven't seen this exact issue. Has anyone seen this problem before. Any help would be apreciated.
Old Thu, Apr-09-2009, 03:59:32 PM   #4
gpoints
elitist D-bag
gpoints's Avatar
Reputation: 0 gpoints will become famous soon enough
here you go:
http://www.m3forum.net/m3forum/showt...arting+problem
There are stupid threads and stupid people. Stupid people are the ones who make, stupid threads.
I run 87 octane because they don't make anything lower.
Starting OR Posting in these threads will make your car slower:
Which rims Should I buy?
Which color ___ looks best?
Where can I buy this wing?
Why don't other owners wave at me?
Jump to top gpoints is offline   Reply With Quote
Old Thu, Apr-09-2009, 04:08:45 PM   #5
Mpoweroo1
OO=00=OO
Mpoweroo1's Avatar
Reputation: 0 Mpoweroo1 is on a distinguished road
Originally Posted by gpoints View Post
Also, look into trying your spare key or the valet key. The battery in the key sometimes goes bad.
Jump to top Mpoweroo1 is offline   Reply With Quote
Old Thu, Apr-09-2009, 04:20:23 PM   #6
ohnoes
Reputation: 0 ohnoes is on a distinguished road
Why do mechanics/people in general ALWAYS bypass the simplest fix and pursue the least likely? I am willing to bet dollars to donuts it is either your starter (more likely) or key (less likely, but still possible).
Jump to top ohnoes is offline   Reply With Quote
Old Thu, Apr-09-2009, 06:07:22 PM   #7
deilenberger
deilenberger's Avatar
Jumping the wires is actually a bad idea (as is twisting them together).. it's not a SWITCH with contacts. It's a Hall-Effect-Sensor, that senses the position of the clutch pedal. It's an active device - solid state. Do a Google on Hall-Effect or Hall-Effect-Sensor.
The starter is the problem. It's happened to MANY other people, same symptoms. Sometimes it starts and once in a while - nothing.
Old Thu, Apr-09-2009, 06:33:55 PM   #8
Satans Idol
Tag Restricted
Satans Idol's Avatar
Reputation: 0 Satans Idol is on a distinguished road
Exactly. 999/1000 times the most likely solution is the solution. It is very rare that a rare part goes on a vehicle. The M is not excluded. I'd almost put money on that you need a new starter.
Jump to top Satans Idol is offline   Reply With Quote
Old Thu, Apr-09-2009, 07:53:20 PM   #9
Fatz
Thanks for the feedback. I have looked into the key (tried the spare) and read the post that gpoints linked, but my problem was an overnight issue. The first thing that was checked was the battery, as this was the simplest, most likely and cheapest fix. If it was the starter going bad (bad spots), I would think that this would be a problem that got progressively worse and turning the key a number of times would move the starter enough to eventually start the car. The starter hasn't been ruled out, but the mechanic wiggled the clutch when he received the car and it started, so that's where he began. Since there is no noise that would indicate the solenoid engaging, my guess is that the problem is between the solenoid and the ignition, but likely not the starter motor.
Let me know if this logic doesn't hold water.
Old Thu, Apr-09-2009, 07:55:13 PM   #10
ohnoes
Try holding the key in the ignition for up to 5 minutes, in the start position of course. Let us know if that starts the car. With this particular starter problem, holding the key for up to several minutes usually gets it to start.
car, diagnosis, start
HELP, Car WILL NOT start on first try. . .?? LoucasDJ5 General BMW Discussion 20 Mon, Oct-10-2011 05:43:31 PM
Car Won't Start Jason_E36 E36 M3 (1992-1999) 23 Sun, Jan-14-2007 07:31:06 PM
SA Diagnosis: "Sir, your car has Gremlins". TopMarc E46 M3 (2001-2006) 41 Sun, Jul-23-2006 12:30:11 AM
car won't start mching E36 M3 (1992-1999) 7 Tue, Jul-22-2003 05:11:30 PM
HELP: Can't start the car! Paparazzi E46 M3 (2001-2006) 2 Tue, Aug-06-2002 08:01:11 PM
Discussing Car won't start - diagnosis in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
