| E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013) {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} |
Useful Posts: 4
What is the normal maintenance schedule and what is done on inspection 1 and 2 for e9X?
Do you have to do the similar valve adjustments as the E46 or did it actually get easier to DIY? I am assuming the newer the car, the harder it will be to do anything at home but just wondering.... Thanks! |
#2 | |
![]() Location: Birmingham
My Beast! 20" Mania Vortec's Black Grills |
Useful Posts: 4
could it all be done easily at home? Like oil changes or are there crazy things it might need like valve checks and replacements?
#4 |
You've got a US flag in your signature, so why don't you just avail yourself of the free service that BMW USA provides?
Dave Last edited by dcstep; Mon, Apr-06-2009 at 02:13:50 AM. |
#5 |
![]() Location: Chicago
There are no valve checks like the E46 M3 had.
IND DISTRIBUTION | IND FACEBOOK | IND STYLE | EISENMANN BLOG | info@ind-distribution.com |
#6 |
![]() Location: East Bay
From page 6 of the Warranty and Service Book (available at BMWUSA.com)
Quote: Oil Service: Engine oil should be changed with the engine at operating temperature. Note: Change oil at least once a year. All 2008 model year M3 vehicles are factoryfilled with Castrol TWS Motorsport SAE 10W-60 Synthetic Engine Oil (BMW part number 07 51 0 009 420). This is the only approved engine oil at the time of printing of this book. BMW recommends that you check your engine oil level whenever you add fuel to your vehicle. If you need to add oil between oil changes and are unable to obtain Castrol TWS Motorsport 10W-60 Synthetic, BMW High Performance Synthetic Oil or Mobil 1, use a synthetic oil with an API rating of SH or higher. The following maintenance elements must be performed at the mileage/time stated (time intervals begin from the vehicles production date): Brake Fluid Service: Change brake fluid every two years, or when specified by CBS. Oxygen Sensor Service: The oxygen sensor deteriorates strictly on a mileage basis and must therefore be replaced every 120,000 miles to maximize vehicle fuel economy and minimize exhaust pollution. Spark Plug Service (not shown in CBS): Replace at 37,000 miles. The engine coolant has a lifetime rating and does not need to be changed except for system repairs. For your convenience, you may also wish to have your BMW center perform any necessary operations to fulfill any state inspection requirements in your area concurrent with the maintenance elements specified above during other repairs. Should you request more frequent maintenance service, the cost of these services will not be covered by the Maintenance Program. Unquote Free maintenance is BMW-speak for no maintenenace.
2008 M3 E90 6mt |
#7 |
Useful Posts: 4
Thanks, I was hoping that the E9x doesn't have weird maintenance requirements like the valve adjustment for E46. If I was gonna buy one, I would like to be able to keep it longer than 4 years without the maintenance costing a fortune.
#8 | |
I used to drive and autocross 5.0 Mustangs. They'll need some maintenancem, BUT it's very inexpensive compared anything on the BMW. An alternator will cost 250-bucks. I wouldn't be surprised if it's not $1500 for the M3. Many of the parts on the M3 are low volume and special purpose, where almost everything on the Mustangs is generic. So, I think the second 4-years will be relatively expensive. BTW, I plan to keep mine 10 or more years. Dave |
#9 | |
#10 |
Well, fwiw I plan on keeping my E90 for well past the 4 year mark. Sold the 2001 M Coupe at four years and the 2006 M3 at three, but I am tired of the depreciation hit.
2008 M3 E90 6mt |
| e9x, maintenance, schedule |
| Maintenance Schedule for Everything | Marku5 | Faults, Fixes and DIY | 6 | Tue, Feb-24-2009 08:49:37 PM |
| 97 M3 maintenance schedule? | 00poop6x | E36 M3 (1992-1999) | 20 | Tue, Feb-24-2009 01:17:36 PM |
| Preventative Maintenance Schedule | gfryesc | E46 M3 (2001-2006) | 1 | Fri, Jan-20-2006 01:07:54 AM |
| maintenance schedule??? | E-solo | E46 M3 (2001-2006) | 1 | Sat, Nov-12-2005 03:19:07 AM |
| 99's have a different maintenance schedule then 95-98 right? | astan100 | E36 M3 (1992-1999) | 0 | Wed, May-12-2004 03:44:05 AM |
